[GeoNode-users] Again on authentication - geofence
Annalisa Schiavon
annalisa.schiavon at gmail.com
Wed Jul 19 04:53:50 PDT 2017
Ok, thanks.
I started to save again the permissions for few layers and I see that rules
are added to GeoFence Data Rules only if I set Active role service of
Security Setting to default.
It may be due to my issue with admin user? In geoserver log I get always
this warning:
WARN [geofence.cache] -
org.geoserver.geofence.cache.CachedRuleReader$NoAuthException: Can't auth
user [admin]
2017-07-19 10:42 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Mmm I see,
> this command "fixgeofencerules" is available only on master branch.
> In this case is not so straight forward to fix this for all the layers.
> You have two options:
> 1. For each Layer you need to click on "Permissions" and save again.
> Double check that rules are added to GeoFence Data Rules. If more than one
> Layer have same permissions, you can also do a bulk update from the Layers
> List page
> 2. Backport that command from master branch and try to execute it again.
> You just need to create this file on the same position
> https://github.com/GeoNode/geonode/tree/master/geonode/
> base/management/commands
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, Jul 18, 2017 at 1:00 PM, Annalisa Schiavon <
> annalisa.schiavon at gmail.com> wrote:
>> Hi Alessio and geonode users,
>> I still have some issue with geofence.
>> I have tried the command you suggest
>> system at bender:~$ geonode fixgeofencerules
>> Unknown command: 'fixgeofencerules'
>> Type 'django-admin help' for usage.
>> with no success.
>> I should execute from a specific dir?
>> I have installed geonode 2.6.1 from apt-get, in standard mode. In
>> geofence Admin Page, the connection is successful, but down in the page I
>> found user cache misses :
>> [image: Immagine incorporata 2]
>> Is there documentation on how setting geofence integrated in geonode?
>> Any suggestions?
>> Please help!
>> 2017-07-11 13:14 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> You can try to use the following management command, it should help you
>>> to align permissions and geofence rules
>>> python manage.py fixgeofencerules
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Tue, Jul 11, 2017 at 1:44 PM, Annalisa Schiavon <
>>>> Hi all.
>>>> I've still the problem of layer's thumbs not displayed.
>>>> But more important, if I don't login in geonode with geonode user, I
>>>> can't see most of layers with permission to all users!
>>>> Even stranger, if I log in with geonode and than log out, I can see
>>>> them.
>>>> I checked all steps of http://docs.geonode.org/en
>>>> /master/tutorials/admin/geoserver_geonode_security/index.html
>>>> <http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=oauth2>
>>>> but I don't have generated new OAuth2 UserID and Secret key. How do you do
>>>> it?
>>>> I've noticed that under GeoFence Data Rules I've only few rules:
>>>> [image: Immagine incorporata 1]
>>>> I've checked permissions and saved only for a layer, and that is
>>>> displayed without problems from anonymous user.
>>>> I've to reapply permissions for all my 110 layers??? Is it this the
>>>> problem, for you?
>>>> I attach tomcat and apache logs.
>>>> Thanks,
>>>> Annalisa
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/3752d855/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/3752d855/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170719/3752d855/attachment-0003.png>
More information about the geonode-users
