[GeoNode-users] Custom background layers not in Thumbnail
Daniel Victoria daniel.victoria at gmail.com
Thu Mar 16 07:01:30 PDT 2017
Hi John,
I had some problems when dealing with https and certificate name mismatch.
Not sure if it's your case. Anyway, my problem occured because I'm behing a
reverse proxy with multiple certificates and python 2.7 does not like this.
The problem should be solved by the SNI (Server Name Indication),
implemented in python 3. But that is not used by Geonode yet.
I opened an issue about this, just in case:
https://github.com/GeoNode/geonode/issues/2695
Cheers
Daniel
On Thu, Mar 16, 2017 at 10:40 AM, John, Steffen <s.john at atenekom.eu> wrote:
> appearently, the https in the URL was the problem. When I enter the URL
> with http:// everything works fine.
> What may be the reason, that that requests to https-sites are blocked?
> Thanks for help!
> Am Donnerstag, den 16.03.2017, 11:19 +0100 schrieb Simone Dalmasso:
> Hm, the bbox is in 900913 and it seems acceptable. Any chance that your
> server is unable to fetch those images because of something blocking the
> connection?
> 2017-03-16 11:09 GMT+01:00 John, Steffen <s.john at atenekom.eu>:
> Hi,
> Yes, this is waht i'm doing. I started debugging, and found out that tiles
> with really weired bounding box values are send to
> geonode.maps.views.map_thumbnail.
> but some of the tiles of wms_webatlas have correct bounding boxes. Also
> the bounding boxes of the geoserver-Wms are correct.
> What may be the problem? I guess it has something to do with the layer
> definition..
> Any further ideas?
> This are the images sended to map_thumbnail():
> <img class="olTileImage" style="visibility: inherit; opacity: 1; position:
> absolute; left: 268px; top: 36px; width: 256px; height: 256px;" src="
> https://sg.geodatenzentrum.de/wms_webatlasde_grau__
> UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&
> SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=
> EPSG%3A900913&BBOX=626172.135625,6887893.491875,1252344.
> 27125,7514065.6275&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=626172.135625,6887893.491875,1252344.27125,7514065.6275&WIDTH=256&HEIGHT=256>
> absolute; left: 12px; top: 36px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=0,6887893.491875,626172.135625,7514065.
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=0,6887893.491875,626172.135625,7514065.6275&WIDTH=256&HEIGHT=256>
> absolute; left: 268px; top: 292px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=626172.135625,6261721.35625,1252344.
> 27125,6887893.491875&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=626172.135625,6261721.35625,1252344.27125,6887893.491875&WIDTH=256&HEIGHT=256>
> absolute; left: 268px; top: -220px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=626172.135625,7514065.6275,1252344.
> 27125,8140237.763125&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=626172.135625,7514065.6275,1252344.27125,8140237.763125&WIDTH=256&HEIGHT=256>
> absolute; left: 524px; top: 36px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=1252344.27125,6887893.491875,1878516.
> 406875,7514065.6275&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=1252344.27125,6887893.491875,1878516.406875,7514065.6275&WIDTH=256&HEIGHT=256>
> absolute; left: 12px; top: 292px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=0,6261721.35625,626172.135625,6887893.
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=0,6261721.35625,626172.135625,6887893.491875&WIDTH=256&HEIGHT=256>
> absolute; left: 12px; top: -220px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=0,7514065.6275,626172.135625,8140237.
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=0,7514065.6275,626172.135625,8140237.763125&WIDTH=256&HEIGHT=256>
> absolute; left: 524px; top: 292px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=1252344.27125,6261721.35625,1878516.
> 406875,6887893.491875&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=1252344.27125,6261721.35625,1878516.406875,6887893.491875&WIDTH=256&HEIGHT=256>
> absolute; left: 524px; top: -220px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=1252344.27125,7514065.6275,1878516.
