[GeoNode-users] gettiting an error to open Geonode and geoserver on Ubuntu 14.04
Yogini Jalidar Sonawane
yoginij.sonawane at st.niituniversity.in
Tue May 2 22:25:32 PDT 2017
Dear sir,
On Friday I was installing postgresql and postgis with the help of this
code.
sudo apt-get install postgresql-9.3-postgis-2.1
but my system switched off in the middle. and process remain uncompleted.
Now I am getting an error to open GeoNode as well as GeoServer as I
attached screen shorts.
Wha should I do next?
*History of commands on terminal *
yogini at yogini:~$ history
1 cd /
/usr/lib/python2.7/dist-packages/geoexplorer/static/geoexplorer/script
2 cd
3 ls
4 "source": {
5 pip install django-geoexplorer
6 locate geoexplorer
7 locate geoexplorer | grep .js
8 cd Desktop/
9 ls
10 pwd
11 ls
12 cd/
13 cd geonode
14 ocate geoexplorer
15 locate geoexplorer
16
17 grep .js
18 locate geoserver
19 locate geoserver | grep wms
20 geoserver/wms
21 /usr/lib/python2.7/dist-packages/geonode/local_settings.py.
22 geonode.catalogue.backends.pycsw_local
23 cd/ geonode.catalogue.backends.pycsw_local
24 cd
25 cd/
26 cd /etc/geonode/local_settings.py
27 cd sudo gedit
28 sudo gedit /usr/lib/python2.7/dist-packages/geonode/local_settings.py
29 locate_Local_settings.py
30 locate Local_settings.py
31 Locate_local_settings.py
32 locate Local_settings.py
33 locate local_settings.py
34 history
35 sudo apt-get install virtualbox-dkms
36 sudo apt-get install linux-headers-generic build-essential dkms
37 sudo apt-get remove --purge virtualbox-dkms
38 sudo apt-get install virtualbox-dkms
39 cd <my_geonode>/static/img
40 cd geonode
41 cd/
42 cd /
43 sudo -u postgres createuser -P geonode
44 sudo -u postgres createdb -O geonode geonode
45 sudo -u postgres createdb -O geonode geonode_data
46 sudo su postgres
47 sudo gedit /etc/postgresql/9.3/main/pg_hba.conf
48 sudo service postgresql restart
49 psql -U geonode geonode
50 cd /geonode
51 apt-get install geoserver-css
52 yes
53 sudo su -
54 1101
55 apt-get install geoserver-css
56 sudo su -
57 apt-get install geoserver-css
58 sudo su apt-get install geoserver-css
59 pip install cartoview
60 cd / django-geonode-client
61 install geoserver-css
62 django-geonode-client
63 sudo apt-get install geoserver css
64 cd/ geoserver
65 cd/ usr/share/geoserver
66 sudo apt-get install geoserver-css
67 sudo apt-get install postgresql-9.3-postgis-2.1
68 sudo apt-get install geoserver-css
69 sudo apt-get install geoserver-css
70 sudo apt-get install geoserver-script
71 sudo apt-get install geoserver-css
72 restart geoserver
73 restart
74 sudo -i -u test1
75 psql
76 psql -d postgres
77 sudo apt-get update
78 sudo apt-get install postgresql postgresql-contrib
79 sudo -i -u postgres
80 psql
81 sudo -i -u postgres
82 sudo apt-get install geoserver-css
83 sudo apt-get install geoserver-postgres
84 sudo apt-get update
85 sudo apt-get install postgresql postgresql-contrib
86 sudo -i -u postgres
87 postgres-xc
88 sudo apt-get update
89 sudo apt-get updatesudo apt-get install tomcat7
90 sudo apt-get install tomcat7
91 get install tomcat7
92 sudo apt-get install tomcat7
93 sudo apt get install tomcat7
94 get install tomcat7
95 sudo apt get install tomcat7
96 sudo apt install tomcat7
97 sudo apt-get install tomcat7
98 sudo nano /etc/default/tomcat7
99 sudo service tomcat7 restart
100 /user/local/webhelpdesk
101 sudo apt-get install openjdk-7-jre-headless
102 sudo apt-get install tomcat7 tomcat7-admin
103 sudo vi /var/lib/tomcat7/conf/tomcat-users.xml
104 sudo vi /etc/default/tomcat7
105 sudo vi /etc/tomcat7/server.xml
106 sudo apt-get install libapache2-mod-proxy-html
107 apt-get -f install
108 sudo apt get install
109 [4~
110 1101
111 sudo apt-get update
112 cd /etc/
113 ls
