[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 16 05:55:38 PDT 2017
It must be an array and not a tuple.
I don't know what ssl misconfiguration could be
Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com> ha
scritto:
> Dear Simone,
> Now I added in settings.py PROXY_ALLOWED_HOSTS = ('192.168.198.209') and
> in proxy/views.py linenumber: 37 is reverted means removed ip adress and
> kept as hostname. It is showing following error
> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal Server
> Error: /proxy/
> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback (most
> recent call last):
> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]   File
> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py", line 112,
> in get_response
> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]     response =
> wrapped_callback(request, *callback_args, **callback_kwargs)
> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]   File
> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
> PROXY_ALLOWED_HOSTS +=hostname
> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError: cannot
> concatenate 'str' and 'tuple' objects
> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal Server
> Error: /proxy/
> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback (most
> recent call last):
> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]   File
> in get_response
> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]     response =
> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]   File
> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError: cannot
> concatenate 'str' and 'tuple' objects*
> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622] Misconfiguration of
> certificate's CN and virtual name. The certificate CN has
> localhost4.localdomain4. We expected localhost.localdomain as virtual name.
> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL Library Error:
> -12263 SSL received a record that exceeded the maximum permissible length
> if in proxy/views.py if i add in place of hostname ip adress of the
> GeoNode, The error '*TypeError: cannot concatenate 'str' and 'tuple'
> objects ' *will go, how ever the error which I mentioned in my earlier
> mail retains.
> Please suggest how to overcome above error '*TypeError: cannot
> concatenate 'str' and 'tuple' objects ' *with out editing proxy/views.py
> And also kindly suggest me how to correct misconfiguration of SSL error,
> since I am not using https any where
> Thanks,
> Naresh
> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Not a good idea to modify the python files, You can add the
>> PROXY_ALLOWED_HOSTS in settings.
>> Anyway, seems you are running under ssl. Seems a misconfiguration of it.
>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>>  I have tried with the url provided http://demo.genode.org/geoserver/wms,
>>> getting the following error.
>>> [image: Inline image 1]
>>> *Please find the apaahe error log file and attached views.py file from
>>> proxy folder of geonode for the reference. In view.py in line no: 37 is
>>> modified (commented host name and placed IP adrdress of GeoNode installed
>>> system)*
>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal Server
>>> Error: /proxy/
>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902] Traceback (most
>>> recent call last):
>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]   File
>>> in get_response
>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]     response =
>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]   File
>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>> conn.request(request.method, locator, request.body, headers)
>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>> self._send_request(method, url, body, headers)
>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>> self.endheaders(body)
>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>> self._send_output(message_body)
>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]     self.send(msg)
>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]     self.connect()
>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]     self.timeout,
>>> self.source_address)
>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]   File
>>> "/usr/lib64/python2.7/socket.py", line 571, in create_connection
>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]     raise err
>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error: [Errno
>>> 111] Connection refused
>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal Server
>>> Error: /proxy/
>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902] Traceback (most
>>> recent call last):
>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]   File
>>> in get_response
>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]     response =
>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]     self.send(msg)
>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]     self.connect()
>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]     self.timeout,
>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]   File
>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]     raise err
>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error: [Errno
>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208] Misconfiguration
>>> of certificate's CN and virtual name. The certificate CN has
>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL Library
>>> Error: -12263 SSL received a record that exceeded the maximum permissible
>>> length
>>> Please kindly suggest me, do i need to modify some where else?
>>> Thanks,
>>> Naresh
>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com> wrote:
>>>> Dear Simone,
>>>>   Thanks. I will try with the provided url.
>>>> Thanks,
>>>> Naresh
>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not sure
>>>>> about our other question, don't think is possible in the standard code.
>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>>   Thanks for the replies. Is any other External WMS Layer url is
>>>>>> available ,please share me to test.  Is that any mechanism is available in
>>>>>> case if WFS of Geoserver is disabled,not enabling EDIT option while reading
>>>>>> error code.
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>> Ah I see, then is not your or geonode fault. This is an issue of
>>>>>>> that geoserver.
>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is external
>>>>>>>> Geoserver of others and I am adding this
>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode using Layers
>>>>>>>> ->Add server option. It is adding but it shows the issue which I mentioned
>>>>>>>> in my earlier mail.
>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in/bhuvan/wms. in
>>>>>>>> demo GeoNode site  and  can be observed same issue.
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>> Dear Simone,
>>>>>>>>>>   Earlier I faced layer issue and with your guidance i  have
>>>>>>>>>> fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>> http://osgeo-org.1560.x6.nabble.com/Layer-Editing-Error-td5323603.html
>>>>>>>>>>  which contains the steps I followed to install.
>>>>>>>>>>  I have verified my geoserver instance  and version is 2.7.4. Not
>>>>>>>>>> able to understand from where you  observed my Geoserver version is 2.0.2?.
>>>>>>>>>>  Please let me know any other information required to solve the
>>>>>>>>>> issue
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should be 2.7.x.
>>>>>>>>>>> Could you clarify how you installed it?
>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>> http://docs.geonode.org/en/2.4.x/tutorials/install_and_admin/geonode_install/install_geoserver_application.html
>>>>>>>>>>>> to configure Geoserver with GeoNode
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>> Have you configured geoserver following the 2.4 guide?
>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>> Copied geoserver.war file from Windows Installation of
>>>>>>>>>>>>>>> GeoNode2.4.x and pasted into /var/lib/tomcats/webapps folder.
>>>>>>>>>>>>>>> And on demo site of GeoNode (http://demo.geonode.org) also
>>>>>>>>>>>>>>> I have tested with the url
>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms   , I am getting same
>>>>>>>>>>>>>>> issue. Please help me to resolve
>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in geoserver.
>>>>>>>>>>>>>>>> How did you install geonode?
>>>>>>>>>>>>>>>> http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html
>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode  using
>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>> Please also find the attached screenshot with this mail.
>>>>>>>>>>>>>>>>> The WMS url  added  is
>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>> *Note: Even the url *http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/6eba49c4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/6eba49c4/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170616/6eba49c4/attachment-0003.png>
More information about the geonode-users mailing list
