[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N naresh919 at gmail.com
Wed Jun 21 03:23:31 PDT 2017
Dear Simone,
 Kindly suggest answers for my earlier mail.
Thanks,
Naresh
On Wed, Jun 21, 2017 at 11:54 AM, Naresh N <naresh919 at gmail.com> wrote:
> Dear Simone,
>   Thanks once again. I am trying to resolve, but not able to do. Kindly
> explain following little more, which will help to resolve
> 1.The WMS URL request  i.e  http://fase2kort.klimatilpasning.dk:80/
> geoserver/wms is first  reaching to GeoNode deployed system and from it ,
> the request is going to corresponding URL.
>   In this case GeoNode deployed system to send the url ,it required proxy
> server our campus network .* Is it true?* If so  I have to specify our
> proxy server address in GeoNode Code. Where I have to specify?
> 2. Even if it works the GeoNode deployed system should have internet
> connectivity.* Is it true*?
> 3. As of now my GeoNode deployed System has internet connectivity, how
> ever once we make this application live/production, the internet
> connectivity will be removed for security concerns
>              (As you aware production servers should not have internet to
> avoid possible threats)
>   *          In this case how to handle?*
> *4. * Is there any way is available , if user specifies WMS Layer URL and
> Name it should load  and add corresponding layers to GeoNode  Map/Layer
> window
> Please kindly help me to understand
> Thanks,
> Naresh
> On Tue, Jun 20, 2017 at 5:49 PM, Simone Dalmasso <
> simone.dalmasso at gmail.com> wrote:
>> Unfortunately I don't have any other advice, if the server is properly
>> connected to the internet and is correctly accessing it, then it should
>> work without requiring specific settings but the PROXY_ALLOWED_HOSTS, which
>> you already set.
>> 2017-06-20 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>> Dear Simone,
>>> Thanks for the responses
>>> As you told the following request getting proper response
>>> http://demo.geonode.org/proxy/?url=http%3A%2F%2Ffase2kort.kl
>>> imatilpasning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26RE
>>> QUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
>>> and in case of my geonode  the following request is getting the error
>>> http://localhost/proxy/?url=http%3A%2F%2Ffase2kort.klimatilp
>>> asning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3
>>> However in my browser with the url : http://fase2kort.klimatilpas
>>> ning.dk/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&TI
>>> LED=true&VERSION=1.1.1, it is getting proper respone
>>> Do I need to add *my proxy server address some where in GeoNode code*?
>>> or proxy address will take directly from the system?  I have also asked
>>> network administrator, but  they are not able to understand
>>> As you know, this functionality is very much important, as it will
>>> connect others server and fetch the data . Please  suggest some clue to
>>> resolve
>>> Thanks,
>>> Naresh
>>> On Tue, Jun 20, 2017 at 5:13 PM, Simone Dalmasso <
>>>> No, that server is not responding to ping so it will never work. Not
>>>> sure what setting you need for the server but to me it looks an error
>>>> related to your network. On demo.geonode.org is, for example, working.
>>>> 2017-06-20 12:45 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>>   I have opened the terminal in  my server(Geonode deployed system)
>>>>> and typed the ping  fase2kort.klimatilpasning.dk, but not getting
>>>>> connected. Do I need to change/add my server settings?
>>>>> Thanks,
>>>>> Naresh
>>>>> On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <
>>>>>> Ok so maybe your server is unable to reach that address, can you
>>>>>> check that?
>>>>>> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>  when I opened the http://fase2kort.klimatilp
>>>>>>> asning.dk:80/geoserver/wms
>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers, it
>>>>>>> is showine geoserver related error. Please find the attached response file
>>>>>>> for you  reference.
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>>>>>>>> It might be. Are you able to access that wms backend from in the
>>>>>>>> browser? http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>>>>>>>> it should give you an XML containing the geoserver error related to
>>>>>>>> missing request parameter.
>>>>>>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>   Yes we are in office campus, we are using proxy server. So  is
>>>>>>>>> this the reason?  if so where I need to do the changes?
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>>>>>>> At this point I would check your local internet connection, are
>>>>>>>>>> you behind a proxy that may block it?
>>>>>>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   Thanks for the responding.  As per I understand from below
>>>>>>>>>>> code in the proxy/views.py
>>>>>>>>>>> if not settings.DEBUG:
>>>>>>>>>>>         if not validate_host(url.hostname, PROXY_ALLOWED_HOSTS):
>>>>>>>>>>>             return HttpResponse("DEBUG is set to False but the
>>>>>>>>>>> host of the path provided to the proxy service"
>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting.",
>>>>>>>>>>>                                 status=403,
>>>>>>>>>>>                                 content_type="text/plain"
>>>>>>>>>>>  if GeoNode  debug mode value is flase, the wms url may not be
>>>>>>>>>>> required to add in  PROXY_ALLOWED_HOSTS. And even if debug mode
>>>>>>>>>>> value is ture, it should show the following error 'DEBUG is set
>>>>>>>>>>> to False but the host of the path provided to the proxy service"
>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting',. In my case nothing this kind of error/alert
>>>>>>>>>>> message is not getting
>>>>>>>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo GeoNode
>>>>>>>>>>> site, it is fetching the layers
>>>>>>>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but it
>>>>>>>>>>> is showing same error.
