[GeoNode-users] Geonode account registrations don't work
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Mar 10 03:01:37 PST 2017
The easiest way is to copy the installed apps block from the default
settings, see in github, and copy in your /etc/geonode/local_settings.py
uncommenting notifications.
Il giorno ven 10 mar 2017 alle 11:36 Adam Lawrence <alaw005 at gmail.com> ha
scritto:
> Hi, thank you for the advice. Can you please advise how to access the
> installed apps settings if I've used the PPA install method or is that not
> possible?
> On 10 March 2017 at 21:55, Simone Dalmasso <simone.dalmasso at gmail.com>
> wrote:
> Hi, you have to also uncomment "notifications" in the settings installed
> apps. then run syncdb. If that is missing from the doc then we need to fix
> it.
> 2017-03-10 5:09 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
> Hi,
> I have using the Ubuntu PPA install of geonode but user registration does
> not work. I get the error below and understand that the "notifications"
> module is not enabled in python, e.g. refer
> https://github.com/GeoNode/geonode/issues/2114. How do I enable
> notifications given I used the quick install method?
> The steps I followed to configure email server and user registration were
> Open config file::
> sudo nano /etc/geonode/local_settings.py
> Locate the following email and user registration settings::
> #REGISTRATION_OPEN = False
> #ACCOUNT_APPROVAL_REQUIRED = False
> #ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
> #ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
> # Uncomment the following to receive emails whenever there are
> errors in GeoNode
> # or to be notified of new user requests when
> ACCOUNT_APPROVAL_REQUIRED has been set.
> #ADMINS = (
> # ('John', 'john at example.com'),
> # Uncomment the following to use a Gmail account as the email
> backend
> #EMAIL_USE_TLS = True
> #EMAIL_HOST = 'smtp.gmail.com'
> #EMAIL_HOST_USER = 'youremail at gmail.com'
> #EMAIL_HOST_PASSWORD = 'yourpassword'
> #EMAIL_PORT = 587
> Update these settings according to your requirements. Then do the
> following to ensure works:
> sudo geonode syncdb
> sudo service apache2 restart
> sudo service tomcat7 restart
> [[This does not work as "notification" module not enabled in django
> settings file]]
> ProgrammingError at /account/signup/
> relation "notification_noticetype" does not exist
> LINE 1: ...iption", "notification_noticetype"."default" FROM "notificat...
> Regards
> Adam
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170310/25de1eba/attachment.html>
More information about the geonode-users
