[GeoNode-users] Issues adding WMS URL in GeoNode
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 23 01:02:49 PDT 2017
Hi, I think that Toni's answer was complete and actually I've nothing to
add. Your sysadmin should help you in figuring out why your GeoNode can't
reach that address. It is a server configuration anyway, doesn't seems to
be related to geonode config.
2017-06-23 7:28 GMT+02:00 Naresh N <naresh919 at gmail.com>:
> Dear Simone,
>  Kindly help me to understand better working of WMS Manager functionality.
> Kindly answer the my earlier post queries
>  Thanks in advance.
> Best Regards,
> Naresh
> On Wed, Jun 21, 2017 at 3:53 PM, Naresh N <naresh919 at gmail.com> wrote:
>> Dear Simone,
>>  Kindly suggest answers for my earlier mail.
>> Thanks,
>> Naresh
>> On Wed, Jun 21, 2017 at 11:54 AM, Naresh N <naresh919 at gmail.com> wrote:
>>> Dear Simone,
>>>   Thanks once again. I am trying to resolve, but not able to do. Kindly
>>> explain following little more, which will help to resolve
>>> 1.The WMS URL request  i.e  http://fase2kort.klimatilpasn
>>> ing.dk:80/geoserver/wms is first  reaching to GeoNode deployed system
>>> and from it , the request is going to corresponding URL.
>>>   In this case GeoNode deployed system to send the url ,it required
>>> proxy server our campus network .* Is it true?* If so  I have to
>>> specify our proxy server address in GeoNode Code. Where I have to specify?
>>> 2. Even if it works the GeoNode deployed system should have internet
>>> connectivity.* Is it true*?
>>> 3. As of now my GeoNode deployed System has internet connectivity, how
>>> ever once we make this application live/production, the internet
>>> connectivity will be removed for security concerns
>>>              (As you aware production servers should not have internet
>>> to avoid possible threats)
>>>   *          In this case how to handle?*
>>> *4. * Is there any way is available , if user specifies WMS Layer URL
>>> and Name it should load  and add corresponding layers to GeoNode  Map/Layer
>>> window
>>> Please kindly help me to understand
>>> Thanks,
>>> Naresh
>>> On Tue, Jun 20, 2017 at 5:49 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Unfortunately I don't have any other advice, if the server is properly
>>>> connected to the internet and is correctly accessing it, then it should
>>>> work without requiring specific settings but the PROXY_ALLOWED_HOSTS, which
>>>> you already set.
>>>> 2017-06-20 14:08 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>> Dear Simone,
>>>>> Thanks for the responses
>>>>> As you told the following request getting proper response
>>>>> http://demo.geonode.org/proxy/?url=http%3A%2F%2Ffase2kort.kl
>>>>> imatilpasning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26RE
>>>>> QUEST%3DGetCapabilities%26TILED%3Dtrue%26VERSION%3D1.1.1
>>>>> and in case of my geonode  the following request is getting the error
>>>>> http://localhost/proxy/?url=http%3A%2F%2Ffase2kort.klimatilp
>>>>> asning.dk%3A80%2Fgeoserver%2Fwms%3FSERVICE%3DWMS%26REQUEST%3
>>>>> However in my browser with the url : http://fase2kort.klimatilpas
>>>>> ning.dk/geoserver/wms?SERVICE=WMS&REQUEST=GetCapabilities&TI
>>>>> LED=true&VERSION=1.1.1, it is getting proper respone
>>>>> Do I need to add *my proxy server address some where in GeoNode code*?
>>>>> or proxy address will take directly from the system?  I have also asked
>>>>> network administrator, but  they are not able to understand
>>>>> As you know, this functionality is very much important, as it will
>>>>> connect others server and fetch the data . Please  suggest some clue to
>>>>> resolve
>>>>> Thanks,
>>>>> Naresh
>>>>> On Tue, Jun 20, 2017 at 5:13 PM, Simone Dalmasso <
>>>>>> No, that server is not responding to ping so it will never work. Not
>>>>>> sure what setting you need for the server but to me it looks an error
>>>>>> related to your network. On demo.geonode.org is, for example,
>>>>>> working.
>>>>>> 2017-06-20 12:45 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>> Dear Simone,
>>>>>>>   I have opened the terminal in  my server(Geonode deployed system)
>>>>>>> and typed the ping  fase2kort.klimatilpasning.dk, but not getting
>>>>>>> connected. Do I need to change/add my server settings?