114 sudo service geoserver start
115 history
116 sudo apt-get install openjdk-7-jre-headless
117 sudo apt-get install postgresql-9.1 postgresql-contrib-9.1 pgadmin3
118 sudo apt-add-repository ppa:ubuntu-wine/ppa
119 sudo apt-get update
120 sudo apt-get install postgresql-9.1 postgresql-contrib-9.1 pgadmin3
121 sudo dpkg --configure -a
122 sudo apt-get install postgresql-9.1 postgresql-contrib-9.1 pgadmin3
123 sudo chown -R USER_NAME /usr/share/geoserver/
124 yogini
125 sudo chown -R USER_NAME /usr/share/geoserver/
126 yogini
127 cd geoserver/bin
128 sh startup.sh
129 sudo apt-get purge openjdk\*
130 sudo add-apt-repository ppa:webupd8team/java
131 sudo apt-get update
132 sudo apt-get install oracle-java7-installer
133 sudo apt-get install tomcat7
134 sudo vi /etc/default/tomcat7
135 sudo service tomcat7 restart
136 sudo apt-get install openjdk-7-jre-headless
137 sudo apt-get install tomcat7 tomcat7-admin
138 sudo apt-get install -f
139 sudo apt-get remove --purge getdeb-repository
140 sudo apt-get install tomcat7 tomcat7-admin
141 sudo dpkg --configure -a
142 sudo apt-get install tomcat7 tomcat7-admin
143 cat /etc/apt/sources.list
144 sudo vi /var/lib/tomcat7/conf/tomcat-users.xml
145 sudo vi /etc/default/tomcat7
146 sudo vi /etc/tomcat7/server.xml
147 history
148 sudo
149 sudo apt-get installmapache2
150 sudo add-apt-repository ppa:webupa
151 sudo apt-get installmapache8team/java
152 sudo apt-get install tomcat7 tomcat7-admin
153 sudo vi/var/lib/tomcat7/conf/tomcat-users.xml
154 sudo /etc/init,d/tomcat7 restart
155 sudo aptitude install tomcat6
156 history
157 sudo service tomcat7 stop
158 sudo service tomcat7 start
159 sudo cp /home/geonode/geonode/downloaded/geoserver.war
/var/lib/tomcat7/webapps/
160 sudo apt-get install
161 sudo dpkg --configure -a
162 sudo apt-get install
163 sudo apt-get install -f
164 cat /etc/apt/sources.list
165 sudo apt-get remove --purge getdeb-repository
166 sudo apt-get install
167 sudo dpkg -i --force-overwrite
/var/cache/apt/archives/libogremain-1.7.3_1.7.3-ogredev-natty3_i386.deb
168 sudo apt-get autoremove
169 sudo apt-get update
170 echo "export GEOSERVER_HOME=/usr/share/geoserver" >> ~/.profile
171 . ~/.profile
172 echo "export GEOSERVER_HOME=/usr/share/geoserver"
173 export GEOSERVER_HOME=/usr/share/geoserver
174 history
175 sudo apt-get update
176 sudo dpkg -P oracle-java7-installer
177 sudo apt-get -f install
178 apt-get autoremove
179 sudo apt-get update
180 sudo apt-get update && sudo apt-get upgrade
181 history
yogini at yogini:~$
*List of errors:*
connect (101: Network is unreachable)
W: Failed to fetch
http://dl.google.com/linux/talkplugin/deb/dists/stable/main/i18n/Translation-en_IN
Cannot initiate the connection to dl.google.com:80
(2404:6800:4003:c00::5d). - connect (101: Network is unreachable)
W: Failed to fetch
W: Failed to fetch
http://dl.google.com/linux/talkplugin/deb/dists/stable/main/binary-amd64/Packages
W: Failed to fetch
http://dl.google.com/linux/talkplugin/deb/dists/stable/main/binary-i386/Packages
W: Failed to fetch http://extras.ubuntu.com/ubuntu/dists/trusty/Release.gpg
Cannot initiate the connection to extras.ubuntu.com:80
(2001:67c:1360:8c01::23). - connect (101: Network is unreachable)
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/main/i18n/Translation-en_IN
W: Failed to fetch
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/main/source/Sources Cannot
initiate the connection to extras.ubuntu.com:80 (2001:67c:1360:8c01::23). -
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/main/binary-amd64/Packages
W: Failed to fetch
http://extras.ubuntu.com/ubuntu/dists/trusty/main/binary-i386/Packages
E: Some index files failed to download. They have been ignored, or old ones
used instead.
