[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N
naresh919 at gmail.com
Thu Jun 15 01:59:31 PDT 2017
Dear Simone,
Thanks. I will try with the provided url.
Thanks,
Naresh
On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> You can try with http://demo.geonode.org/geoserver/wms. Not sure about
> our other question, don't think is possible in the standard code.
> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>> Thanks for the replies. Is any other External WMS Layer url is
>> available ,please share me to test. Is that any mechanism is available in
>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>> error code.
>> Thanks,
>> Naresh
>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Ah I see, then is not your or geonode fault. This is an issue of that
>>> geoserver.
>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>> This url http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>> Geoserver of others and I am adding thishttp://bhuvan5.nrsc.gov.in
>>>> /bhuvan/web/ url to GeoNode using Layers ->Add server option. It is
>>>> adding but it shows the issue which I mentioned in my earlier mail.
>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>>> demo GeoNode site and can be observed same issue.
>>>> Thanks,
>>>> Naresh
>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>> Earlier I faced layer issue and with your guidance i have fixed
>>>>>> the issue. Please find the link our earlier converstaion
>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td53
>>>>>> 23603.html which contains the steps I followed to install.
>>>>>> I have verified my geoserver instance and version is 2.7.4. Not
>>>>>> able to understand from where you observed my Geoserver version is 2.0.2?.
>>>>>> Please let me know any other information required to solve the issue
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x.
>>>>>>> Could you clarify how you installed it?
>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>> Yes, I followed steps from http://docs.geonode.org/
>>>>>>>> en/2.4.x/tutorials/install_and_admin/geonode_install/install
>>>>>>>> _geoserver_application.html to configure Geoserver with GeoNode
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_an
>>>>>>>>> d_admin/geonode_install/install_geoserver_application.html
>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear simone,
>>>>>>>>>> Kindly suggest to overcome the issue.
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also I
>>>>>>>>>>> have tested with the url http://bhuvan5.nrsc.gov.in/bhuvan/wms
>>>>>>>>>>> , I am getting same issue. Please help me to resolve
>>>>>>>>>>> My System details:
>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>> Hi seems that you are missing a configuration in geoserver. How
>>>>>>>>>>>> did you install geonode?
>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_
>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>> When I am adding WMS Layer URL in GeoNode using
>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>> Please also find the attached screenshot with this mail. The
>>>>>>>>>>>>> WMS url added is http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>> with GeoNode demo site and facing similar issue as above*
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/5709da97/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/5709da97/attachment-0001.png>
More information about the geonode-users
