[GeoNode-users] Geonode Multi-Tenancy error
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Jun 15 06:53:10 PDT 2017
did you dd geonode.contrib.geosites in your INSTALLED_APPS? Anyway the
command could be broken, you can achieve the same by copying the
https://github.com/GeoNode/geonode/tree/2.6.x/geonode/contrib/geosites/site_template
folder for each of your sites and set it up manually.
2017-06-15 10:03 GMT+02:00 Albano Giovanni <albano.giovanni at tiscali.it>:
> Hi, I have a problem with GeoNode Multi-Tenancy.
> I followed the geonode guide and this link https://github.com/GeoNode/
> geonode/tree/master/geonode/contrib/geosites
> But when I try to write the command
> (geonode-2.6.x) C:\GeoNode-2.6.x\geonode-2.6.x>python manage.py addsite
> sitename sitedomain
> Unknown command: 'addsite'
> Why?
> Thanks
> Giovanni Albano
> [image: LOGO_piccolo]
> Pianificazione Ambiente Energia Sistemi Informativi Territoriali
> Via Della Tecnica 24 85100 Potenza (PZ)
> Telefono +39 0971/1652848 <+39%200971%20165%202848>
> Partita IVA 01801940766
> Rispetta l’ambiente. Hai davvero bisogno di stampare questa mail?
> *Please consider the environment – Do you really need to print this email?*
> Ai sensi del D.lgs n. 196 del 30.06.03 (Codice Privacy) si precisa che le
> informazioni contenute in questo messaggio sono riservate e ad uso
> esclusivo del destinatario. Qualora il messaggio in parola Le fosse
> pervenuto per errore, La preghiamo di eliminarlo senza copiarlo e di non
> inoltrarlo a terzi, dandocene gentilmente comunicazione. Grazie
> *This message, for the D.lgs n. 196 / 30.06.03 (Privacy Code), may contain
> confidential and/or privileged information. If you are not the addressee or
> authorized to receive this for the addressee, you must not use, copy,
> disclose or take any action based on this message or any information
> herein. If you have received this message in error, please advise the
> sender immediately by reply e-mail and delete this message. **Thank you
> for your cooperation*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/6cafbdcf/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170615/6cafbdcf/attachment.jpg>
More information about the geonode-users
