[GeoNode-users] Fwd: geonode-users Digest, Vol 30, Issue 49
Toni Schönbuchner toni.schoenbuchner at csgis.de
Wed Jul 12 22:50:15 PDT 2017
Hi Naresh,
from a quick look it´s the same angular controller for both api requests.
Means all use the same max var. If you like to have the amount different
on peoples page only you could give a try to override
this variable in the peoples template. From naming I think it should be
profile_list.html
here I would try to add a new var after line 28
https://github.com/GeoNode/geonode/blob/master/geonode/people/templates/people/profile_list.html#L28 <https://github.com/GeoNode/geonode/blob/master/geonode/people/templates/people/profile_list.html#L28>
<script type="text/javascript">
   CLIENT_RESULTS_LIMIT = 10;
</script>
If this works you could create a override of this file and move the var
to your local_settings to keep things tidy.
Another way is to modify the angular search script to respect a second var.
it should be this file:  https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/search/search.js <https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/search/search.js>
best,
toni
CSGIS
Kolonnadenstraße 1
04109 Leipzig
Mobil	+49/ (0) 176 6680 3198
Tel 		+49/ (0) 341 24 04 738
Fax 		+49/ (0) 341 24 04 73
Web		http://csgis.de
> Anfang der weitergeleiteten Nachricht:
> Von: geonode-users-request at lists.osgeo.org
> Betreff: geonode-users Digest, Vol 30, Issue 49
> Datum: 13. Juli 2017 um 06:32:10 MESZ
> An: geonode-users at lists.osgeo.org
> Antwort an: geonode-users at lists.osgeo.org
>> Dear Simone,
>>     After removing the line  also ,the user list is not available, it is
>> showing empty.
>>     I have reverted the changes i.e commenting the line in url.py and
>> profile_details.html  and done changes like as follows in the
>> C:\GeoNode-2.4.x\geonode-2.4.x\geonode\templates\actstream\actor.html ,
>> now it is working fine
>> *{% if user.is <http://user.is/>_superuser or request.user == actor %} *after line number 24
>> It may not be professional way to do, I did not get any other option, so
>> with the following now it is working fine.
>> Once again thanks for the support.
>> *Kindly help me in following new issue*
>> How to limit the no of results showing to max 10 only , as of now default
>> limit is 100.
>> I mean in following url limit is 100
>> http://192.168.197.108/people/?limit=100&offset=0 <http://192.168.197.108/people/?limit=100&offset=0>
>> To do the change the limit value in settings.py  i have
>> modified CLIENT_RESULTS_LIMIT =10   and    max_limit=10 in the file
>> GeoNode-2.4.x\geonode-2.4.x\geonode\api\resourcebase_api.py
>> After doing above changes layers,maps,documents is working as per the new
>> updated limit value 10,.
>> However people,groups url showing like http://192.168.197.108/people/ <http://192.168.197.108/people/>
>> ?limit=10&offset=0,http://192.168.197.108/groups/?limit=10&offset=0 <http://192.168.197.108/groups/?limit=10&offset=0>, but
>> if you change the limit value in url more than 10,
>> it is displaying the result more than 10(as per given limit value)
>> Please kindly suggest me how to enable  new limit value to People, Groups
>> list also
>> Best Regards,
>> Naresh
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b6b65b2b/attachment.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170713/b6b65b2b/attachment.sig>
More information about the geonode-users mailing list
