[GeoNode-users] python manage.py Error
George Petrakis
gkpetrak at gmail.com
Wed Jul 12 13:56:39 PDT 2017
I'm still using geonode 2.4 in Ubuntu 16.04 and my django's version is
1.6.11. In geonode 2.6, django's version should be 1.8.7 according to this
file: https://github.com/GeoNode/geonode/blob/2.6.x/requirements.txt#L1
George
2017-07-12 17:06 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
> Thanks George, I saw that before, but since i´m not a programmer and not
> using the same version as the linked issue, i´m afraid to screw it up worse.
> But i bleieve it´s related to django version, as you said.
> Is GeoNode 2.6 using DJango 1.11.3? I want to make sure i didn´t change
> version.
> Thanks!
> 2017-07-12 6:04 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
>> Check this conversation. It could help. https://github.com/translate/p
>> ootle/issues/4537
>> George
>> 2017-07-11 20:21 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>>> I followed the quick install: http://docs.geonode.o
>>> rg/en/master/tutorials/install_and_admin/quick_install.html
>>> I also tried to install "django-debug-toolbar" according to this link:
>>> link: https://geonode.readthedocs.io/en/2.0/tutorials/admin/
>>> debugging.html
>>> but since it was throwing an internal server error, I removed the
>>> changes done in local_settings.py back to original. Maybe that was a bad
>>> move.
>>> Django version 1.11.3 (checked w print(django.get_version())
>>> 2017-07-11 12:59 GMT-03:00 George Petrakis <gkpetrak at gmail.com>:
>>>> Hi Ariel,
>>>> Maybe this issue is related with your Django version. Which guide did
>>>> you follow to install GeoNode ?
>>>> George
>>>> 2017-07-11 17:57 GMT+03:00 Ariel Neri <ariel.neriw at gmail.com>:
>>>>> Hi, I´m running GeoNode 2.6 in ubuntu server 16.04. I´m getting the
>>>>> following errors when running updatelayers:
>>>>> geonode at geonode:~/my_geonode$ python manage.py updatelayers
>>>>> Traceback (most recent call last):
>>>>> File "manage.py", line 11, in <module>
>>>>> execute_from_command_line(sys.argv)
>>>>> File "/home/geonode/.local/lib/python2.7/site-packages/django/core/management/__init__.py",
>>>>> line 363, in execute_from_command_line
>>>>> utility.execute()
>>>>> line 337, in execute
>>>>> django.setup()
>>>>> File "/home/geonode/.local/lib/python2.7/site-packages/django/__init__.py",
>>>>> line 22, in setup
>>>>> configure_logging(settings.LOGGING_CONFIG, settings.LOGGING)
>>>>> File "/home/geonode/.local/lib/python2.7/site-packages/django/utils/log.py",
>>>>> line 75, in configure_logging
>>>>> logging_config_func(logging_settings)
>>>>> File "/usr/lib/python2.7/logging/config.py", line 794, in dictConfig
>>>>> dictConfigClass(config).configure()
>>>>> File "/usr/lib/python2.7/logging/config.py", line 576, in configure
>>>>> '%r: %s' % (name, e))
>>>>> ValueError: Unable to configure handler 'null': Cannot resolve
>>>>> 'django.utils.log.NullHandler': No module named NullHandler
>>>>> I have connected geoserver w a Postgis database, and it worked fine
>>>>> when i had only those layers. Then I loaded new layers via GeoNode web, and
>>>>> the command stopped working.
>>>>> "Collectstatic" command is throwing the same error.
>>>>> I did not change LOGGING in settings.py. and did not override in
>>>>> local_settings.py
>>>>> I did changes according to this http://docs.geonode.org/e
>>>>> n/master/tutorials/admin/customize_lookfeel/customize/setup_admin.html
>>>>> I´m not a programmer so please, take that in account on your
>>>>> suggestions or answers. Thanks!
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Πετράκης Γεώργιος
>>>> Τοπογράφος Μηχανικός, Msc
>>>> Τηλ: 2810-288363
>>>> Κιν: 6984871889
>> Πετράκης Γεώργιος
>> Τηλ: 2810-288363
>> Κιν: 6984871889
Πετράκης Γεώργιος
Τηλ: 2810-288363
Κιν: 6984871889
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170712/0bdcf7f2/attachment.html>
More information about the geonode-users