>>>>>>> Thanks,
>>>>>>> Naresh
>>>>>>> On Tue, Jun 20, 2017 at 3:46 PM, Simone Dalmasso <
>>>>>>>> Ok so maybe your server is unable to reach that address, can you
>>>>>>>> check that?
>>>>>>>> 2017-06-20 12:01 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>> Dear Simone,
>>>>>>>>>  when I opened the http://fase2kort.klimatilp
>>>>>>>>> asning.dk:80/geoserver/wms
>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> in browsers,
>>>>>>>>> it is showine geoserver related error. Please find the attached response
>>>>>>>>> file for you  reference.
>>>>>>>>> Thanks,
>>>>>>>>> Naresh
>>>>>>>>> On Tue, Jun 20, 2017 at 3:14 PM, Simone Dalmasso <
>>>>>>>>>> It might be. Are you able to access that wms backend from in the
>>>>>>>>>> browser? http://fase2kort.klimatilpasning.dk:80/geoserver/wms
>>>>>>>>>> it should give you an XML containing the geoserver error related
>>>>>>>>>> to missing request parameter.
>>>>>>>>>> 2017-06-20 11:00 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>   Yes we are in office campus, we are using proxy server. So  is
>>>>>>>>>>> this the reason?  if so where I need to do the changes?
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Naresh
>>>>>>>>>>> On Tue, Jun 20, 2017 at 2:11 PM, Simone Dalmasso <
>>>>>>>>>>>> At this point I would check your local internet connection, are
>>>>>>>>>>>> you behind a proxy that may block it?
>>>>>>>>>>>> 2017-06-20 10:37 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>   Thanks for the responding.  As per I understand from below
>>>>>>>>>>>>> code in the proxy/views.py
>>>>>>>>>>>>> if not settings.DEBUG:
>>>>>>>>>>>>>         if not validate_host(url.hostname,
>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS):
>>>>>>>>>>>>>             return HttpResponse("DEBUG is set to False but the
>>>>>>>>>>>>> host of the path provided to the proxy service"
>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting.",
>>>>>>>>>>>>>                                 status=403,
>>>>>>>>>>>>>                                 content_type="text/plain"
>>>>>>>>>>>>>  if GeoNode  debug mode value is flase, the wms url may not be
>>>>>>>>>>>>> required to add in  PROXY_ALLOWED_HOSTS. And even if debug
>>>>>>>>>>>>> mode value is ture, it should show the following error 'DEBUG
>>>>>>>>>>>>> is set to False but the host of the path provided to the proxy service"
>>>>>>>>>>>>>                                 " is not in the
>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS setting',. In my case nothing this kind of error/alert
>>>>>>>>>>>>> message is not getting
>>>>>>>>>>>>> And I added the  fase2kort.klimatilpasning.dk  in Demo
>>>>>>>>>>>>> GeoNode site, it is fetching the layers
>>>>>>>>>>>>> However now,I have added  fase2kort.klimatilpasning.dk in PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>> = ('192.168.198.209',' 'fase2kort.klimatilpasning.dk',) but
>>>>>>>>>>>>> it is showing same error.
>>>>>>>>>>>>> I have been trying from last two days to overcome this issue,
>>>>>>>>>>>>> but not able to do. Please suggest anywhere more I need to investigate the
>>>>>>>>>>>>> code/settings?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>> On Tue, Jun 20, 2017 at 1:19 PM, Simone Dalmasso <
>>>>>>>>>>>>>> Naresh, you should add the fase2kort.klimatilpasning.dk
>>>>>>>>>>>>>> <http://fase2kort.klimatilpasning.dk/geoserver/wms> string
>>>>>>>>>>>>>> in the PROXY_ALLOWED_HOSTS directive as every remote address should be
>>>>>>>>>>>>>> authorised there.
>>>>>>>>>>>>>> I tested locally and seems to work.
>>>>>>>>>>>>>> 2017-06-20 8:39 GMT+02:00 Naresh N <naresh919 at gmail.com>:
>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>> After including comma in PROXY_ALLOWED_HOSTS .i.e. PROXY_ALLOWED_HOSTS
>>>>>>>>>>>>>>> = ('192.168.198.209', ) the error, str and tupple can not be concatenated
>>>>>>>>>>>>>>> is solved.
