[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N
naresh919 at gmail.com
Tue Jun 20 03:45:58 PDT 2017
Dear Simone,
I have opened the terminal in my server(Geonode deployed system) and
typed the ping fase2kort.klimatilpasning.dk, but not getting connected. Do
I need to change/add my server settings?
Thanks,
Naresh
On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Ok so maybe your server is unable to reach that address, can you check
> that?
> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>> Dear Simone,
>> when I opened the http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers, it is
>> showine geoserver related error. Please find the attached response file for
>> you reference.
>> Thanks,
>> Naresh
>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> It might be. Are you able to access that wms backend from in the
>>> browser? http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>>> it should give you an XML containing the geoserver error related to
>>> missing request parameter.
>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>> Dear Simone,
>>>> Yes we are in office campus, we are using proxy server. So is this
>>>> the reason? if so where I need to do the changes?
>>>> Thanks,
>>>> Naresh
>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>> At this point I would check your local internet connection, are you
>>>>> behind a proxy that may block it?
>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>> Dear Simone,
>>>>>> Thanks for the responding. As per I understand from below code in
>>>>>> the proxy/views.py
>>>>>> if not settings.DEBUG:
>>>>>> if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>>>> return HttpResponse("DEBUG is set to False but the host
>>>>>> of the path provided to the proxy service"
>>>>>> " is not in the PROXY_ALLOWED_HOSTS
>>>>>> setting.",
>>>>>> status=403,
>>>>>> content_type="text/plain"
>>>>>> if GeoNode debug mode value is flase, the wms url may not be
>>>>>> required to add in PROXY_ALLOWED_HOSTS. And even if debug mode
>>>>>> value is ture, it should show the following error 'DEBUG is set to
>>>>>> False but the host of the path provided to the proxy service"
>>>>>> setting',. In my case nothing this kind of error/alert message is not
>>>>>> getting
>>>>>> And I added the fase2kort.klimatilpasning.dk in Demo GeoNode site,
>>>>>> it is fetching the layers
>>>>>> However now,I have added fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it is
>>>>>> showing same error.
>>>>>> I have been trying from last two days to overcome this issue, but not
>>>>>> able to do. Please suggest anywhere more I need to investigate the
>>>>>> code/settings?
>>>>>> Thanks,
>>>>>> Naresh
>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in the
>>>>>>> PROXY_ALLOWED_HOSTS directive as every remote address should be authorised
>>>>>>> there.
>>>>>>> I tested locally and seems to work.
>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>> Dear Simone,
>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>> is solved.
>>>>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>>>>> following error.
>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>> Internal Server Error: /proxy/
>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629] Traceback
>>>>>>>> (most recent call last):
>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>>>> line 112, in get_response
>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629] response =
>>>>>>>> wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>> self.endheaders(body)
>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>> self._send_output(message_body)
>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>> self.send(msg)
>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>> self.connect()
>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>> self.timeout, self.source_address)
>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in create_connection
>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise err
>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error:
>>>>>>>> [Errno 111] Connection refused
>>>>>>>> Even I went to httplib.py and socket.py with the alerts I could
>>>>>>>> able to see the following WMS server IP and port details ('188.64.159.9',
>>>>>>>> 80) and source_address is none
>>>>>>>> Please help me how to resolve the issue, is that any where my
>>>>>>>> GeoNode Deployed System Ip need to place?
>>>>>>>> Thanks,
>>>>>>>> Naresh
>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <naresh919 at gmail.com>
>>>>>>>>> ha scritto:
>>>>>>>>>> Dear Simone,
>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410] Internal
>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410] Traceback
>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410] File
>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410] File
>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 37, in proxy
>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410] TypeError:
>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409] Internal
>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409] Traceback
>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409] File
>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409] File
>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>> name.
>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL
>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>> permissible length
>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip adress of
>>>>>>>>>> the GeoNode, The error '*TypeError: cannot concatenate 'str' and
>>>>>>>>>> 'tuple' objects ' *will go, how ever the error which I mentioned
>>>>>>>>>> in my earlier mail retains.
