[GeoNode-users] Issue with admin authentication
Annalisa Schiavon
annalisa.schiavon at gmail.com
Tue Jul 25 02:24:42 PDT 2017
Here my test using CURL:
~$ curl -X GET http://192.168.31.80/api/roles
{"groups": ["anonymous", "Authenticated-GeoNode-Users", "ARPAV", "admin"]}
~$ curl -X GET http://192.168.31.80/api/users
{"users": [{"username": "AnonymousUser", "groups": ["anonymous"]},
{"username": "esar", "groups": ["anonymous", "ARPAV",
"Authenticated-GeoNode-Users"]}, {"username": "OssAria", "groups":
["anonymous", "Authenticated-GeoNode-Users", "ARPAV"]}, {"username":
"suoli", "groups": ["anonymous", "Authenticated-GeoNode-Users", "ARPAV"]},
{"username": "rifiuti", "groups": ["anonymous",
"Authenticated-GeoNode-Users", "ARPAV"]}, {"username": "dapvr", "groups":
"nirweb", "groups": ["anonymous", "Authenticated-GeoNode-Users", "ARPAV"]},
{"username": "CFD_Idrologico", "groups": ["anonymous",
"Authenticated-GeoNode-Users", "ARPAV"]}, {"username": "sirav", "groups":
"soaf", "groups": ["anonymous", "Authenticated-GeoNode-Users", "ARPAV"]},
{"username": "sier", "groups": ["anonymous", "Authenticated-GeoNode-Users",
"ARPAV"]}, {"username": "OssAA", "groups": ["anonymous",
"Authenticated-GeoNode-Users", "ARPAV"]}, {"username": "acqueInterne",
{"username": "geonode", "groups": ["anonymous",
"Authenticated-GeoNode-Users", "ARPAV", "admin"]}]}
$ curl -X GET http://192.168.31.80/api/users/admin
{"users": []}
It's strange that it finds all users, also geonode of admin group, but not
users/admin, don't it?
My geoserver configuration says:
JVM Version Oracle Corporation: 1.8.0_131 (OpenJDK 64-Bit Server VM)
During installation of GeoNode (30/5), I launched these commands:
~$ sudo apt-get update
~$ sudo apt-get upgrade
~$ sudo add-apt-repository ppa:geonode/stable
~$ sudo apt-get install geonode
~$ sudo geonode-updateip 192.168.31.80
.... raise GeoNodeException('You must have an admin account configured '
geonode.GeoNodeException: You must have an admin account configured before
importing data. Try: django-admin.py createsuperuser
~$ geonode createsuperuser
Username: geonode
Email address: geonode at arpa.veneto.it
Password:
Password (again):
Superuser created successfully.
On 5/7 I make an upgrade :
...Get:2 http://ppa.launchpad.net/geonode/stable/ubuntu xenial/main amd64
geonode all 2.6.1+thefinal0 [4,787 kB]
Setting up geonode (2.6.1+thefinal0) ...
Sourcing /usr/share/geonode/config-post.sh as the configuration file
Step: 'post specified
Running GeoNode postinstall ...
Operations to perform:
Apply all migrations: account
Running migrations:
No migrations to apply.
Your models have changes that are not yet reflected in a migration, and
so won't be applied.
Run 'manage.py makemigrations' to make new migrations, and then re-run
'manage.py migrate' to apply them.
...and than installed 2.6.1 ver.
Than installed geonode-project:
~$ django-admin startproject geoportale26 --template=
https://github.com/GeoNode/geonode-project/archive/2.6.zip -epy,rst
~$ sudo pip install -e geoportale26
You advice an upgrade of geonode? Or there is other I can check?
Thanks
2017-07-24 14:32 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Hello Annalisa,
> it looks like your GeoNode instance is not enabled to provide users' roles
> via REST service.
> I'm afraid your installation has something wrong, especially with the
> versions numbers.
