Thank you very much for your reply !
The issues of pink tiles in some base layers (Bing, Mapquest) and limited
zoom-in in OpenStreetMap were fixed.
After further investigation I figured out that for Mapquest maps rendering,
I had to create an account and get an api key from MapQuest. After that, I
had to define it in my local_settings.py code. Instead, I preferred to
remove the MapQuest and Bing base layers and added BlueMarble layer (with
OpenStreetMap) . After that modification the problem of limited zoom-in in
OpenStreetMap base layer was fixed but I have no idea why.. :-)
I found very helpful the following links:
http://docs.geonode.org/en/master/tutorials/advanced/geonode_production/production.html#production
http://osgeo-org.1560.x6.nabble.com/MapQuest-has-discontinued-direct-tile-access-td5275881.html
Thus, after modification the corresponding part of the code at the
local_settings.py file looks like this:
MAP_BASELAYERS = [{
"source": {
"ptype": "gxp_wmscsource",
"url": GEOSERVER_URL + "wms",
"restUrl": "/gs/rest"
"source": {"ptype": "gxp_olsource"},
"type":"OpenLayers.Layer",
"args":["No background"],
"visibility": False,
"fixed": True,
"group":"background"
"type":"OpenLayers.Layer.OSM",
"args":["OpenStreetMap"],
"fixed": True,
"type":"OpenLayers.Layer.WMS",
"group":"background",
"fixed": True,
"args":[
"bluemarble",
"http://demo.opengeo.org/geoserver/wms",
"layers":["bluemarble"],
"format":"image/png",
"tiled": True,
"tilesOrigin": [-20037508.34, -20037508.34]
{"buffer": 0}
"source": {"ptype": "gxp_mapboxsource"},
Best Regards,
George
2017-01-30 10:23 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi,
> your procedure is correct, you have to go with the manual installation.
> Geoexplorer hasn't changed from 2.0 to 2.4, you should investigate more
> the issue of pink tiles by looking at the http response that comes from
> geoserver. For the limited zoom it may just be a configuration in the
> map_geoexplorer template https://github.com/GeoNode/geonode/blob/master/
> geonode/maps/templates/maps/map_geoexplorer.js.
> hope this helps
> 2017-01-27 17:14 GMT+01:00 gkpetrak <gkpetrak at gmail.com>:
>> Hello,
>> I installed and customized a Geonode project (2.0 edition) on my fresh
>> local machine (Ubuntu 12.04) with apt-get installation.
>> Now I have to deploy the project on a virtual machine which already hosts
>> a WebGIS application (with technologies such as Geoserver / Jetty,
>> Postgresql / PostGIS, Apache2) on Ubuntu 12.04.
>> I think that Geonode installation via apt-get is not recommended when the
>> machine already runs individual software components of Geonode. So I have
>> to install Geonode with custom installation following this link:
>> https://geonode.readthedocs.io/en/2.0/tutorials/admin/instal
>> l/complete_install.html
>> Am I wrong ?
>> Also because I have some problems with GeoExplorer of Geonode 2.0 (pink
>> tiles and limited zoom in) is there a way to upgrade to GeoExplorer of
>> Geonode 2.4 ?
>> Thank you in advance !
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170130/58302a37/attachment.html>
