[GeoNode-users] Authentication, Authorisation against LDAP
Christian Braun christian.braun at list.lu
Thu Mar 2 06:11:09 PST 2017
Thanks for your quick and honest answer.
What is then the point of GeoNode if I can not authenticate and authorise against a LDAP server to serve, in my case, several hundred users?
Thanks,
Christian
Christian Braun, MSc.
Research Associate for Geocomputation
eScience Unit
Environmental Research and Innovation (ERIN) Department
Luxembourg Institute of Science and Technology (LIST)
41, rue du Brill
L-4422 Belvaux
Tel: +352 42 59 91 - 6608
Fax : +352 275 885
E-mail : christian.braun at list.lu
-----Simone Dalmasso <simone.dalmasso at gmail.com> wrote: -----To: Christian Braun <christian.braun at list.lu>
From: Simone Dalmasso <simone.dalmasso at gmail.com>
Date: 02.03.2017 15:04
Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] Authentication, Authorisation against LDAP
Hi Christian,I'm afraid this doesn't work as you expect, the authentication can work but the authorisation no because it's relying on local users. You would have to extend geonode to support that.
2017-03-02 13:50 GMT+01:00 Christian Braun <christian.braun at list.lu>:
Dear list,
I do have a fresh Geonode 2.4.1 installation from the Ubuntu stable repository running.
I also tried to replicate with a checkout from Git with latest 2.5 version. Same behaviour.
I want to authenticate against our local corporate LDAP/Active Directory. This is working fine so far, I can login with my corporate credentials. User flags, like "superuser", "is_staff" and "is_active" are being replicated accordingly if I set AUTH_LDAP_USER_FLAGS_BY_GROUP. LDAP groups of the user are also replicated in the admin interface.
But, how do I get group membership of authenticated users to work with Geonode group permissions and authorisation? Groups nor users are being replicated in the Geonode UI and I can not assign any rules, e.g. access to layers...
This doesn't work as well with locally created users [1].
Do I miss any steps of configuration to make this work? I think these things should work out-of-the-box, right?
Many thanks in advance,
Christian
[1] http://docs.geonode.org/en/master/reference/security.html#permissions-and-geonode-objects
eScience Unit
41, rue du Brill
L-4422 Belvaux
Fax : +352 275 885
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
SimoneĀ
More information about the geonode-users mailing list