> In order to make a quick test using CURL:
> 1) curl -X GET http://192.168.31.80/api/roles
> you should receive the list of available groups on GeoNode
> 2) curl -X GET http://192.168.31.80/api/users
> you should receive the list of available users on GeoNode
> 3) curl -X GET http://192.168.31.80/api/users/admin
> you should receive the list of available groups for admin user
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Mon, Jul 24, 2017 at 1:33 PM, Annalisa Schiavon <
> annalisa.schiavon at gmail.com> wrote:
>> I changed those values without success.
>> I can login with geonode user with admin permissions in geonode and also
>> in geoserver, even if sometimes it fails. But also when geonode login fails
>> in geoserver, waiting for a while, then I can access. I don't know why.
>> Even without restart tomcat or apache.
>> But, for example, if I try to load a new layer I receive again this error:
>> Tried to make a GET request to http://localhost:8080/geoserve
>> r/rest/workspaces/default.xml but got a 404 status code: No such
>> workspace: default
>> I have some WARNING and ERRORS in the logs, like:
>> org.geoserver.security.GeoServerRestRoleService$1 executeWithContext
>> WARNING: null
>> com.jayway.jsonpath.PathNotFoundException: No results for path:
>> $['users'][0]['groups']
>> ERROR [geoserver.rest] - No such workspace: default
>> 24 Jul 13:06:12 ERROR [geoserver.rest] -
>> org.geoserver.rest.RestletException
>> at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(Worksp
>> aceFinder.java:41)
>> (my default workspace is named geonode ...)
>> If you want, I may attach full log.
>> For layers and maps already upload there are no problems, it seems.
>> Thanks
>> 2017-07-20 11:19 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> You need to change those values:
>>> 1. GeoNode REST Role Service to -> <baseUrl>http://192.168.31.80
>>> </baseUrl>
>>> 2. Authentication filters, geonode-oauth2:
>>> Access Token URI to -> http://192.168.31.80/o/token/
>>> Check Token Endpoint URL to -> http://192.168.31.80/api/o/
>>> v4/tokeninfo/
>>> Scopes to -> write
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Wed, Jul 19, 2017 at 3:25 PM, Annalisa Schiavon <
>>>> I can enter in GeoNode REST Role Service. <baseUrl> was my ip:
>>>> <baseUrl>http:// <http://localhost/>192.168.31.80</baseUrl>
>>>> Now I set it to localhost. This is my screenshot:
>>>> [image: Immagine incorporata 1]
>>>> In Authentication filters, geonode-oauth2 is setted as below:
>>>> [image: Immagine incorporata 2]
>>>> what I wrong?
>>>> ClientID and Client Secret are equal to those in Geonode Admin
>>>> Thanks
>>>> 2017-07-19 13:56 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> In that case it might be a misconfiguration of the "GeoNode REST Role
>>>>> Service". Most likely if you try to enter it you will receive an error.
>>>>> You need to double check manually the file inside the
>>>>> GEOSERVER_DATA_DIR:
>>>>> $GEOSERVER_DATA_DIR/security/role/geonode\ REST\ role\ servi
>>>>> ce/config.xml
>>>>> and make sure this parameter points correctly to the base URL of your
>>>>> GeoNode instance
>>>>> <baseUrl>http://localhost</baseUrl>
>>>>> Regards,
>>>>> Alessio Fabiani
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Wed, Jul 19, 2017 at 1:41 PM, Annalisa Schiavon <
>>>>>> I didn't delete the "admin" user in geonode, but ... there is a
>>>>>> default admin user in geonode? My superuser created with
>>>>>> is named "geonode".
>>>>>> I migrated a geonode 2.4 db (than execute $ geonode migrate
>>>>>> --fake-initial); maybe I lost the admin user?
>>>>>> Among geonode users I have geonode, AnonymousUser and than my users
>>>>>> created in 2.4.
>>>>>> In Geoserver, I've changed the default password of admin user and
>>>>>> stop.
>>>>>> 2017-07-19 11:42 GMT+02:00 Alessio Fabiani <
>>>>>>> Did you deleted the "admin" user from GeoNode? Or removed
>>>>>>> privileged status? If yes it is normal, otherwise not.