> 406875,8140237.763125&WIDTH=256&HEIGHT=256">
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=1252344.27125,7514065.6275,1878516.406875,8140237.763125&WIDTH=256&HEIGHT=256>
> absolute; left: -244px; top: 36px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=-626172.135625,6887893.491875,0,
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=-626172.135625,6887893.491875,0,7514065.6275&WIDTH=256&HEIGHT=256>
> absolute; left: -244px; top: 292px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=-626172.135625,6261721.35625,0,
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=-626172.135625,6261721.35625,0,6887893.491875&WIDTH=256&HEIGHT=256>
> absolute; left: -244px; top: -220px; width: 256px; height: 256px;" src="
> EPSG%3A900913&BBOX=-626172.135625,7514065.6275,0,8140237.
> <https://sg.geodatenzentrum.de/wms_webatlasde_grau__UUID?LAYERS=webatlasde_grau&FORMAT=image%2Fpng&TILED=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A900913&BBOX=-626172.135625,7514065.6275,0,8140237.763125&WIDTH=256&HEIGHT=256>
> Am Donnerstag, den 16.03.2017, 10:21 +0100 schrieb Simone Dalmasso:
> Hi, are you saving the thumbnail through the set thumbnail button in map
> detail -> edit map?
> This is the only way to get the background rendered in the thumbnail
> 2017-03-16 9:43 GMT+01:00 John, Steffen <s.john at atenekom.eu>:
> Hi,
> I created custom map base layers, which are added to every newly
> created map. When saving this map, the thumbnail is created without the
> basemap on it.
> To define the basemaps, i added a gxp plugin, correspondingly to the
> BingSource, based on a WMS. May be I missed something?
> Do you have any idea, what I have done wrong?
> Thank you so much for your help.
> Here is the code:
> gxp.plugins.WebAtlasFarbeSource = Ext.extend(gxp.plugins.LayerSource, {
>     ptype: "gxp_webatlasfarbesource",
>     title: "WebAtlasDE Farbe",
>     webAtlasFarbeTitle: "WebAtlasDEFarbe",
>     url: "https://sg.geodatenzentrum.de/wms_webatlasde__UUID",
>     attribution: "© GeoBasis-DE / <b>BKG</b> ("+year+")",
>     createStore: function() {
>         var layers = [
>              new OpenLayers.Layer.WMS(this.webAtlasFarbeTitle,
>                                    this.url,
>                                    {layers: ["webatlasde"],
>                                    format:"image/png",
>                                    tiled: true
>                                        attribution : this.attribution
>         this.store = new GeoExt.data.LayerStore({
>             layers: layers,
>             fields: [
>                 {name: "source", type: "string"},
>                 {name: "name", type: "string", defaultValue:
> "webatlasdefarbe"},
>                 {name: "abstract", type: "string", mapping:
> "attribution"},
>                 {name: "group", type: "string", defaultValue:
> "background"},
>                 {name: "fixed", type: "boolean", defaultValue: true},
>                 {name: "selected", type: "boolean"}
>         this.store.each(function(l) {
>             l.set("group", "background");
>         this.fireEvent("ready", this);
>     createLayerRecord: function(config) {
>         var record;
>         var index = this.store.findExact("name", config.name);
>         if (index > -1) {
>             record =
> this.store.getAt(index).copy(Ext.data.Record.id({}));
>             var layer = record.getLayer().clone();
>             // set layer title from config
>             if (config.title) {
>                  * Because the layer title data is duplicated, we have
>                  * to set it in both places.  After records have been
>                  * added to the store, the store handles this
>                  * synchronization.
>                 layer.setName(config.title);
>                 record.set("title", config.title);
>             // set visibility from config
>             if ("visibility" in config) {
>                 layer.visibility = config.visibility;
>             record.set("selected", config.selected || false);
>             record.set("source", config.source);
>             record.set("name", config.name);
>             if ("group" in config) {
>                 record.set("group", config.group);
>             record.data.layer = layer;
>             record.commit();
>         return record;
> Ext.preg(gxp.plugins.WebAtlasFarbeSource.prototype.ptype,
> gxp.plugins.WebAtlasFarbeSource);
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170316/0b597624/attachment-0001.html>
More information about the geonode-users mailing list
