[GeoNode-users] SLD and Geonode
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Jun 27 03:19:44 PDT 2017
Dear Francesco,
there is some ongoing work on this topic from our side.
We are working both on QGIS side in order to fix SLD exporter issues (of
course it won't be possible to replicate exactly *all* the QGIS style
features, but at least it will be possible to replicate most of them) and
on GeoNode side by trying to:
1. Fix an issue with GeoNode replacing the content of the attached SLD file
with the a default one
2. Implement on GeoNode a functionality to allow users to upload SLDs from
the Layer Editor GUI
Currently, the easiest way to do it is:
a) Upload the Layer as is; this will create on GeoServer a Style named
exactly equal to the filename
b) Go to GeoServer Admin > Styles and replace the style with the correct
one by uploading it
[image: Inline image 1]
*NOTICE: **You need GeoServer administrator rights in order to access this
page.*
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, Jun 27, 2017 at 12:01 PM, Fosco Ventura <foscone at gmail.com> wrote:
> Dear list,
> I have a question about SLD in Geonode/Geoserver.
> I have noted that QGIS doesn't export SLD in the way that Geoserver want
> and I have to use UDIG in order to get the correct SLD file.
> Moreover, when I upload the SHP with its SLD file, I have to upload twice
> the same file to make it accepted by Geoserver.
> Is there any smarter way to do this operation?
> Thanks a lot
> Fosco
> Fosco
> http://studiotypo.it/
> http://www.studiotypo.it/fosco/
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170627/b43cdefb/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170627/b43cdefb/attachment-0001.png>
More information about the geonode-users
