[GeoNode-users] Geonode account registrations don't work
Adam Lawrence
alaw005 at gmail.com
Fri Mar 10 14:23:01 PST 2017
Thank you and I like that solution better! Only problem is I still get an
500 error, and when I tried syncdb I get the following error:
$ sudo geonode syncdb
File "/usr/bin/django-admin.py", line 5, in <module>
management.execute_from_command_line()
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
399, in execute_from_command_line
utility.execute()
File
392, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File
261, in fetch_command
commands = get_commands()
File
107, in get_commands
apps = settings.INSTALLED_APPS
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 54,
in __getattr__
self._setup(name)
File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line 49,
in _setup
self._wrapped = Settings(settings_module)
128, in __init__
mod = importlib.import_module(self.SETTINGS_MODULE)
File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line
40, in import_module
__import__(name)
File "/usr/local/lib/python2.7/dist-packages/geonode/settings.py", line
871, in <module>
from local_settings import * # noqa
File "/usr/local/lib/python2.7/dist-packages/geonode/local_settings.py",
line 110, in <module>
INSTALLED_APPS = geonode.settings.INSTALLED_APPS + ('notification',)
AttributeError: 'module' object has no attribute 'settings'
On 11 March 2017 at 00:45, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> oh right I forgot the geonode apps. Ok discard the previous and try with
> this one
> 2017-03-10 12:37 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>> On 11 March 2017 at 00:16, Adam Lawrence <alaw005 at gmail.com> wrote:
>>> Thank you, but unfortunately it still doesn't work. I have pasted the
>>> following into my local_sttings.py from https://github.com/GeoNod
>>> e/geonode/blob/master/geonode/settings.py but I now get a server error
>>> 500 code on all pages. I did a sudo service apache2 restart after the
>>> change but do I also need to restart something else?
>>> INSTALLED_APPS = (
>>> 'modeltranslation',
>>> # Boostrap admin theme
>>> # 'django_admin_bootstrapped.bootstrap3',
>>> # 'django_admin_bootstrapped',
>>> # Apps bundled with Django
>>> 'django.contrib.auth',
>>> 'django.contrib.contenttypes',
>>> 'django.contrib.sessions',
>>> 'django.contrib.sites',
>>> 'django.contrib.admin',
>>> 'django.contrib.sitemaps',
>>> 'django.contrib.staticfiles',
>>> 'django.contrib.messages',
>>> 'django.contrib.humanize',
>>> 'django.contrib.gis',
>>> # Third party apps
>>> # Utility
>>> 'pagination',
>>> 'taggit',
>>> 'treebeard',
>>> 'friendlytagloader',
>>> 'geoexplorer',
>>> 'leaflet',
>>> 'django_extensions',
>>> #'geonode-client',
>>> # 'haystack',
>>> 'autocomplete_light',
>>> 'mptt',
>>> # 'modeltranslation',
>>> 'djcelery',
>>> 'storages',
>>> 'floppyforms',
>>> # Theme
>>> "pinax_theme_bootstrap_account",
>>> "pinax_theme_bootstrap",
>>> 'django_forms_bootstrap',
>>> # Social
>>> 'account',
>>> 'avatar',
>>> 'dialogos',
>>> 'agon_ratings',
>>> # 'notification',
>>> 'announcements',
>>> 'actstream',
>>> 'user_messages',
>>> 'tastypie',
>>> 'polymorphic',
>>> 'guardian',
>>> 'oauth2_provider',
>>> ) + GEONODE_APPS
>>> On 11 March 2017 at 00:01, Simone Dalmasso <simone.dalmasso at gmail.com>
>>> wrote:
>>>> The easiest way is to copy the installed apps block from the default
>>>> settings, see in github, and copy in your /etc/geonode/local_settings.py
>>>> uncommenting notifications.
>>>> Il giorno ven 10 mar 2017 alle 11:36 Adam Lawrence <alaw005 at gmail.com>
>>>> ha scritto:
>>>>> Hi, thank you for the advice. Can you please advise how to access the
>>>>> installed apps settings if I've used the PPA install method or is that not
>>>>> possible?
>>>>> On 10 March 2017 at 21:55, Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> wrote:
>>>>> Hi, you have to also uncomment "notifications" in the settings
>>>>> installed apps. then run syncdb. If that is missing from the doc then we
>>>>> need to fix it.
>>>>> 2017-03-10 5:09 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>>>>> Hi,
>>>>> I have using the Ubuntu PPA install of geonode but user registration
>>>>> does not work. I get the error below and understand that the
>>>>> "notifications" module is not enabled in python, e.g. refer
>>>>> https://github.com/GeoNode/geonode/issues/2114. How do I enable
>>>>> notifications given I used the quick install method?
>>>>> The steps I followed to configure email server and user registration
>>>>> were
>>>>> Open config file::
>>>>> sudo nano /etc/geonode/local_settings.py
>>>>> Locate the following email and user registration settings::
>>>>> #REGISTRATION_OPEN = False
>>>>> #ACCOUNT_APPROVAL_REQUIRED = False
>>>>> #ACCOUNT_EMAIL_CONFIRMATION_EMAIL = False
>>>>> #ACCOUNT_EMAIL_CONFIRMATION_REQUIRED = False
>>>>> # Uncomment the following to receive emails whenever there
>>>>> are errors in GeoNode
>>>>> # or to be notified of new user requests when
>>>>> ACCOUNT_APPROVAL_REQUIRED has been set.
>>>>> #ADMINS = (
>>>>> # ('John', 'john at example.com'),
>>>>> # Uncomment the following to use a Gmail account as the
>>>>> email backend
>>>>> #EMAIL_USE_TLS = True
>>>>> #EMAIL_HOST = 'smtp.gmail.com'
>>>>> #EMAIL_HOST_USER = 'youremail at gmail.com'
>>>>> #EMAIL_HOST_PASSWORD = 'yourpassword'
>>>>> #EMAIL_PORT = 587
>>>>> Update these settings according to your requirements. Then do
>>>>> the following to ensure works:
>>>>> sudo geonode syncdb
>>>>> sudo service tomcat7 restart
>>>>> [[This does not work as "notification" module not enabled in django
>>>>> settings file]]
>>>>> ProgrammingError at /account/signup/
>>>>> relation "notification_noticetype" does not exist
>>>>> LINE 1: ...iption", "notification_noticetype"."default" FROM "notificat...
>>>>> Regards
>>>>> Adam
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Simone
>>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170311/eff95d25/attachment-0001.html>
More information about the geonode-users
