[GeoNode-users] Installation Problems with version 2.6 on Ubuntu 16.04
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Jun 9 00:17:24 PDT 2017
Hi, yes definitely geoserver needs to be there and the package should
install it. Make sure your machine is powerful enough, also during the
installation you should have gotten some errors.
2017-06-08 18:22 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com>:
> PS: and I am unable to authenticate via the geonode website.
> On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <cliffpatterson at gmail.com
> > wrote:
>> Hello,
>> I decided to give Geonode 2.6 a go and installed it on a fresh VM running
>> Ubuntu 16.04.2 x64. I installed it with the following commands:
>> sudo add-apt-repository ppa:geonode/stable
>> sudo apt-get update
>> sudo apt-get install geonode
>> geonode createsuperuser
>> sudo geonode-updateip 67.207.87.119
>> When creating the super user, I get the following warning:
>> System check identified some issues:
>> WARNINGS:
>> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in
>> Django 1.8 and the TEMPLATES dictionary takes precedence. You must put the
>> values of the following settings into your default TEMPLATES dict:
>> TEMPLATE_DIRS.
>> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>> ManyToManyField.
>> Username: test
>> Email address:
>> Password:
>> Password (again):
>> Superuser created successfully.
>> When running sudo geonode-updateip 67.207.87.119, the following happens:
>> 1) Hangs on "Inspecting the available layers in GeoServer ..."
>> 2) Geonode does get up and running at 67.207.87.119 but no ability to
>> login
>> Replacing SITEURL value with '67.207.87.119' in
>> /etc/geonode/local_settings.py ... done.
>> Adding entry for '67.207.87.119' in /usr/share/geoserver/data/printing/config.yaml
>> ... done.
>> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ... done.
>> Setting up oauth
>> Am I missing something in the instructions? Do we need to install
>> Geoserver on Tomcat7 first, then Geonode? As far as I can see, Geoserver
>> has not been installed, which I thought was part of the geonode
>> installation, but I could be wrong.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/31181637/attachment.html>
More information about the geonode-users
