[GeoNode-users] Fwd: can't log into geoverser with the "geonode button"
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Jun 9 07:30:19 PDT 2017
Hi Elisa,
please try to follow instructions here
https://docs.google.com/document/d/1g_sD8NCzKRflkrbXZp0gqHmELG_B9hz8xCqKHaK-_O8/edit#bookmark=id.kb51dm9cqdlk
most probably your oauth2 configuration on GeoServer still refers to the
local address.
Please, notice that the instructions are for Windows setup, but with some
minor differences can be applied to ubuntu setup also.
Best Regards,
Alessio Fabiani.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313 <0584%20962313>
fax:     +39 0584 1660272 <0584%20166%200272>
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Fri, Jun 9, 2017 at 4:19 PM, Elisa Pruvot <pruvotelisa at gmail.com> wrote:
> Thanks a lot for your quick and clear answer Alessio.
> I did exactly what you wrote (indeed the geoserver proxy base url was not
> up to date), but it still doesn't work.
> Maybe it takes a little time to update ? I even restarted my computer just
> in case.
> But I still get the same error message and the same url :
> http://192.168.1.23/o/authorize/?response_type=code&client_
> id=ue4aJt4AXIlXiiCs32OIVeMFNrQcGHsYRJgxj2Kn&scope=write&
> *redirect_uri=http://127.0.0.1/geoserver/ <http://127.0.0.1/geoserver/>*
> 2017-06-09 15:15 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
> .it>:
>> Hi,
>> you need to add the new GeoServer URL on allowed Redirect URIs from
>> GeoNode Admin Dashboard
>> [image: Inline image 1]
>> [image: Inline image 2]
>> [image: Inline image 3]
>> And Save.
>> Also, *make sure* GeoServer Proxy Base URL has been set to* http://192.168.1.23/geoserver
>> <http://192.168.1.23/geoserver>*
>> *[image: Inline image 6]*
>> *[image: Inline image 5]*
>> And Save again.
>> Best Regards,
>> Alessio Fabiani.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> @alfa7691
>> GeoSolutions S.A.S.
>> Italy
>> http://twitter.com/geosolutions_it
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti,
>> copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento
>> contrario ai principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Fri, Jun 9, 2017 at 3:05 PM, Elisa Pruvot <pruvotelisa at gmail.com>
>> wrote:
>>> Hi all !
>>> Running GeoNode 2.6 installed with ppa on ubuntu 16.04.
>>> I got a new little problem i'd like to share..
>>> So far I had no problem to log into GeoServer with the "geonode button"
>>> on the left of the username and password fields.
>>> But now that i've updated the ip (-> "sudo geonode-updateip
>>> 192.168.1.23" to access geonode with others computers) it doesn't work
>>> anymore.
>>> This is the error I get when i click on the "geonode button" to log in:
>>> Error : invalid_request
>>> Mismatching redirect URI
>>> and the url field is :
>>> ​http://192.168.1.23/o/authorize/?response_type=code&client_
>>> id=ue4aJt4AXIlXiiCs32OIVeMFNrQcGHsYRJgxj2Kn&scope=write&redi
>>> here is my local_settings file in case
>>> I can still log into GeoServer the "old" way, but i'm logged as "admin"
>>> and not with my geonode username, like it did when logging in with that new
>>> geonode button.
>>> Does anyone know what should i do to log into GeoServer with that button
>>> Thanks,
>>> Elisa
>>> Elisa Pruvot
>>> M2 SIGAT
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Elisa Pruvot
> M2 SIGAT
> Elisa Pruvot
> M2 SIGAT
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170609/c939764e/attachment-0009.png>
More information about the geonode-users mailing list
