[GeoNode-users] geonode-users Digest, Vol 29, Issue 88
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Tue Jun 20 14:38:38 PDT 2017
Hi Cliff,
> No access to Geoserver on the address line.
you serve via apache? Have you checked if everything is okay with your
vhost config f.e. with your proxy settings?
<Proxy *>
Order allow,deny
Allow from all
</Proxy>
ProxyPreserveHost On
ProxyPass /geoserver http://localhost:8080/geoserver
ProxyPassReverse /geoserver http://localhost:8080/geoserver
And if tomcat is running?
cheers,
toni
> Am 20.06.2017 um 20:09 schrieb geonode-users-request at lists.osgeo.org:
> Message: 1
> Date: Tue, 20 Jun 2017 14:09:48 -0400
> From: Cliff Patterson <cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>>
> To: Simone Dalmasso <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>>
> Cc: Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>, geonode-users
> <geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>>
> Subject: Re: [GeoNode-users] Installation Problems with version 2.6 on
> Ubuntu 16.04
> Message-ID:
> <CABemPGPGYdR8O-gbYOY3mbkSiUfjyc56u0UN2Gof3qx1XPtsWg at mail.gmail.com <mailto:CABemPGPGYdR8O-gbYOY3mbkSiUfjyc56u0UN2Gof3qx1XPtsWg at mail.gmail.com>>
> Content-Type: text/plain; charset="utf-8"
> No access to Geoserver on the address line. Will do more testing. Might try
> on the local VM to see it I can get it running.
> Thanks!
> Cliff
> On Tue, Jun 20, 2017 at 12:48 PM, Simone Dalmasso <simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>
>> wrote:
>> Ok, and you mentioned you can't log in with your superuser, this is very
>> strange. Any error in the apache log? You could also turn on the DEBUG =
>> True in the settings, this will give you more info on the screen.
>> For the geoserver issue, are you able to reach the /geoserver address and
>> see the geoserver home page?
>> 2017-06-20 15:04 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>>:
>>> @simone I used the following instructions to install:
>>> sudo add-apt-repository ppa:geonode/stable
>>> sudo apt-get update
>>> sudo apt-get install geonode
>>> Then set the IP address and create a superuser.
>>> geonode createsuperuser
>>> sudo geonode-updateip 127.0.0.1 (replaced with my IP address)
>>> There were no errors during installation. I did a thorough read of the
>>> apt log at /var/log/apt/term.log and no errors reported.
>>> On Tue, Jun 20, 2017 at 5:45 AM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>> wrote:
>>>> Not an issue, just a warning. It has been already solved on master.
>>>> Regards,
>>>> Alessio Fabiani
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V <http://goo.gl/it488V> for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054 Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>>>> mob: +39 331 6233686 <+39%20331%20623%203686>
>>>> http://www.geo-solutions.it <http://www.geo-solutions.it/>
>>>> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
>>>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>> principi dettati dal D.Lgs. 196/2003.
>>>> The information in this message and/or attachments, is intended solely
>>>> for the attention and use of the named addressee(s) and may be confidential
>>>> or proprietary in nature or covered by the provisions of privacy act
>>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>>> copying, distribution, or either dissemination, either whole or partial, is
>>>> strictly forbidden except previous formal approval of the named
>>>> addressee(s). If you are not the intended recipient, please contact
>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>> information in this message that has been received in error. The sender
>>>> does not give any warranty or accept liability as the content, accuracy or
>>>> completeness of sent messages and accepts no responsibility for changes
>>>> made after they were sent or for other risks which arise as a result of
>>>> e-mail transmission, viruses, etc.
>>>> On Tue, Jun 20, 2017 at 7:53 AM, Simone Dalmasso <
>>>> simone.dalmasso at gmail.com <mailto:simone.dalmasso at gmail.com>> wrote:
>>>>> @Cliff, could you describe again how you install GeoNode? if using
>>>>> apt-get you should get errors during installation, please report them here.
>>>>> @Israel, that is just an info due to db design, we can clean it up in
>>>>> the future but is not an issue.
>>>>> 2017-06-19 22:46 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>>:
>>>>>> No previous version installed. It was installed on a fresh OS.
>>>>>> On Jun 19, 2017 4:43 PM, "Israel López" <asralf at gmail.com <mailto:asralf at gmail.com>> wrote:
>>>>>> Hi, did you have a previous version of genode installed???
>>>>>> I'm testing Geonode 2.6 too, but on Develoment mode, I had similar
>>>>>> issues,
>>>>>> but "log-in" problem I solved running the create superuser command
>>>>>> again.
>>>>>> The issue that remains is this one:
>>>>>> base.ResourceBase.tkeywords: (fields.W340) null has no effect on
>>>>>> ManyToManyField.
>>>>>> I don't understand it, but Geonode is running and working, if somebody
>>>>>> could explain me
>>>>>> how to fix it I will appreciate it.
>>>>>> Greetings.
>>>>>> 2017-06-19 11:29 GMT-05:00 Cliff Patterson <cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>>:
>>>>>>> I finally reinstalled on a clean Ubuntu 16.04.2 (64 bit) VPS with 4GB
>>>>>>> of ram and still having the same issues:
>>>>>>> 1. Unable to log in with superuser credentials
>>>>>>> 2. unable to fully update IP. The system hangs at "Inspecting the
>>>>>>> available layers in GeoServer ..."
