[GeoNode-users] Custom background layers not in Thumbnail
John, Steffen
s.john at atenekom.eu
Thu Mar 16 01:43:35 PDT 2017
I created custom map base layers, which are added to every newly
created map. When saving this map, the thumbnail is created without the
basemap on it.
To define the basemaps, i added a gxp plugin, correspondingly to the
BingSource, based on a WMS. May be I missed something?
Do you have any idea, what I have done wrong?
Thank you so much for your help.
Here is the code:
gxp.plugins.WebAtlasFarbeSource = Ext.extend(gxp.plugins.LayerSource, {
ptype: "gxp_webatlasfarbesource",
title: "WebAtlasDE Farbe",
webAtlasFarbeTitle: "WebAtlasDEFarbe",
url: "https://sg.geodatenzentrum.de/wms_webatlasde__UUID",
attribution: "© GeoBasis-DE / <b>BKG</b> ("+year+")",
createStore: function() {
var layers = [
new OpenLayers.Layer.WMS(this.webAtlasFarbeTitle,
this.url,
{layers: ["webatlasde"],
format:"image/png",
tiled: true
attribution : this.attribution
this.store = new GeoExt.data.LayerStore({
layers: layers,
fields: [
{name: "source", type: "string"},
{name: "name", type: "string", defaultValue:
"webatlasdefarbe"},
{name: "abstract", type: "string", mapping:
"attribution"},
{name: "group", type: "string", defaultValue:
"background"},
{name: "fixed", type: "boolean", defaultValue: true},
{name: "selected", type: "boolean"}
this.store.each(function(l) {
l.set("group", "background");
this.fireEvent("ready", this);
createLayerRecord: function(config) {
var record;
var index = this.store.findExact("name", config.name);
if (index > -1) {
record =
this.store.getAt(index).copy(Ext.data.Record.id({}));
var layer = record.getLayer().clone();
// set layer title from config
if (config.title) {
* Because the layer title data is duplicated, we have
* to set it in both places. After records have been
* added to the store, the store handles this
* synchronization.
layer.setName(config.title);
record.set("title", config.title);
// set visibility from config
if ("visibility" in config) {
layer.visibility = config.visibility;
record.set("selected", config.selected || false);
record.set("source", config.source);
record.set("name", config.name);
if ("group" in config) {
record.set("group", config.group);
record.data.layer = layer;
record.commit();
return record;
Ext.preg(gxp.plugins.WebAtlasFarbeSource.prototype.ptype,
gxp.plugins.WebAtlasFarbeSource);
More information about the geonode-users
