[GeoNode-users] Remove ability to Explore People from geonode
Adam Lawrence alaw005 at gmail.com
Sat Mar 11 01:52:49 PST 2017
Thank you. My next question was going to be where do I find these files,
but as result of answers to another query I have found that the geonode
files are in the /usr/local/lib/python2.7/dist-packages/geonode folder.
Thank you for the help.
On 10 March 2017 at 21:58, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> You have to modify the geonode templates to do that, the "base.html"
> removing the entry in the menu bar. If to be 100% sure that no one can
> access it you also have to remove this line https://github.com/
> GeoNode/geonode/blob/master/geonode/urls.py#L82
> 2017-03-10 5:19 GMT+01:00 Adam Lawrence <alaw005 at gmail.com>:
>> Hi,
>> I have installed geonode in ubuntu using the GeoNode PPA repository. I
>> have it working but want to remove ability to "Explore People" under the
>> People menu. I basically don't want to make public the list of usernames.
>> It seems this should be a configuration setting but I can't locate any.
>> Please can someone advise how to do this?
>> Regards
>> Adam
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170311/c1bd51a4/attachment.html>
More information about the geonode-users mailing list
