[GeoNode-users] Installing SSL certificates in GeoNode
Amedeo Fadini amefad at gmail.com
Thu Jun 15 02:10:34 PDT 2017
Hi Dimitris,
How is handled the Proxy configuration in Nginx?
Did you checked if the proxy_pass in Nginx  is mapped to the same address
and port of <connector port> in tomcat7/server.xml?
If you can add the part of Nginx configuration to the tutorial page i think
it will be good.
Amefad
2017-06-15 8:40 GMT+02:00 Dimitris Karakostis <karakostis.dimitris at gmail.com
> Hey list,
> We are installing SSL certificates for our GeoNode instance. I am testing
> right now in staging and I am facing some issues. Although the SSL is
> installed in the server and partially works, I am not able to load the
> existing layers.
> To install the SSL I have followed the instructions here:
> http://docs.geonode.org/en/master/tutorials/advanced/g
> eonode_production/ssl.html  (instead of apache we have nginx)
> I have also changed the corresponding URLs in the local_settings.py file
> (SITE_URL etc.)
> And I have executed the updatelayers command.
> The staging.geonode.wfp.org page loads with an https and a notification
> that is not fully secured. This must be cause some images and the
> openstreetmap baselayer  have hardcoded http instead of https.
> I can upload new layers and style them or edit the metadata but I am not
> able to access any of the old (existing) layers.
> I get a NGINX 502 Bad Gateway error. The log files are not particularly
> helpful. I suspect that some of the links broke after I executed the
> updatelayer command. Before that, I was able to access the layers but I
> couldn't style or edit the metadata.
> Do you have any idea what it could be the issue?
> Thanks a lot.
> Dimitris
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/e8135deb/attachment.html>
More information about the geonode-users mailing list