>>>>>>>>>>>>>>> How ever, not able to add any WMS Layer url, it is showing
>>>>>>>>>>>>>>> the following error.
>>>>>>>>>>>>>>> For example Layer URL: http://fase2kort.klimatilpasni
>>>>>>>>>>>>>>> ng.dk:80/geoserver/wms. Getting the following error.
>>>>>>>>>>>>>>> Internal Server Error: /proxy/
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230275 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230278 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib/python2.7/site-packages/django/core/handlers/base.py",
>>>>>>>>>>>>>>> line 112, in get_response
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230281 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> response = wrapped_callback(request, *callback_args, **callback_kwargs)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230291 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/data/cms/geonode/geonode/proxy/views.py", line 82, in
>>>>>>>>>>>>>>> proxy
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230294 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> conn.request(request.method, locator, request.body, headers)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230296 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1017, in request
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230298 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self._send_request(method, url, body, headers)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230301 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230321 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self.endheaders(body)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230323 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 1013, in endheaders
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230326 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self._send_output(message_body)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.230329 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 864, in _send_output
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232014 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self.send(msg)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232033 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 826, in send
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232036 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self.connect()
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232038 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/httplib.py", line 807, in connect
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232040 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> self.timeout, self.source_address)
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232042 2017] [:error] [pid 17629] File
>>>>>>>>>>>>>>> "/usr/lib64/python2.7/socket.py", line 577, in
>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232045 2017] [:error] [pid 17629] raise
>>>>>>>>>>>>>>> err
>>>>>>>>>>>>>>> [Mon Jun 19 23:59:55.232067 2017] [:error] [pid 17629]
>>>>>>>>>>>>>>> error: [Errno 111] Connection refused
>>>>>>>>>>>>>>> Even I went to httplib.py and socket.py with the alerts I
>>>>>>>>>>>>>>> could able to see the following WMS server IP and port details
>>>>>>>>>>>>>>> ('188.64.159.9', 80) and source_address is none
>>>>>>>>>>>>>>> Please help me how to resolve the issue, is that any where
>>>>>>>>>>>>>>> my GeoNode Deployed System Ip need to place?
>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 6:25 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>> It must be an array and not a tuple.
>>>>>>>>>>>>>>>> I don't know what ssl misconfiguration could be
>>>>>>>>>>>>>>>> Il giorno ven 16 giu 2017 alle 14:46 Naresh N <
>>>>>>>>>>>>>>>> naresh919 at gmail.com> ha scritto:
>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>> Now I added in settings.py PROXY_ALLOWED_HOSTS =
>>>>>>>>>>>>>>>>> ('192.168.198.209') and in proxy/views.py linenumber: 37 is reverted means
>>>>>>>>>>>>>>>>> removed ip adress and kept as hostname. It is showing following error
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174610 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174671 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174675 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> File "/usr/lib/python2.7/site-packa
>>>>>>>>>>>>>>>>> ges/django/core/handlers/base.py", line 112, in
>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174679 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174682 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> File "/data/cms/geonode/geonode/proxy/views.py", line 37,
>>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174684 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> PROXY_ALLOWED_HOSTS +=hostname
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174686 2017] [:error] [pid 17410]
>>>>>>>>>>>>>>>>> TypeError: cannot concatenate 'str' and 'tuple' objects
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174674 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174707 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174711 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174716 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174719 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> in proxy
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174721 2017] [:error] [pid 17409]
>>>>>>>>>>>>>>>>> [Fri Jun 16 07:31:27.174724 2017] [:error] [pid 17409] *TypeError:
>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects*
>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:29.759238 2017] [:error] [pid 17622]
>>>>>>>>>>>>>>>>> Misconfiguration of certificate's CN and virtual name. The certificate CN
>>>>>>>>>>>>>>>>> has localhost4.localdomain4. We expected localhost.localdomain as virtual
>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>> [Fri Jun 16 18:01:36.561265 2017] [:error] [pid 17535] SSL
>>>>>>>>>>>>>>>>> Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>> if in proxy/views.py if i add in place of hostname ip
>>>>>>>>>>>>>>>>> adress of the GeoNode, The error '*TypeError: cannot
>>>>>>>>>>>>>>>>> concatenate 'str' and 'tuple' objects ' *will go, how
>>>>>>>>>>>>>>>>> ever the error which I mentioned in my earlier mail retains.
