[GeoNode-users] Issue on updateip in migration to 2.6
Simone Dalmasso simone.dalmasso at gmail.com
Fri Jun 30 02:45:53 PDT 2017
Annalisa, for the geoserver preview make sure to set the proxy base url
parameter in the geoserver global settings (from ui).
For the thumbs it could be still some authentication issues, did you follow
all the steps in the docs?
http://docs.geonode.org/en/master/tutorials/admin/geoserver_geonode_security/index.html?highlight=oauth2
2017-06-30 11:30 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Well, I don't know why, but this morning layers and maps in geonode are
> displayed correctly, no more pink tiles!
> Layer's thumbs aren't displayed even after having setted them with edit
> layer button, except for some. I set permissions
> to /var/www/geonode/uploaded/thumbs dir to 664 (some files were 644) and
> owner to www-data.
> Preview layers in Geoserver still doesn't work. I attach wms error.
> After these errors, geonode is thrown out and authentication fails, when
> browsing in geoserver.
> I also attach errors.zip with logs from apache and tomcat.
> Thanks!
> 2017-06-29 14:22 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Annalisa, the distribution url is not used in GeoNode 2.6, it's in the db
>> because the migrations don't delete fields.
>> For the display issue check the http request made by the browser and you
>> should be able to see more info about the error.
>> 2017-06-29 11:48 GMT+02:00 Annalisa Schiavon <annalisa.schiavon at gmail.com
>>> Hi all,
>>> I'm migrating from geonode 2.4 to 2.6.
>>> I've restored geonode DB and geonode-data DB (DB postgres with all my
>>> vector layers) in a new server (a fresh ubuntu 16.04) than I've launched
>>> $geonode migrate --fake-initial.
>>> I also launched a geonode-updateip 192.168.31.80 (my internal ip for
>>> now) for authentication issues. But the "distribution url" field in
>>> "base_resourcebase" table still has the old ip.
>>> I found this issue: https://github.com/GeoNode/geonode/issues/1694 .
>>> How can I resolve? Preview layers in Geoserver doesn't work and layers and
>>> maps in geonode aren't displayed.
>>> Thanks
>>> Annalisa
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170630/52076f06/attachment.html>
More information about the geonode-users mailing list
