[GeoNode-users] Issues adding WMS URL in GeoNode
Naresh N
naresh919 at gmail.com
Fri Jun 23 01:58:15 PDT 2017
Dear All,
Thanks for the responses. However, in future version if possible please
include the option like as follows
There should be one button with the name---?'ADD WMS' on click of it
opening like the following window and once we give details like url as
http://bhuvan5.nrsc.gov.in/bhuvan/wms and layer name as
vector:AS_LULC50K_0506
[image: Inline image 2]
Once we will get Load option, the correspond layer details checkbox
should be visible in Map interface of Window like as follows
[image: Inline image 4]
By adding this way enables quickly adding the layer into Map window if
user knows the Layer name ,url directly and in coding level there is no
requirement adding url in proxy, since from map client/Genode interface
will directly send the requests to corresponding server and fetches the
response.
Best Regards,
Naresh. N
On Fri, Jun 23, 2017 at 1:51 PM, Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Hey Naresh,
> if I correctly remember from heart I normally do it this way:
> - create new map
> - choose hadd layer select
> > there you´ll find add server
> - add wms server in question
> - load layers from wms
> However, maybe publishing the layer directly via your geoserver instance
> does as well what you´re looking for:
> find the docmentation here:
> http://docs.geonode.org/en/master/tutorials/advanced/adv_
> data_mgmt/adding_data/add_wmscascade.html
> cheers,
> toni
> CSGIS
> Kolonnadenstraße 1
> 04109 Leipzig
> Mobil +49/ (0) 176 6680 3198
> Tel +49/ (0) 341 24 04 738
> Fax +49/ (0) 341 24 04 73
> Web http://csgis.de
> Am 23.06.2017 um 10:14 schrieb geonode-users-request at lists.osgeo.org:
> Message: 1
> Date: Fri, 23 Jun 2017 13:44:45 +0530
> From: Naresh N <naresh919 at gmail.com>
> To: Simone Dalmasso <simone.dalmasso at gmail.com>
> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
> Subject: Re: [GeoNode-users] Issues adding WMS URL in GeoNode
> Message-ID:
> <CAKAPXzO5fQn0Kjwaq0CbYbOSuj-RKJM3Yyuoq5g-rLAMcJ2pRA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Dear Simone,
> Thanks for the response.
> Is it possible to add WMS Layer with Layer Name and URL to GeoNode
> interface. If not where do I need to write a script for taking the input
> WMS URL , Layer Name and adding to Overlay layers section in Map window
> Thanks,
> Naresh
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/4a98050a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/4a98050a/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170623/4a98050a/attachment-0003.png>
More information about the geonode-users