yogini at yogini:~$ ^C
yogini at yogini:~$ sudo apt-get install postgresql-9.3-postgis-2.1
Reading package lists... Done
Building dependency tree
Reading state information... Done
postgresql-9.3-postgis-2.1 is already the newest version.
The following packages were automatically installed and are no longer
required:
geoserver-geonode libproj-dev libxml2-dev libxslt1-dev
linux-image-extra-3.13.0-32-generic linux-signed-image-3.13.0-32-generic
python-amqp python-anyjson python-awesome-slugify python-billiard
python-bs4
python-celery python-chardet-whl python-cl python-colorama
python-colorama-whl python-dateutil python-dialogos python-distlib
python-distlib-whl python-django python-django-activity-stream
python-django-appconf python-django-autocomplete-light
python-django-bootstrap3-datetimepicker python-django-celery
python-django-downloadview python-django-extensions
python-django-forms-bootstrap python-django-friendly-tag-loader
python-django-geoexplorer python-django-guardian python-django-jsonfield
python-django-leaflet python-django-modeltranslation python-django-mptt
python-django-nose python-django-pagination python-django-polymorphic
python-django-south python-django-taggit python-django-taggit-templatetags
python-django-templatetag-sugar python-egenix-mxdatetime
python-egenix-mxtools python-geolinks python-geonode-agon-ratings
python-geonode-announcements python-geonode-arcrest python-geonode-avatar
python-geonode-notification python-geonode-user-accounts
python-geonode-user-messages python-gisdata python-gsconfig
python-gsimporter python-html5lib python-html5lib-whl python-kombu
python-librabbitmq python-mailer python-memcache python-mimeparse
python-multipartposthandler python-owslib python-paver
python-pinax-theme-bootstrap python-pinax-theme-bootstrap-account
python-pip
python-pip-whl python-psycopg2 python-pycsw python-pyparsing python-pyproj
python-regex python-requests-whl python-setuptools-whl python-shapely
python-six-whl python-support python-tastypie python-tz python-unidecode
python-urllib3-whl python-virtualenv python-wheel python-yaml
transifex-client
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 42 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up oracle-java7-installer (7u4-0~webupd8~0) ...
Downloading cookie...
--2017-05-03 10:22:35-- http://launchpadlibrarian.net/98645053/cookie.txt
Resolving launchpadlibrarian.net (launchpadlibrarian.net)... 91.189.89.228,
91.189.89.229
Connecting to launchpadlibrarian.net
(launchpadlibrarian.net)|91.189.89.228|:80...
connected.
HTTP request sent, awaiting response... 200 OK
Length: 1053 (1.0K) [text/plain]
Saving to: ‘./cookie.txt’
0K 100% 71.4M=0s
2017-05-03 10:22:36 (71.4 MB/s) - ‘./cookie.txt’ saved [1053/1053]
Downloading Oracle Java 7...
--2017-05-03 10:22:36--
http://download.oracle.com/otn-pub/java/jdk/7u4-b20/jdk-7u4-linux-x64.tar.gz
Resolving download.oracle.com (download.oracle.com)... 202.88.188.203,
202.88.188.208
Connecting to download.oracle.com (download.oracle.com)|202.88.188.203|:80...
connected.