>>>>>>> 3. Getting the following warning during install and when running
>>>>>>> createssuperuser:
>>>>>>> WARNINGS:
>>>>>>> ?: (1_8.W001) The standalone TEMPLATE_* settings were deprecated in
>>>>>>> Django 1.8 and the TEMPLATES dictionary takes precedence. You must put the
>>>>>>> values of the following settings into your default TEMPLATES dict:
>>>>>>> TEMPLATE_DIRS.
>>>>>>> ManyToManyField.
>>>>>>> Bottom line, even on a 4GB machine, I cannot get Geonode working.
>>>>>>> Have the installation instructions changed or am I missing some critical
>>>>>>> step? I'm using these: http://geonode.org/blog/2017/0 <http://geonode.org/blog/2017/0>
>>>>>>> 5/17/geonode-2.6-released/
>>>>>>> Big thanks!
>>>>>>> Cliff
>>>>>>> On Fri, Jun 9, 2017 at 7:25 AM, Simone Dalmasso <
>>>>>>>> Hi, well 2 GB are probably not enough. 4GB are the minimum I think.
>>>>>>>> You shopuld be able to find geoserver with locate geoserver, it is
>>>>>>>> uncompressed in /usr/share if I'm no wrong.
>>>>>>>> 2017-06-09 13:03 GMT+02:00 Cliff Patterson <cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>
>>>>>>>>> Thanks for the reply!
>>>>>>>>> I didn't see any errors (except for template warnings) during
>>>>>>>>> installation. I even saw that geonode-geoserver was installed but I can't
>>>>>>>>> find it post installation.
>>>>>>>>> I spun it up on a VM with 4 cores and 2GB of ram on Digital Ocean.
>>>>>>>>> Is this enough power for GeoNode?
>>>>>>>>> Thanks again for your help!
>>>>>>>>> Cheers,
>>>>>>>>> Cliff
>>>>>>>>> On Jun 9, 2017 3:17 AM, "Simone Dalmasso" <
>>>>>>>>>> Hi, yes definitely geoserver needs to be there and the package
>>>>>>>>>> should install it. Make sure your machine is powerful enough, also during
>>>>>>>>>> the installation you should have gotten some errors.
>>>>>>>>>> 2017-06-08 18:22 GMT+02:00 Cliff Patterson <
>>>>>>>>>>> PS: and I am unable to authenticate via the geonode website.
>>>>>>>>>>> On Thu, Jun 8, 2017 at 12:20 PM, Cliff Patterson <
>>>>>>>>>>> cliffpatterson at gmail.com <mailto:cliffpatterson at gmail.com>> wrote:
>>>>>>>>>>>> Hello,
>>>>>>>>>>>> I decided to give Geonode 2.6 a go and installed it on a fresh
>>>>>>>>>>>> VM running Ubuntu 16.04.2 x64. I installed it with the following commands:
>>>>>>>>>>>> sudo apt-get update
>>>>>>>>>>>> sudo geonode-updateip 67.207.87.119
>>>>>>>>>>>> When creating the super user, I get the following warning:
>>>>>>>>>>>> System check identified some issues:
>>>>>>>>>>>> WARNINGS:
>>>>>>>>>>>> in Django 1.8 and the TEMPLATES dictionary takes precedence. You must put
>>>>>>>>>>>> the values of the following settings into your default TEMPLATES dict:
>>>>>>>>>>>> TEMPLATE_DIRS.
>>>>>>>>>>>> ManyToManyField.
>>>>>>>>>>>> Username: test
>>>>>>>>>>>> Email address:
>>>>>>>>>>>> Password:
>>>>>>>>>>>> Password (again):
>>>>>>>>>>>> Superuser created successfully.
>>>>>>>>>>>> When running sudo geonode-updateip 67.207.87.119, the following
>>>>>>>>>>>> happens:
>>>>>>>>>>>> 1) Hangs on "Inspecting the available layers in GeoServer ..."
>>>>>>>>>>>> 2) Geonode does get up and running at 67.207.87.119 but no
>>>>>>>>>>>> ability to login
>>>>>>>>>>>> Replacing SITEURL value with '67.207.87.119' in
>>>>>>>>>>>> /etc/geonode/local_settings.py ... done.
>>>>>>>>>>>> Adding entry for '67.207.87.119' in
>>>>>>>>>>>> /usr/share/geoserver/data/printing/config.yaml ... done.
>>>>>>>>>>>> Adding ALLOWED_HOSTS with in /etc/geonode/local_settings.py ...
>>>>>>>>>>>> done.
>>>>>>>>>>>> Setting up oauth
>>>>>>>>>>>> Am I missing something in the instructions? Do we need to
>>>>>>>>>>>> install Geoserver on Tomcat7 first, then Geonode? As far as I can see,
>>>>>>>>>>>> Geoserver has not been installed, which I thought was part of the geonode
>>>>>>>>>>>> installation, but I could be wrong.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users>
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/b400022e/attachment-0001.html>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170620/b400022e/attachment-0001.sig>
More information about the geonode-users
