[GeoNode-users] Fwd: Raster Upload visualization issues
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jul 4 06:26:52 PDT 2017
Dear Naresh,
you can maybe take a look at those links which may help you clarify better
how the RasterSymbolizer works
http://docs.geotools.org/stable/javadocs/org/geotools/styling/RasterSymbolizer.html
http://docs.geoserver.org/latest/en/user/styling/ysld/reference/symbolizers/raster.html
Unfortunately it really depends on the structure of your data. I will be on
leave those days, for a workshop. If you still are not able to find a
solution, I can try to find some spare time to take a look at your geotiff.
Problem is I really don't know if I will be able to respond in the next
couple of weeks.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Tue, Jul 4, 2017 at 2:40 PM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Alessio,
>   Thanks a lot for the response.
>  I am new raster styling using SLD , and gone thorough the links you have
> provided, I am not able to understand what are the minimum basic rules/tags
> required to add in SLD to remove the issues which I mentioned. if you aware
>  please share the minimum basic parameters we need to include to remove the
> patches/issues. I will replace/add the rules in  the default  SLD, so that
> by default, the uploaded raster visualization should  come good with tiled
> service also.
> Best Regards,
> Naresh
> On Mon, Jul 3, 2017 at 7:54 PM, Alessio Fabiani <alessio.fabiani at geo-
> solutions.it> wrote:
>> GeoServer Layer preview is untiled by default, this is why you are not
>> currently seeing that effect.
>> Regards,
>> Alessio Fabiani
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> phone: +39 0584 962313 <0584%20962313>
>> fax:     +39 0584 1660272 <0584%20166%200272>
>> mob:   +39 331 6233686 <331%20623%203686>
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Mon, Jul 3, 2017 at 4:22 PM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Alessio,
>>> Thanks for the quick response.
>>>  However if we see same layer in Geoserver layer preview the issues are
>>> not observed, this means the problem might not be because of  side
>>> effect caused by WMS tiled requests using the default "raster" style on
>>> GeoServer.
>>> Please upload Geotiff which i attached in my earlier mail in GeoNode and
>>> visualize this layer with Geonode;s Geoserver layer preview, the problems
>>> are not observed.
>>> Kindly help me to resolve the issue
>>> Thanks&Regards,
>>> Naresh
>>> On Mon, Jul 3, 2017 at 7:33 PM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Dear Naresh,
>>>> this is a side effect caused by WMS tiled requests using the default
>>>> "raster" style on GeoServer.
>>>> In order to improve this, you should create a correct SLD[1] of type
>>>> RasterSymbolizer[2] compatible with your dataset, and upload it to
>>>> GeoServer.
>>>> You can also use advanced colormaps, like [3].
>>>> [1] - http://docs.geoserver.org/maintain/en/user/styling/sld/ref
>>>> erence/index.html
>>>> [2] - http://docs.geoserver.org/latest/en/user/styling/sld/refer
>>>> ence/rastersymbolizer.html
>>>> [3] - http://geoserver.geo-solutions.it/edu/en/pretty_maps/styli
>>>> ng_raster.html
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> On Mon, Jul 3, 2017 at 3:27 PM, Naresh N <naresh919 at gmail.com> wrote:
>>>>> Dear All,
>>>>>  I have published Geotiff in my GeoNode server. Original uploaded
>>>>> geotiff is attached with the mail for reference. Please find the following
>>>>> screenshots with various scale levels.
>>>>>  Scale:1:272492
>>>>> [image: Inline image 1]
>>>>>  scale:1:136428
>>>>> [image: Inline image 2]
>>>>> The following problems are observed
>>>>> 1. Some portion shining/brightness  is more, how ever if we increase
>>>>> zoom level in same portion, few portion only getting brighter and this is
>>>>> varying based on zoom level
>>>>> 2. Small ,small white lines are visible, which makes image quality poor
>>>>> 3.  Over all image is  visible as patches
>>>>> 4. Over all image looks compressed vertically
>>>>> *Kindly help me to resolve the issues*
>>>>> *Note:* I have tried to upload in demo Geonode site,GeoNode site is
>>>>> not working. Please kindly up the GeoNode demo server
>>>>> Best Regards,
>>>>> Naresh
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170704/2ccb024f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170704/2ccb024f/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170704/2ccb024f/attachment-0003.png>
More information about the geonode-users mailing list