HTTP request sent, awaiting response... 302 Moved Temporarily
https://edelivery.oracle.com/otn-pub/java/jdk/7u4-b20/jdk-7u4-linux-x64.tar.gz
[following]
Resolving edelivery.oracle.com (edelivery.oracle.com)... 104.122.102.128,
2600:140f:4:185::2d3e, 2600:140f:4:18a::2d3e
Connecting to edelivery.oracle.com
(edelivery.oracle.com)|104.122.102.128|:443...
connected.
Location: http://download.oracle.com/errors/download-fail-1505220.html
[following]
connected.
Length: 5307 (5.2K) [text/html]
Saving to: ‘./jdk-7u4-linux-x64.tar.gz’
0K 100%
8.65M=0.001s
2017-05-03 10:22:37 (8.65 MB/s) - ‘./jdk-7u4-linux-x64.tar.gz’ saved
[5307/5307]
Download done.
sha256sum mismatch jdk-7u4-linux-x64.tar.gz
Oracle JDK 7 is NOT installed.
dpkg: error processing package oracle-java7-installer (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
yogini at yogini:~$ sudo dpkg -P oracle-java7-installer
(Reading database ... 272815 files and directories currently installed.)
Removing oracle-java7-installer (7u4-0~webupd8~0) ...
Purging configuration files for oracle-java7-installer (7u4-0~webupd8~0) ...
Processing triggers for mime-support (3.54ubuntu1.1) ...
Processing triggers for gnome-menus (3.10.1-0ubuntu2) ...
Processing triggers for desktop-file-utils (0.22-1ubuntu1) ...
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
yogini at yogini:~$ sudo apt-get -f install
required:
python-bs4
python-pip
transifex-client
0 upgraded, 0 newly installed, 0 to remove and 41 not upgraded.
yogini at yogini:~$ apt-get autoremove
E: Could not open lock file /var/lib/dpkg/lock - open (13: Permission
denied)
E: Unable to lock the administration directory (/var/lib/dpkg/), are you
root?
yogini at yogini:~$ sudo apt-get update
Ign http://dl.google.com stable InRelease
Get:1 http://dl.google.com stable Release.gpg [916
B]
Hit http://security.ubuntu.com trusty-security
InRelease
Ign http://in.archive.ubuntu.com trusty
InRelease
Ign http://extras.ubuntu.com trusty
InRelease
Hit http://dl.google.com stable
Release
Hit http://ppa.launchpad.net trusty
InRelease
Hit http://dl.google.com stable/main amd64
Packages
Hit http://in.archive.ubuntu.com trusty-updates
InRelease
Get:2 http://extras.ubuntu.com trusty Release.gpg [72
B]
Hit http://security.ubuntu.com trusty-security/main
Sources
InRelease
Hit http://dl.google.com stable/main i386
Packages
Hit http://in.archive.ubuntu.com trusty-backports
InRelease
Hit http://security.ubuntu.com trusty-security/restricted
Sources
Hit http://extras.ubuntu.com trusty
Release
InRelease
Release.gpg
Hit http://security.ubuntu.com trusty-security/universe
Sources
Hit http://extras.ubuntu.com trusty/main
Sources
Hit http://ppa.launchpad.net trusty/main amd64
Packages
Hit http://in.archive.ubuntu.com trusty-updates/main
Sources
Hit http://security.ubuntu.com trusty-security/multiverse
Sources
Hit http://extras.ubuntu.com trusty/main amd64
Packages
Hit http://ppa.launchpad.net trusty/main i386
Packages
Hit http://in.archive.ubuntu.com trusty-updates/restricted
Sources
Hit http://security.ubuntu.com trusty-security/main amd64
Packages
Hit http://extras.ubuntu.com trusty/main i386
Packages
Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/universe
Sources
Hit http://security.ubuntu.com trusty-security/restricted amd64
Packages
Ign http://dl.google.com stable/main
Translation-en_IN
Packages
Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/multiverse
Sources
Hit http://security.ubuntu.com trusty-security/universe amd64
Packages
Packages
Hit http://in.archive.ubuntu.com trusty-updates/main amd64
Packages
Hit http://security.ubuntu.com trusty-security/multiverse amd64
Packages
Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/restricted amd64
Packages
Hit http://security.ubuntu.com trusty-security/main i386
Packages
Packages
