[GeoNode-users] error opening map
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Jul 19 01:15:32 PDT 2017
Most likely the communication between GeoNode and GeoServer is not working
correctly due to some misconfiguration.
Try to go to the geoserver home page and log in through GeoNode. By the
way, which version? How is your setup?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Wed, Jul 19, 2017 at 10:06 AM, trocellier estelle <
trocellier.estelle at gmail.com> wrote:
> Dear all
> I'm working on geonode 2.6 on a windows server.
> I've created some map with layer from geoserver connecting to a data base
> of postgis 9.5 (i didn't use the initial postgis 8.4 because it was to old
> to make my backup...)
> My problem is at the first time when i try to open the map i have this
> message (go to see the attachment). But when i try to open it a second time
> it's work but then i have a seconde message : [image: Images intégrées 1]
> It seems that the problem come from the connection between geonode and
> geoserver.
> What do you think ?
> And that should i do ? Can you explain in details please.
> Thank you a lot
> Regards
> Estelle
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/adcc1e84/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/adcc1e84/attachment-0001.png>
More information about the geonode-users
