[GeoNode-users] python manage.py Error
George Petrakis
gkpetrak at gmail.com
Tue Jul 11 08:59:58 PDT 2017
Hi Ariel,
Maybe this issue is related with your Django version. Which guide did you
follow to install GeoNode ?
George
2017-07-11 17:57 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
> Hi, I´m running GeoNode 2.6 in ubuntu server 16.04. I´m getting the
> following errors when running updatelayers:
> geonode at geonode:~/my_geonode$ python manage.py updatelayers
> Traceback (most recent call last):
> File "manage.py", line 11, in <module>
> execute_from_command_line(sys.argv)
> File "/home/geonode/.local/lib/python2.7/site-packages/
> django/core/management/__init__.py", line 363, in
> utility.execute()
> django/core/management/__init__.py", line 337, in execute
> django.setup()
> File "/home/geonode/.local/lib/python2.7/site-packages/django/__init__.py",
> line 22, in setup
> configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
> File "/home/geonode/.local/lib/python2.7/site-packages/django/utils/log.py",
> line 75, in configure_logging
> logging_config_func(logging_settings)
> File "/usr/lib/python2.7/logging/config.py", line 794, in dictConfig
> dictConfigClass(config).configure()
> File "/usr/lib/python2.7/logging/config.py", line 576, in configure
> '%r: %s' % (name, e))
> ValueError: Unable to configure handler 'null': Cannot resolve
> 'django.utils.log.NullHandler': No module named NullHandler
> I have connected geoserver w a Postgis database, and it worked fine when i
> had only those layers. Then I loaded new layers via GeoNode web, and the
> command stopped working.
> "Collectstatic" command is throwing the same error.
> I did not change LOGGING in settings.py. and did not override in
> local_settings.py
> I did changes according to this http://docs.geonode.org/
> en/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html.
> I´m not a programmer so please, take that in account on your suggestions
> or answers. Thanks!
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Πετράκης Γεώργιος
Τοπογράφος Μηχανικός, Msc
Τηλ: 2810-288363
Κιν: 6984871889
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170711/a6abad72/attachment.html>
More information about the geonode-users
