[GeoNode-users] Printing Issue - GeoNode
Naresh N naresh919 at gmail.com
Thu Jun 1 02:26:06 PDT 2017
Dear GeoNode Users,
 I have deployed GeNode in RHEL 7.2 64 bit machine.  In Layer/Map viewer
Print icons was in disabled mode.Then to over come this issue,Print-plugin
is installed and configured using instructions in given in following link
http://suite.opengeo.org/docs/latest/geoserver/extensions/printing/index.html#installation..
Now Print icon is enable mode and Print Window is appearing with the
layers, how ever when I select the Print icon from Print Window it is
showing  following error
[image: Inline image 2]
With the fire bug , it is getting following *response*
Error while generating PDF:
org.mapfish.print.InvalidValueException: url has an invalid value:
http://geoserver.org/img/geoserver-logo.png
at org.mapfish.print.PDFUtils.createImage(PDFUtils.java:668)
at org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:656)
at org.mapfish.print.PDFUtils.createImageChunk(PDFUtils.java:653)
at org.mapfish.print.config.layout.ImageBlock.render(ImageBlock.java:66)
at org.mapfish.print.PDFUtils.createCell(PDFUtils.java:624)
at org.mapfish.print.PDFUtils.buildTable(PDFUtils.java:609)
at org.mapfish.print.config.layout.ColumnsBlock.render(ColumnsBlock.java:72)
at org.mapfish.print.config.layout.HeaderFooter.render(HeaderFooter.java:55)
at org.mapfish.print.PDFCustomBlocks.addFooter(PDFCustomBlocks.java:134)
at org.mapfish.print.PDFCustomBlocks.onEndPage(PDFCustomBlocks.java:89)
at com.itextpdf.text.pdf.PdfDocument.newPage(PdfDocument.java:911)
at com.itextpdf.text.Document.newPage(Document.java:363)
at org.mapfish.print.config.layout.Page.render(Page.java:63)
at org.mapfish.print.config.layout.MainPage.render(MainPage.java:63)
at org.mapfish.print.config.layout.Layout.render(Layout.java:59)
at
org.mapfish.print.output.AbstractOutputFormat.doPrint(AbstractOutputFormat.java:30)
at org.mapfish.print.output.PdfOutputFactory.print(PdfOutputFactory.java:58)
at org.mapfish.print.MapPrinter.print(MapPrinter.java:173)
at
org.mapfish.print.servlet.MapPrinterServlet.doCreatePDFFile(MapPrinterServlet.java:366)
at
org.mapfish.print.servlet.MapPrinterServlet.createPDF(MapPrinterServlet.java:184)
at
org.mapfish.print.servlet.MapPrinterServlet.doPost(MapPrinterServlet.java:112)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at
org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:159)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at
at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at
at
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at
at
at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at
at
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
at
at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
at
at
at
at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at
at
at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
at
at
at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:83)
at
at
at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at
at
at
at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:135)
at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
at
at
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:83)
at
at
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at
at
at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at
at
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at
at
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122)
at
org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:505)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:956)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:436)
at
org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1078)
at
org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:625)
at
org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at
org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: Connection refused (Connection refused)
at org.mapfish.print.PDFUtils.handleImageLoadError(PDFUtils.java:357)
at org.mapfish.print.PDFUtils.loadImageFromUrl(PDFUtils.java:341)
at org.mapfish.print.PDFUtils.getImageDirect(PDFUtils.java:182)
at org.mapfish.print.PDFUtils.getImage(PDFUtils.java:102)
at org.mapfish.print.PDFUtils.createImage(PDFUtils.java:666)
... 112 more
Please help me to overcome this issue?.
Note:for reference attached my config.yaml file with this mail
Thanks&Regards,
Naresh
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170601/265b347d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170601/265b347d/attachment-0001.png>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170601/265b347d/attachment-0001.obj>
More information about the geonode-users mailing list