>>>>>>> Regards,
>>>>>>> Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> On Thu, Jul 13, 2017 at 9:29 AM, Annalisa Schiavon <
>>>>>>>> I don't want to create a different admin user of Geoserver. But
>>>>>>>> "admin" user (the default of Geoserver) is an Administrator if I set in
>>>>>>>> Security settings, "Active role service" = "default". If I set "Active role
>>>>>>>> service" = "geonode REST role service", the "admin" user is no longer an
>>>>>>>> administrator but a common user with no permission.
>>>>>>>> This is my edit user page of admin user, when I set geonode REST
>>>>>>>> role service:
>>>>>>>> Is it normal? It's ok?
>>>>>>>> Thanks
>>>>>>>> Annalisa
>>>>>>>> 2017-07-13 8:25 GMT+02:00 Alessio Fabiani <
>>>>>>>>> As stated in the documentation, GeoServer still has its own
>>>>>>>>> internal users.
>>>>>>>>> If you want to create an admin different from the default one in
>>>>>>>>> GeoServer also which works with basic auth also, you need to create a
>>>>>>>>> GeoServer internal user too.
>>>>>>>>> Regards,
>>>>>>>>> Alessio Fabiani
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> Italy
>>>>>>>>> On Wed, Jul 12, 2017 at 2:09 PM, Annalisa Schiavon <
>>>>>>>>>> I add that if I run this command:
>>>>>>>>>> $ curl http://localhost/api/users/admin
>>>>>>>>>> I get:
>>>>>>>>>> {"users": []}
>>>>>>>>>> The other cmd:
>>>>>>>>>> curl http://localhost/api/adminRole
>>>>>>>>>> curl http://localhost/api/roles
>>>>>>>>>> are ok.
>>>>>>>>>> I attach the last lines of geoserver.log
>>>>>>>>>> I've migrated from geonode 2.4 to geonode 2.6.
>>>>>>>>>> I've changed the geoserver data dir coping the original 2.9 and
>>>>>>>>>> than replacing these directories from my geoserver 2.7:
>>>>>>>>>> - data
>>>>>>>>>> - layergroups
>>>>>>>>>> - legendsamples
>>>>>>>>>> - styles
>>>>>>>>>> - workspace
>>>>>>>>>> Thanks for any reply
>>>>>>>>>> Annalisa
>>>>>>>>>> 2017-07-12 12:48 GMT+02:00 Annalisa Schiavon <
>>>>>>>>>> annalisa.schiavon at gmail.com>:
>>>>>>>>>>> Hi all.
>>>>>>>>>>> I've followed this doc because I had some problems with
>>>>>>>>>>> permissions on layers: http://docs.geonode.org/en/mas
>>>>>>>>>>> ter/tutorials/admin/geoserver_geonode_security/index.html .
>>>>>>>>>>> My geonode superuser is "*geonode*", so I access Geoserver with
>>>>>>>>>>> geonode and setted geonode REST role service as Active role
>>>>>>>>>>> service in Security settings.
>>>>>>>>>>> After doing this, I can no more login in Geoserver with *admin*
>>>>>>>>>>> user.
>>>>>>>>>>> Unfortunately, I made a "updatelayer" with --remove-deleted
>>>>>>>>>>> option and this deleted all my layers from geonode. In geoserver there are
>>>>>>>>>>> all layers.
>>>>>>>>>>> I try to change back Security settings and set it to "default".
>>>>>>>>>>> Now if I make an updatelayers, geonode recreate my layers (but I have to
>>>>>>>>>>> restore my old backups because I lost all metadata and link with the maps).
>>>>>>>>>>> I hope that after restoring geonode DB and doing "geonode
>>>>>>>>>>> migrate --fake-initial" I'll return to my situation of yesterday.
>>>>>>>>>>> But how should I set Security settings?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Annalisa
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170725/e5a38f8c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170725/e5a38f8c/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170725/e5a38f8c/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170725/e5a38f8c/attachment-0005.png>
More information about the geonode-users
