[GeoNode-users] Permissions issue
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Jul 19 01:36:40 PDT 2017
Hello Francesco,
can you send somesnapshots of both Layer Permissions and GeoFence Data
Rules created for that Layer?
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Jul 18, 2017 at 7:33 PM, Fosco Ventura <foscone at gmail.com> wrote:
> Dear all,
> Maybe I have the same problem of Annalisa.
> I need to create 3 users with differents permission (Viewer, Editor and
> Admin)
> I have assigned the permissions of all my layers accordingly to these
> profiles, but, there is an issue, maybe in Geofence.
> In this example, I supposed to be able to see the preview
> [image: Immagine incorporata 1]
> I have run " manage.py fixgeofencerules" as suggested (
> https://github.com/GFDRR/geonode-risk-tools/commit/a987f14d
> 12c180ea526ef4350609421a4fa5c67b)
> but this operation does not solved this problem.
> Someone could suggest a solution please?
> Thanks a lot.
> Fosco
> Fosco
> http://studiotypo.it/
> http://www.studiotypo.it/fosco/
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/e4be6070/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/e4be6070/attachment-0001.png>
More information about the geonode-users