>>>>>>>>>>>>>>>>> Please suggest how to overcome above error '*TypeError:
>>>>>>>>>>>>>>>>> cannot concatenate 'str' and 'tuple' objects ' *with out
>>>>>>>>>>>>>>>>> editing proxy/views.py
>>>>>>>>>>>>>>>>> And also kindly suggest me how to correct misconfiguration
>>>>>>>>>>>>>>>>> of SSL error, since I am not using https any where
>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>> On Fri, Jun 16, 2017 at 5:08 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>> Not a good idea to modify the python files, You can add
>>>>>>>>>>>>>>>>>> the PROXY_ALLOWED_HOSTS in settings.
>>>>>>>>>>>>>>>>>> Anyway, seems you are running under ssl. Seems a
>>>>>>>>>>>>>>>>>> misconfiguration of it.
>>>>>>>>>>>>>>>>>> 2017-06-16 13:22 GMT+02:00 Naresh N <naresh919 at gmail.com>
>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>  I have tried with the url provided
>>>>>>>>>>>>>>>>>>> http://demo.genode.org/geoserver/wms, getting the
>>>>>>>>>>>>>>>>>>> following error.
>>>>>>>>>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>>>>>>>>>> *Please find the apaahe error log file and attached
>>>>>>>>>>>>>>>>>>> views.py file from proxy folder of geonode for the reference. In view.py in
>>>>>>>>>>>>>>>>>>> line no: 37 is modified (commented host name and placed IP adrdress of
>>>>>>>>>>>>>>>>>>> GeoNode installed system)*
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663803 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663868 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663873 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663876 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663878 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> 67, in proxy
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663881 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663883 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1017, in
>>>>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663886 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663888 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1051, in
>>>>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663890 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663892 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 1013, in
>>>>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663895 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663897 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 864, in
>>>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663899 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   self.send(msg)
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663901 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 826, in
>>>>>>>>>>>>>>>>>>> send
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663905 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   self.connect()
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663907 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/httplib.py", line 807, in
>>>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663909 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663911 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> File "/usr/lib64/python2.7/socket.py", line 571, in
>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663914 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   raise err
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.663916 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690555 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690580 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690584 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> get_response
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690587 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690589 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> 67, in proxy
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690591 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690615 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> request
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690621 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690623 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> _send_request
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690626 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690628 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> endheaders
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690630 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690632 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> _send_output
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690635 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   self.send(msg)
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690637 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> send
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690639 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   self.connect()
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690641 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> connect
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690644 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690646 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> create_connection
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690648 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>>   raise err
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 06:16:29.690650 2017] [:error] [pid 14902]
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:32.233785 2017] [:error] [pid 15208]
>>>>>>>>>>>>>>>>>>> name.
>>>>>>>>>>>>>>>>>>> [Fri Jun 16 16:46:39.030787 2017] [:error] [pid 15135]
>>>>>>>>>>>>>>>>>>> SSL Library Error: -12263 SSL received a record that exceeded the maximum
>>>>>>>>>>>>>>>>>>> permissible length
>>>>>>>>>>>>>>>>>>> Please kindly suggest me, do i need to modify some where
>>>>>>>>>>>>>>>>>>> else?
>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 2:29 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>   Thanks. I will try with the provided url.
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 1:17 PM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>> You can try with http://demo.geonode.org/geoserver/wms.
>>>>>>>>>>>>>>>>>>>>> Not sure about our other question, don't think is possible in the standard
>>>>>>>>>>>>>>>>>>>>> code.
>>>>>>>>>>>>>>>>>>>>> 2017-06-15 9:42 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>   Thanks for the replies. Is any other External WMS
>>>>>>>>>>>>>>>>>>>>>> Layer url is available ,please share me to test.  Is that any mechanism is
>>>>>>>>>>>>>>>>>>>>>> available in case if WFS of Geoserver is disabled,not enabling EDIT option
>>>>>>>>>>>>>>>>>>>>>> while reading error code.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:50 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>> Ah I see, then is not your or geonode fault. This is
>>>>>>>>>>>>>>>>>>>>>>> an issue of that geoserver.
