[GeoNode-users] Layer Editing Error
Naresh N naresh919 at gmail.com
Fri Jun 9 06:55:54 PDT 2017
Dear ALL,
 Although all the functionalities of GeoNode working except permissions of
Layers. Please kindly help me to resolve the issue.
1. Layers Uploaded with  Username: XXXXX  with password:XXXX and permission
for visualize is given to specific user. But with layer name and layer url
with out credentials layer is loading.
 Please help me how to over come the issue. As I mentioned in my earlier
mail I am configured GeoNode2.4.x  in RHEL 7.2 64 bit machine.
 Since I could not able find geoserver.war file in geonode2.4.zip file ,I
have  downloaded  Geoserver2.7.4 war from Geoserver official site and
followed the rest of the steps.
 Thanks,
Naresh
On Fri, Jun 9, 2017 at 2:21 PM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Bartoli,Simone,
>  Thanks for the helping. Downloaded Geosever2.7.4 war from Geoserver
> official site and replaced  with Geoserver2.11.1, the layer editing
> functionality is worked. Now i understand that basically issue is with
> Geoserver version . Now I am checking all other functionalities, hoping  I
> will not get any unexpected error/behaviour.
> Thanks again........
> Thanks,
> Naresh
> On Fri, Jun 9, 2017 at 1:12 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> Naresh,
>> the same command suggested by Simone should download the correct
>> GeoServer version which relies on the old authentication system.
>> Francesco
>> Il giorno 09/giu/2017, alle ore 09:39, Naresh N <naresh919 at gmail.com> ha
>> scritto:
>> Dear Simone,
>> I have deployed GeoNode 2.4 version. I think there is no concept of oauth
>> in GeoNode 2.4 version.I am facing the issue with GeoNode 2.4. Please
>> suggest how to overcome the issue in GeoNode2.4 version
>> Thanks,
>> Naresh
>> On Fri, Jun 9, 2017 at 12:57 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Running "paver setup" in your geonode virtualenv will download it into
>>> the "downloaded folder" Then you will have to configure the oauth2
>>> mechanism http://docs.geonode.org/en/master/tutorials/admin/
>>> geoserver_geonode_security/index.html#geonode-and-geoserver-
>>> a-a-interaction
>>> 2017-06-09 9:19 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>>  Thanks for the response.
>>>>  But I have configured GeoNode2.4 in my RHEL machine. In downloaded
>>>> GeoNode Zip Geoserver.war file is not available. How to get shipped
>>>> geoserver.war file in case of GeoNode deployment in Linux.
>>>> Thanks,
>>>> Naresh
>>>> On Fri, Jun 9, 2017 at 12:44 PM, Simone Dalmasso <
>>>>> Hi,
>>>>> GeoNode requires it's own Geoserver. It is shipped with it and is
>>>>> version 2.9. Security and permissions won't work otherwise.
>>>>> 2017-06-09 8:58 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear ALL,
>>>>>> When I am editing the layer it is showing following error. Please
>>>>>> suggest to fix
>>>>>> <ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema"
>>>>>> xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2
>>>>>> 001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="
>>>>>> http://www.opengis.net/ows http://192.168.198.209/geoserv
>>>>>> er/schemas/ows/1.0.0/owsExceptionReport.xsd">
>>>>>>   <ows:Exception exceptionCode="NoApplicableCode">
>>>>>>     <ows:ExceptionText>{http://192.168.198.209/geoserver/cite}_6
>>>>>> _9_2017_9657073 is read-only</ows:ExceptionText>
>>>>>>   </ows:Exception>
>>>>>> </ows:ExceptionReport>
>>>>>> System Details : Geo Node is configured in RHEL7.2 64 bit machine
>>>>>>                          Geoserver version 2.11.1
>>>>>>                             jre version is 1.8
>>>>>> * Note:  If login the geoserver with admin credential in another tab
>>>>>> and layer editing functionality is working*
>>>>>> *Please kindly suggest any layer security settings need to update in
>>>>>> Geoserver2.11.1*
>>>>>> *Thanks,*
>>>>>> *Naresh*
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/9d8f6486/attachment-0001.html>
More information about the geonode-users mailing list
