[GeoNode-users] ACTIVITY Feed - Option
Naresh N naresh919 at gmail.com
Tue Jul 11 05:37:20 PDT 2017
Dear Simone,
Thanks for quick response
 I have commented the line 86 i.e. (r'^activity/',
include('actstream.urls')), then we are not able to see peoples profile
list. I want only activity feed should not be visible/accessible to the
users. Please suggest
Best Regards,
Naresh
On Tue, Jul 11, 2017 at 5:57 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, you could exclude the activity urls by commenting this line
> https://github.com/GeoNode/geonode/blob/master/geonode/urls.py#L86.
> 2017-07-11 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear All,
>>  Please any body can share how to disable activity stream option for all
>> the users.
>> With Best Regards,
>> Naresh
>> On Wed, Jun 28, 2017 at 9:24 AM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Fabiani,
>>>  Thanks for sharing the links, I will go through the links
>>> Best Regards,
>>> Naresh
>>> On Tue, Jun 27, 2017 at 8:41 PM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi,
>>>> recently I have rebuilt almost from scratch the source code of
>>>> GeoExplorer and aligned with live code in order to make it updatable.
>>>> You can find the GeoNode module here
>>>> https://github.com/GeoNode/django-geoexplorer
>>>> It actually depends on this one
>>>> https://github.com/geosolutions-it/geoexplorer/tree/geonode-geoexplorer
>>>> which, again, references other git submodules.
>>>> See instructions here
>>>> https://github.com/GeoNode/django-geoexplorer#geoexplorer-sources
>>>> also you need to download sources by uasing
>>>> git submodule sync
>>>> Regards,
>>>> Alessio Fabiani
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>>> mob:   +39 331 6233686 <+39%20331%20623%203686>
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility  for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> On Tue, Jun 27, 2017 at 2:40 PM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com> wrote:
>>>>> Geoexplorer is quite difficult to modify, and I don't know where you
>>>>> could do such change.
>>>>> Here's a very minimal documentation on how to make geoexplorer work in
>>>>> dev mode but then not sure how you can compile it back and deploy
>>>>> http://docs.geonode.org/en/master/tutorials/devel/dev
>>>>> el_debug/geoexplorer.html?highlight=geoexplorer
>>>>> 2017-06-27 14:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>  Yes as told functionality is working properly based on permissions
>>>>>> as geoserver handling the styling option. But if user is not having
>>>>>> permission if he does the style change,after that showing error message
>>>>>> like as follows, user time will waste it is better if we disable based on
>>>>>> previliges. How Edit option is implemented, kindly tell us where i need to
>>>>>> modify the functionality
>>>>>>     [image: Inline image 1]
>>>>>> Thanks&Regards,
>>>>>> Naresh
>>>>>> On Tue, Jun 27, 2017 at 5:51 PM, Simone Dalmasso <
>>>>>>> Not sure it's easily achievable as would require geoexplorer
>>>>>>> development. Although the permission should be respected by geoserver
>>>>>>> anyway,
>>>>>>> 2017-06-27 14:13 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone and all,
>>>>>>>>   One more query, please help me to do
>>>>>>>>  If user has option for visualizing the layer and not having style
>>>>>>>> option, then also Style icon is enabled mode in Map and Layer Window of
>>>>>>>> GeoNode interface. Can we grey out Style icon in case if user has not
>>>>>>>> having permission for add/edit style
>>>>>>>> *NOTE: This kind of enabling/disabling icon is happening for
>>>>>>>> Editing data icon. In following Edit is disable mode if user has not having
>>>>>>>> edit option. How ever for Style it is not happening*
>>>>>>>> *   [image: Inline image 1]*
>>>>>>>> How to enable/disable style icon based on user privileges for
>>>>>>>> styling the data
>>>>>>>> Best Regards,
>>>>>>>> Naresh
>>>>>>>> On Tue, Jun 27, 2017 at 4:38 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Thanks for the response, I will go through the shared link
>>>>>>>>> Best Regards,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 27, 2017 at 3:12 PM, Simone Dalmasso <
>>>>>>>>>> Hi, GeoNode does not ship this but you can develop it. This is
>>>>>>>>>> the app geonode is using to implement the activity stream.
>>>>>>>>>> https://github.com/justquick/django-activity-stream
>>>>>>>>>> 2017-06-27 11:35 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear All,
>>>>>>>>>>>    Is it possible Activity Feed of the People  should be visible
>>>>>>>>>>> to other users based on user settings?
>>>>>>>>>>>  I mean in following screenshot , I could able to see the
>>>>>>>>>>> activity of jamesboy.  But is it possible we can provide some option to
>>>>>>>>>>>  user to share his  Activity  Feed with other based on his choice. How to
>>>>>>>>>>> do it? Kindly help me to do.
>>>>>>>>>>> Thanks&Regards,
>>>>>>>>>>> Naresh
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0b89e13f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0b89e13f/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0b89e13f/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/0b89e13f/attachment-0005.png>
More information about the geonode-users mailing list