Hit http://in.archive.ubuntu.com trusty-updates/universe amd64
Packages
Hit http://security.ubuntu.com trusty-security/restricted i386
Packages
Packages
Hit http://in.archive.ubuntu.com trusty-updates/multiverse amd64
Packages
Hit http://security.ubuntu.com trusty-security/universe i386
Packages
Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/main i386
Packages
Hit http://security.ubuntu.com trusty-security/multiverse i386
Packages
Hit http://in.archive.ubuntu.com trusty-updates/restricted i386
Packages
Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/universe i386
Packages
Translation-en
Translation-en
Ign http://extras.ubuntu.com trusty/main
Translation-en_IN
Hit http://security.ubuntu.com trusty-security/universe Translation-en
Ign http://extras.ubuntu.com trusty/main Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/multiverse i386 Packages
Hit http://in.archive.ubuntu.com trusty-updates/main Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/multiverse Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/restricted Translation-en
Hit http://in.archive.ubuntu.com trusty-updates/universe Translation-en
Hit http://in.archive.ubuntu.com trusty-backports/main Sources
Hit http://in.archive.ubuntu.com trusty-backports/restricted Sources
Hit http://in.archive.ubuntu.com trusty-backports/universe Sources
Hit http://in.archive.ubuntu.com trusty-backports/multiverse Sources
Hit http://in.archive.ubuntu.com trusty-backports/main amd64 Packages
Hit http://in.archive.ubuntu.com trusty-backports/restricted amd64 Packages
Hit http://in.archive.ubuntu.com trusty-backports/universe amd64 Packages
Hit http://in.archive.ubuntu.com trusty-backports/multiverse amd64 Packages
Hit http://in.archive.ubuntu.com trusty-backports/main i386 Packages
Hit http://in.archive.ubuntu.com trusty-backports/restricted i386 Packages
Hit http://in.archive.ubuntu.com trusty-backports/universe i386 Packages
Hit http://in.archive.ubuntu.com trusty-backports/multiverse i386 Packages
Hit http://in.archive.ubuntu.com trusty-backports/main Translation-en
Hit http://in.archive.ubuntu.com trusty-backports/multiverse Translation-en
Hit http://in.archive.ubuntu.com trusty-backports/restricted Translation-en
Hit http://in.archive.ubuntu.com trusty-backports/universe Translation-en
Hit http://in.archive.ubuntu.com trusty Release
Hit http://in.archive.ubuntu.com trusty/main Sources
Hit http://in.archive.ubuntu.com trusty/restricted Sources
Hit http://in.archive.ubuntu.com trusty/universe Sources
Hit http://in.archive.ubuntu.com trusty/multiverse
Sources
Hit http://in.archive.ubuntu.com trusty/main amd64
Packages
Hit http://in.archive.ubuntu.com trusty/restricted amd64
Packages
Hit http://in.archive.ubuntu.com trusty/universe amd64
Packages
Hit http://in.archive.ubuntu.com trusty/multiverse amd64
Packages
Hit http://in.archive.ubuntu.com trusty/main i386
Packages
Hit http://in.archive.ubuntu.com trusty/restricted i386
Packages
Hit http://in.archive.ubuntu.com trusty/universe i386
Packages
Hit http://in.archive.ubuntu.com trusty/multiverse i386
Packages
Translation-en
Translation-en
Translation-en
Translation-en
Ign http://in.archive.ubuntu.com trusty/main
Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/multiverse
Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/restricted
Translation-en_IN
Ign http://in.archive.ubuntu.com trusty/universe
Translation-en_IN
Fetched 988 B in 10s (95
B/s)
W: There is no public key available for the following key IDs:
1397BC53640DB551
yogini at yogini:~$ sudo apt-get update && sudo apt-get upgrade
Release.gpg
InRelease
InRelease
InRelease
InRelease
Release
InRelease
Packages
Release.gpg
InRelease
Sources
Packages
InRelease
Release
InRelease
Sources
Packages
Sources
Release.gpg
Sources
Packages
Packages
Sources
Sources
Translation-en
Packages