>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:18 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>   This url  http://bhuvan5.nrsc.gov.in/bhuvan/web/ is
>>>>>>>>>>>>>>>>>>>>>>>> external Geoserver of others and I am adding this
>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/web/ url to
>>>>>>>>>>>>>>>>>>>>>>>> GeoNode using Layers ->Add server option. It is adding but it shows the
>>>>>>>>>>>>>>>>>>>>>>>> issue which I mentioned in my earlier mail.
>>>>>>>>>>>>>>>>>>>>>>>> Please kindly add the url
>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms. in demo
>>>>>>>>>>>>>>>>>>>>>>>> GeoNode site  and  can be observed same issue.
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:39 AM, Simone Dalmasso <
>>>>>>>>>>>>>>>>>>>>>>>>> This says 2.0.2 http://bhuvan5.nrsc.gov.
>>>>>>>>>>>>>>>>>>>>>>>>> in/bhuvan/web/
>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 8:07 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>   Earlier I faced layer issue and with your
>>>>>>>>>>>>>>>>>>>>>>>>>> guidance i  have fixed the issue. Please find the link our earlier
>>>>>>>>>>>>>>>>>>>>>>>>>> converstaion http://osgeo-org.1560.x6.nabbl
>>>>>>>>>>>>>>>>>>>>>>>>>> e.com/Layer-Editing-Error-td5323603.html  which
>>>>>>>>>>>>>>>>>>>>>>>>>> contains the steps I followed to install.
>>>>>>>>>>>>>>>>>>>>>>>>>>  I have verified my geoserver instance  and
>>>>>>>>>>>>>>>>>>>>>>>>>> version is 2.7.4. Not able to understand from where you  observed my
>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver version is 2.0.2?.
>>>>>>>>>>>>>>>>>>>>>>>>>>  Please let me know any other information
>>>>>>>>>>>>>>>>>>>>>>>>>> required to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:27 AM, Simone Dalmasso
>>>>>>>>>>>>>>>>>>>>>>>>>> <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>> I see that your geoserver is 2.0.2 with 2.4 it
>>>>>>>>>>>>>>>>>>>>>>>>>>> should be 2.7.x. Could you clarify how you installed it?
>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:36 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, I followed steps from
>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/
>>>>>>>>>>>>>>>>>>>>>>>>>>>> en/2.4.x/tutorials/install_and
>>>>>>>>>>>>>>>>>>>>>>>>>>>> _admin/geonode_install/install
>>>>>>>>>>>>>>>>>>>>>>>>>>>> _geoserver_application.html  to configure
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Geoserver with GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jun 15, 2017 at 11:01 AM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dalmasso <simone.dalmasso at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Have you configured geoserver following the
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2.4 guide? http://docs.geonode.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /en/2.4.x/tutorials/install_an
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> d_admin/geonode_install/instal
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> l_geoserver_application.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-15 7:27 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Kindly suggest to overcome the issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 5:13 PM, Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear Simone,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Copied geoserver.war file from Windows
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Installation of GeoNode2.4.x and pasted into /var/lib/tomcats/webapps
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> folder.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> And on demo site of GeoNode (
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://demo.geonode.org) also I have tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with the url http://bhuvan5.nrsc.gov.in
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /bhuvan/wms   , I am getting same issue.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please help me to resolve
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> My System details:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> GeoNode 2.4 version
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> OS: RHEL7.2, 64 bit machine
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Wed, Jun 14, 2017 at 4:43 PM, Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hi seems that you are missing a
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> configuration in geoserver. How did you install geonode?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://docs.geonode.org/en/mas
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ter/tutorials/admin/geoserver_
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode_security/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 2017-06-14 11:25 GMT+02:00 Naresh N <
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dear All,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  When I am adding WMS Layer URL in GeoNode
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  using ADDLayrers---> Addsever option the following error is getting and
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> EDIT options getting enabled.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please also find the attached screenshot
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with this mail. The WMS url  added  is
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please suggest to solve the issue
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Note: Even the url *
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://bhuvan5.nrsc.gov.in/bhuvan/wms* tested
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with GeoNode demo site  and facing similar  issue as above*
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Naresh
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ______________________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> _________________
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> https://lists.osgeo.org/mailma
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> n/listinfo/geonode-users
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>>>> Simone
>>>>>>>>>>>>>> Simone
>>>>>>>>>>>> Simone
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/3af0359b/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/3af0359b/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/3af0359b/attachment-0003.png>
More information about the geonode-users mailing list