>>>>>>>>>> Please suggest how to overcome above error '*TypeError: cannot
>>>>>>>>>> concatenate 'str' and 'tuple' objects ' *with out editing
>>>>>>>>>> proxy/views.py
>>>>>>>>>> And also kindly suggest me how to correct misconfiguration of SSL
>>>>>>>>>> error, since I am not using https any where
>>>>>>>>>> Thanks,
>>>>>>>>>> Naresh
>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>> I have tried with the url provided
>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the following
>>>>>>>>>>>> error.
>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>> *Please find the apaahe error log file and attached views.py
>>>>>>>>>>>> file from proxy folder of geonode for the reference. In view.py in line no:
>>>>>>>>>>>> 37 is modified (commented host name and placed IP adrdress of GeoNode
>>>>>>>>>>>> installed system)*
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902] Internal
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902] File
>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 67, in proxy
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>> self.connect()
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902] File
>>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>> create_connection
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>> raise err
>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902] error:
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902] Internal
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>> self.connect()
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902] File
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902] File
>>>>>>>>>>>> create_connection
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>> raise err
>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902] error:
>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>> name.
>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL
>>>>>>>>>>>> permissible length
>>>>>>>>>>>> Please kindly suggest me, do i need to modify some where else?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Naresh
>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>> Thanks. I will try with the provided url.
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms. Not
>>>>>>>>>>>>>> sure about our other question, don't think is possible in the standard code.
>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>> Thanks for the replies. Is any other External WMS Layer
>>>>>>>>>>>>>>> url is available ,please share me to test. Is that any mechanism is
>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is an
>>>>>>>>>>>>>>>> issue of that geoserver.
>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>> This url http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to GeoNode
>>>>>>>>>>>>>>>>> using Layers ->Add server option. It is adding but it shows the issue which
>>>>>>>>>>>>>>>>> I mentioned in my earlier mail.
>>>>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site and can be observed
>>>>>>>>>>>>>>>>> same issue.
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.in/bhuvan/web/
>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>> Earlier I faced layer issue and with your guidance i
>>>>>>>>>>>>>>>>>>> have fixed the issue. Please find the link our earlier converstaion
>>>>>>>>>>>>>>>>>>> http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html which
>>>>>>>>>>>>>>>>>>> contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>> I have verified my geoserver instance and version is
>>>>>>>>>>>>>>>>>>> 2.7.4. Not able to understand from where you observed my Geoserver version
>>>>>>>>>>>>>>>>>>> is 2.0.2?.
>>>>>>>>>>>>>>>>>>> Please let me know any other information required to
>>>>>>>>>>>>>>>>>>> solve the issue
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it should
>>>>>>>>>>>>>>>>>>>> be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <naresh919 at gmail.com
>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>> Yes, I followed steps from http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html to configure Geoserver
>>>>>>>>>>>>>>>>>>>>> with GeoNode
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4
>>>>>>>>>>>>>>>>>>>>>> guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>> Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>> naresh919 at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have tested with
>>>>>>>>>>>>>>>>>>>>>>>> the url http://bhuvan5.nrsc.gov.in/bhuvan/wms ,
>>>>>>>>>>>>>>>>>>>>>>>> I am getting same issue. Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration in
>>>>>>>>>>>>>>>>>>>>>>>>> geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>> When I am adding WMS Layer URL in GeoNode using
>>>>>>>>>>>>>>>>>>>>>>>>>> ADDLayrers---> Addsever option the following error is getting and EDIT
>>>>>>>>>>>>>>>>>>>>>>>>>> options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot with
>>>>>>>>>>>>>>>>>>>>>>>>>> this mail. The WMS url added is
>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site and facing similar issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/17976e85/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/17976e85/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/17976e85/attachment-0003.png>
More information about the geonode-users