Sources
Packages
Packages
Sources
Packages
Packages
Translation-en_IN
Translation-en
Sources
Translation-en
Packages
Packages
Packages
Packages
Packages
Packages
Packages
Translation-en
Packages
Packages
Packages
Packages
Packages
Packages
Packages
Translation-en
Translation-en_IN
Packages
Translation-en
Translation-en
Hit http://security.ubuntu.com trusty-security/restricted Translation-en
Hit http://in.archive.ubuntu.com trusty/multiverse Sources
Hit http://in.archive.ubuntu.com trusty/main amd64 Packages
Hit http://in.archive.ubuntu.com trusty/restricted amd64 Packages
Hit http://in.archive.ubuntu.com trusty/universe amd64 Packages
Packages
Packages
Packages
Packages
Packages
Translation-en
Translation-en
Translation-en
Translation-en
Translation-en_IN
Translation-en_IN
Translation-en_IN
Translation-en_IN
Done
1397BC53640DB551
Calculating upgrade... Done
required:
python-bs4
python-pip
transifex-client
The following packages will be upgraded:
fonts-opensymbol ghostscript ghostscript-x libgs9 libgs9-common libicu52
libido3-0.1-0 libmm-glib0 libmysqlclient18 libnautilus-extension1a
libnspr4
libnss3 libnss3-nssdb libreoffice-avmedia-backend-gstreamer
libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core
libreoffice-draw libreoffice-gnome libreoffice-gtk libreoffice-impress
libreoffice-math libreoffice-ogltrans libreoffice-pdfimport
libreoffice-presentation-minimizer libreoffice-style-human
libreoffice-writer libxslt1-dev libxslt1.1 modemmanager mysql-common
nautilus nautilus-data oneconf oneconf-common python-oneconf
python3-oneconf
python3-uno uno-libs3 ure
41 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 87.1 MB of archives.
After this operation, 75.8 kB of additional disk space will be used.
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main libicu52 amd64
52.1-3ubuntu0.6
Cannot initiate the connection to in.archive.ubuntu.com:80
(2001:67c:1360:8001::17). - connect (101: Network is unreachable) [IP:
2001:67c:1360:8001::17 80]
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main libido3-0.1-0
amd64 13.10.0+14.04.20170403-0ubuntu1
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main libmm-glib0
amd64 1.0.0-2ubuntu1.1
libnautilus-extension1a amd64 1:3.10.1-0ubuntu9.11
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main modemmanager
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main nautilus-data
all 1:3.10.1-0ubuntu9.11
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main nautilus amd64
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main oneconf-common
all 0.3.7.14.04.1
python3-oneconf all 0.3.7.14.04.1
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main oneconf all
0.3.7.14.04.1
Err http://in.archive.ubuntu.com/ubuntu/ trusty-updates/main python-oneconf
all 0.3.7.14.04.1
Get:1 http://security.ubuntu.com/ubuntu/ trusty-security/main libicu52
amd64 52.1-3ubuntu0.6 [6,745 kB]
Get:2 http://security.ubuntu.com/ubuntu/ trusty-security/main mysql-common
all 5.5.55-0ubuntu0.14.04.1 [13.0 kB]
Get:3 http://security.ubuntu.com/ubuntu/ trusty-security/main
libmysqlclient18 amd64 5.5.55-0ubuntu0.14.04.1 [597 kB]
Get:4 http://security.ubuntu.com/ubuntu/ trusty-security/main libnspr4
amd64 2:4.13.1-0ubuntu0.14.04.1 [110 kB]
Get:5 http://security.ubuntu.com/ubuntu/ trusty-security/main libnss3-nssdb
all 2:3.28.4-0ubuntu0.14.04.1 [10.6 kB]
Get:6 http://security.ubuntu.com/ubuntu/ trusty-security/main libnss3 amd64
2:3.28.4-0ubuntu0.14.04.1 [1,120 kB]
Get:7 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-calc amd64 1:4.2.8-0ubuntu5.1 [5,934 kB]
Get:8 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-gnome amd64 1:4.2.8-0ubuntu5.1 [90.6 kB]
Get:9 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-gtk amd64 1:4.2.8-0ubuntu5.1 [222 kB]
