[GeoNode-users] Issue on updateip in migration to 2.6
Annalisa Schiavon annalisa.schiavon at gmail.com
Mon Jul 3 03:14:44 PDT 2017
Thanks!  Yes, if I replace it, it works.
For the stale layers, I can't remove them from the admin panel, It gives
error! I try to remove from DB, checking dependencies, ok?
Thanks again
2017-07-03 11:31 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Annalisa, layer preview from geoserver seems to have a bug in the url of
> the preview itself
> if you right click and copy the url you'll notice it has two "?". if you
> replace the second one with "&" then should work. This will probably be
> fixed in next gs releases
> 2017-07-03 11:21 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Hi Toni,
>> 2017-07-03 10:07 GMT+02:00 Toni Schönbuchner <toni.schoenbuchner at csgis.de
>>> Hi Annalisa,
>>> I setted the ip address in geonode-oauth2 in a couple of lines they still
>>> point to "localhost“.
>>> You could grep your files to see if somewhere localhost is still
>>> mentioned:
>>> grep -rn --include="*.py“ „192.68.31.80" 2>/dev/null
>> Ok, but now it seems that localhost should remain in some settings, maybe?
>>> Here it is an example of a wrong preview link:
>>> http://192.168.31.80/geoserver/geonode/wms?access_token=SFtO
>>> 1m1uwzKVWzOmJmsQi72nMQyEfi?service=WMS&version=1.1.0&request
>>> =GetMap&layers=geonode:v_staz_aria_attive&styles=&bbox=16472
>>> 77.811,4991070.397,1798213.0,5117620.0&width=768&height=
>>> 643&srs=EPSG:3003&format=application/openlayers
>>> You want the local IP to be a public, right?
>>> Stupid question. Have you restarted your web servers?
>> After checking all, I'll have to change it to a domain ... Yes, I've
>> restarted apache and tomcat
>>> Then, I've some old layers in geonode that doesn't more exists in
>>> geoserver. If I try to remove from geonode ui It fails. Also the "geonode
>>> updatelayers --remove-deleted" fails on those layers
>>> updatelayers has a verbose option.
>>> http://docs.geonode.org/en/master/tutorials/admin/admin_mgmt
>>> _commands/#updatelayers
>>> can you provide a detailed error output?
>>> There are geonode commands for clean or syncronize databases? Some docs?
>>> syncdb is now deprecated, right?
>>> I think to remember that from Django 1.9 synchdb is depreceated. Instead
>>> migrate
>>> should work. F.e.:
>>> python manage.py migrate auth# performs migrations for auth and contenttypes contrib apps
>>> python manage.py migrate --run-syncdb# creates the rest of the database
>>> I couldn´t find any updated documentation either.
>>> When searching for things like that I often have a look in pavement.py
>>> https://github.com/GeoNode/geonode/blob/master/pavement.py#L213
>>> Thanks
>> Annalisa
>>> Cheers,
>>> Toni
>>> CSGIS
>>> Kolonnadenstraße 1
>>> 04109 Leipzig
>>> Mobil +49/ (0) 176 6680 3198 <+49%20176%2066803198>
>>> Tel  +49/ (0) 341 24 04 738 <+49%20341%202404738>
>>> Fax  +49/ (0) 341 24 04 73 <+49%20341%20240473>
>>> Web http://csgis.de
>>> Hinweis gemäß § 33 BDSG
>>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist
>>> ausschließlich für den
>>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie
>>> diese E-Mail versehentlich
>>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und
>>> löschen Sie diese Nachricht
>>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung,
>>> Vervielfältigung, Veränderung,
>>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170703/acc87843/attachment.html>
More information about the geonode-users mailing list