>>>>>>>>>>> I have been trying from last two days to overcome this issue,
>>>>>>>>>>> but not able to do. Please suggest anywhere more I need to investigate the
>>>>>>>>>>> code/settings?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string in
>>>>>>>>>>>> the PROXY_ALLOWED_HOSTS directive as every remote address should be
>>>>>>>>>>>> authorised there.
>>>>>>>>>>>> I tested locally and seems to work.
>>>>>>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>>>>>>> is solved.
>>>>>>>>>>>>> How ever, not able to add any WMS Layer url, it is showing the
>>>>>>>>>>>>> following error.
>>>>>>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>>>>>>> Internal Server Error: /proxy/
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629]
>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>>>>>>>>> line 112, in get_response
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629]
>>>>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in proxy
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in _send_request
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self.endheaders(body)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self._send_output(message_body)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in
>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise
>>>>>>>>>>>>> err
>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629] error:
>>>>>>>>>>>>> [Errno 111] Connection refused
>>>>>>>>>>>>> Even I went to httplib.py and socket.py with the alerts I
>>>>>>>>>>>>> could able to see the following WMS server IP and port details
>>>>>>>>>>>>> ('188.64.159.9', 80) and source_address is none
>>>>>>>>>>>>> Please help me how to resolve the issue, is that any where my
>>>>>>>>>>>>> GeoNode Deployed System Ip need to place?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <
>>>>>>>>>>>>>> naresh919 at gmail.com> ha scritto:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> File "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>> ges/django/core/handlers/base.py", line 112, in get_response
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line 37,
>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>> TypeError: cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL
>>>>>>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip adress
>>>>>>>>>>>>>>> of the GeoNode, The error '*TypeError: cannot concatenate
>>>>>>>>>>>>>>> 'str' and 'tuple' objects ' *will go, how ever the error
>>>>>>>>>>>>>>> which I mentioned in my earlier mail retains.
>>>>>>>>>>>>>>> Please suggest how to overcome above error '*TypeError:
>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects ' *with out
>>>>>>>>>>>>>>> editing proxy/views.py
>>>>>>>>>>>>>>> And also kindly suggest me how to correct misconfiguration
>>>>>>>>>>>>>>> of SSL error, since I am not using https any where
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> Not a good idea to modify the python files, You can add the
>>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the
>>>>>>>>>>>>>>>>> following error.
>>>>>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>>>>>> *Please find the apaahe error log file and attached
>>>>>>>>>>>>>>>>> views.py file from proxy folder of geonode for the reference. In view.py in
>>>>>>>>>>>>>>>>> line no: 37 is modified (commented host name and placed IP adrdress of
>>>>>>>>>>>>>>>>> GeoNode installed system)*
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line 67,
>>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1017, in
>>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1013, in
>>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 807, in
>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> error: [Errno 111] Connection refused
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> raise err
>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135] SSL
>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>> Please kindly suggest me, do i need to modify some where
>>>>>>>>>>>>>>>>> else?
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <
>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms.
>>>>>>>>>>>>>>>>>>> Not sure about our other question, don't think is possible in the standard
>>>>>>>>>>>>>>>>>>> code.
>>>>>>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS
>>>>>>>>>>>>>>>>>>>> Layer url is available ,please share me to test.  Is that any mechanism is
>>>>>>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is
>>>>>>>>>>>>>>>>>>>>> an issue of that geoserver.
>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to
>>>>>>>>>>>>>>>>>>>>>> GeoNode using Layers ->Add server option. It is adding but it shows the
>>>>>>>>>>>>>>>>>>>>>> issue which I mentioned in my earlier mail.
>>>>>>>>>>>>>>>>>>>>>> Please kindly add the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>>> /bhuvan/wms. in demo GeoNode site  and  can be
>>>>>>>>>>>>>>>>>>>>>> observed same issue.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.
>>>>>>>>>>>>>>>>>>>>>>> in/bhuvan/web/
>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your
>>>>>>>>>>>>>>>>>>>>>>>> guidance i  have fixed the issue. Please find the link our earlier
>>>>>>>>>>>>>>>>>>>>>>>> converstaion http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which
>>>>>>>>>>>>>>>>>>>>>>>> contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and version
>>>>>>>>>>>>>>>>>>>>>>>> is 2.7.4. Not able to understand from where you  observed my Geoserver
>>>>>>>>>>>>>>>>>>>>>>>> version is 2.0.2?.
>>>>>>>>>>>>>>>>>>>>>>>>  Please let me know any other information required
>>>>>>>>>>>>>>>>>>>>>>>> to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it
>>>>>>>>>>>>>>>>>>>>>>>>> should be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure
>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver with GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone Dalmasso
>>>>>>>>>>>>>>>>>>>>>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the 2.4
>>>>>>>>>>>>>>>>>>>>>>>>>>> guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /bhuvan/wms   , I am getting same issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dalmasso <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a configuration
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> in geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  using ADDLayrers---> Addsever option the following error is getting and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> EDIT options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with this mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/f30d6920/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/f30d6920/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170621/f30d6920/attachment-0003.png>
More information about the geonode-users mailing list