Get:10 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-impress amd64 1:4.2.8-0ubuntu5.1 [1,210 kB]
Get:11 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-writer amd64 1:4.2.8-0ubuntu5.1 [9,457 kB]
Get:12 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-common all 1:4.2.8-0ubuntu5.1 [19.7 MB]
Get:13 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-pdfimport amd64 1:4.2.8-0ubuntu5.1 [220 kB]
Get:14 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-base-core amd64 1:4.2.8-0ubuntu5.1 [731 kB]
Get:15 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-math amd64 1:4.2.8-0ubuntu5.1 [356 kB]
Get:16 http://security.ubuntu.com/ubuntu/ trusty-security/main python3-uno
amd64 1:4.2.8-0ubuntu5.1 [120 kB]
Get:17 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-ogltrans amd64 1:4.2.8-0ubuntu5.1 [77.7 kB]
Get:18 http://security.ubuntu.com/ubuntu/ trusty-security/main uno-libs3
amd64 4.2.8-0ubuntu5.1 [618 kB]
Get:19 http://security.ubuntu.com/ubuntu/ trusty-security/main ure amd64
4.2.8-0ubuntu5.1 [1,646 kB]
Get:20 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-draw amd64 1:4.2.8-0ubuntu5.1 [2,422 kB]
Get:21 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-core amd64 1:4.2.8-0ubuntu5.1 [27.9 MB]
Get:22 http://security.ubuntu.com/ubuntu/ trusty-security/main
fonts-opensymbol all 2:102.6+LibO4.2.8-0ubuntu5.1 [110 kB]
Get:23 http://security.ubuntu.com/ubuntu/ trusty-security/main libxslt1-dev
amd64 1.1.28-2ubuntu0.1 [406 kB]
Get:24 http://security.ubuntu.com/ubuntu/ trusty-security/main libxslt1.1
amd64 1.1.28-2ubuntu0.1 [145 kB]
Get:25 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-style-human all 1:4.2.8-0ubuntu5.1 [1,739 kB]
Get:26 http://security.ubuntu.com/ubuntu/ trusty-security/main ghostscript
amd64 9.10~dfsg-0ubuntu10.7 [40.8 kB]
Get:27 http://security.ubuntu.com/ubuntu/ trusty-security/main
ghostscript-x amd64 9.10~dfsg-0ubuntu10.7 [33.4 kB]
Get:28 http://security.ubuntu.com/ubuntu/ trusty-security/main
libgs9-common all 9.10~dfsg-0ubuntu10.7 [2,067 kB]
Get:29 http://security.ubuntu.com/ubuntu/ trusty-security/main libgs9 amd64
9.10~dfsg-0ubuntu10.7 [1,941 kB]
Get:30 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-avmedia-backend-gstreamer amd64 1:4.2.8-0ubuntu5.1 [37.0 kB]
Get:31 http://security.ubuntu.com/ubuntu/ trusty-security/main
libreoffice-presentation-minimizer all 1:4.2.8-0ubuntu5.1 [22.1 kB]
Fetched 85.8 MB in 6min 36s (217
kB/s)
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/i/ido/libido3-0.1-0_13.10.0+14.04.20170403-0ubuntu1_amd64.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/m/modemmanager/libmm-glib0_1.0.0-2ubuntu1.1_amd64.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/n/nautilus/libnautilus-extension1a_3.10.1-0ubuntu9.11_amd64.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/m/modemmanager/modemmanager_1.0.0-2ubuntu1.1_amd64.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/n/nautilus/nautilus-data_3.10.1-0ubuntu9.11_all.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/n/nautilus/nautilus_3.10.1-0ubuntu9.11_amd64.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/o/oneconf/oneconf-common_0.3.7.14.04.1_all.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/o/oneconf/python3-oneconf_0.3.7.14.04.1_all.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/o/oneconf/oneconf_0.3.7.14.04.1_all.deb
E: Failed to fetch
http://in.archive.ubuntu.com/ubuntu/pool/main/o/oneconf/python-oneconf_0.3.7.14.04.1_all.deb
E: Unable to fetch some archives, maybe run apt-get update or try with
--fix-missing?
yogini at yogini:~$
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170503/ccd16ce7/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170503/ccd16ce7/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170503/ccd16ce7/attachment-0003.png>
More information about the geonode-users
