[GeoNode-users] geonode-project for templates
Annalisa Schiavon
annalisa.schiavon at gmail.com
Fri Jul 7 01:48:31 PDT 2017
Hi all!
I've create a new template after having upgraded geonode (to 2.6.1) with
this instructions:
$ django-admin startproject geoportale26
--template=https://github.com/GeoNode/geonode-project/archive/2.6.zip
-epy,rst
$ sudo pip install -e geoportale26
according these instructions: https://github.com/GeoNode/geonode-project
But I've chosed 2.6 branch, is it correct?
I've these problems:
1. I don'y have local_settings.py.sample in my dir, so I don't renamed it
and I've got only a settings.py in my dir geoportale26/geoportale26.
2. I changed/added some files in static dir (site_base.css, img, js and
geoexplorer-debug.js) and in template dir, but the file "geo_header.html"
under templates/geonode seems have no effect on the new site! In
geo_header.html
I call geoexplorer-debug.js instead of geoexplorer.js, how can I do?
To apply changes, I run python collectstatic, and it replaces original
static files in /var/www/geonode/static with mine, but how does it work
with templates?
Thanks to all
Annalisa
2017-06-29 13:51 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Annalisa, it works in the same way.
> Best
> 2017-06-29 12:43 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Hi all!
>> In our geonode 2.4 site I used geonode-project to customize logo, images
>> and little else.
>> For geonode 2.6, can I use it in the same way? Do you suggest to follow
>> these instructions: https://github.com/GeoNode/geonode-project (connect
>> to geonode/stable) ? It works in the same way?
>> Is there any up-to-date documentation?
>> Thanks
>> Annalisa
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170707/0947715e/attachment.html>
More information about the geonode-users
