[GeoNode-users] Increase performance for loading map, because of capabilities request
John, Steffen s.john at atenekom.eu
Fri May 12 05:28:13 PDT 2017
I have tried unchecking the advertised property in the layer.
When I then load the map, all layers which have "advertised" = False are not shown in the map. But instead it is written to the console:
"Could not create layer record for layer 'geonode:layername'. Check if the layer is found in the WMS GetCapabilities response."
How can the layer be loaded without showing up in the capabilities document?
I even added the source params to the map layer, but still the layer will not be loaded.
Best,
Steffen
Am Montag, den 08.05.2017, 13:51 +0200 schrieb Simone Dalmasso:
Hi all, a thought, what about moving to the leaflet based detail viewer? I've never tested it but maybe is not doing a getcapabilities and using only the map attribute to build the web map. Is a settings, https://github.com/GeoNode/geonode/blob/2.6.x/geonode/settings.py#L936
2017-05-08 13:18 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>>:
Also I'd suggest to change the option below on "WMS" global settings by specifying only the CRS supported and avoid GeoServer to print on the GetCapabilities document the whole list of CRSs
[Inline image 1]
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github<https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313<tel:+39%200584%20962313>
fax:     +39 0584 1660272<tel:+39%200584%20166%200272>
mob:   +39 331 6233686<tel:(331)%20623-3686>
http://www.geo-solutions.it<http://www.geo-solutions.it/>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
On Mon, May 8, 2017 at 1:13 PM, Alessio Fabiani <alessio.fabiani at geo-solutions.it<mailto:alessio.fabiani at geo-solutions.it>> wrote:
Trivial solution (but also easiest to achieve and should not require any other "particular" customization), would be to login into GeoServer ad an internal administrator, edit the Layers to not show on the GetCapabilities but checking-off the "Advertised" option and save them.
Best Regards,
Alessio Fabiani.
@alfa7691
GeoSolutions S.A.S.
Italy
phone: +39 0584 962313<tel:0584%20962313>
fax:     +39 0584 1660272<tel:0584%20166%200272>
mob:   +39 331 6233686<tel:331%20623%203686>
On Mon, May 8, 2017 at 12:49 PM, John, Steffen <s.john at atenekom.eu<mailto:s.john at atenekom.eu>> wrote:
none of the layers has download permission, so is isn't the reason. I'm logged in as admin, which has the view persmissions to all layers.
So, is it possible to adapt geonode, geoserver to request only the capabilities of the layers included in the map?
I'm quite advanced in Geonode and Geoserver, do you have ideas, how i can solve this problem in a different way?
cheers,
Steffen
Am Montag, den 08.05.2017, 11:21 +0200 schrieb Alessio Fabiani:
Ok, GeoNode 2.4 is quite old and still makes use of obsolete auth method, so I'm not fully sure this solution could work, but it is worth to try it out.
For all those layers which are not public, please remove also the download permissions. You can maybe do a quick test with just one or two and see if they have been removed from the big GetCapabilities document.
If this won't work either, the possible solutions are not trivial and will require a very good knowledge of both GeoServer and GeoNode.
Best Regards,
Alessio Fabiani.
@alfa7691
GeoSolutions S.A.S.
Italy
On Mon, May 8, 2017 at 11:17 AM, John, Steffen <s.john at atenekom.eu<mailto:s.john at atenekom.eu>> wrote:
Only third of layers are public. The rest are owned by one or two users withou view persmission for anyone.
But still they appear in the capabilities document.
Steffen
Am Montag, den 08.05.2017, 11:12 +0200 schrieb Alessio Fabiani:
Are those layer all public? All 300 more layers must be accessible to the unauthenticated users also?
Best Regards,
Alessio Fabiani.
@alfa7691
GeoSolutions S.A.S.
Italy
On Mon, May 8, 2017 at 10:38 AM, John, Steffen <s.john at atenekom.eu<mailto:s.john at atenekom.eu>> wrote:
Hi!
I'm running Geonode 2.4. with approximately 300 layers. Whenever I load a map (containing 80 layers), it takes around 20 seconds.
Using the developer tool of the browser, I could identify a GetCapabilties-Request to the geoserver, which takes around 17 seconds.
The XML Document contains around 40000 lines, which is the reason for the long loading time. It contains all Capabilities of all the layers included in Geonode (not only the ones included in the map).
How can I improve the performance?
Is it possible to avoid the capabilities request or at least only load the capabilities of the layers which are included in the map?
I'm thankful for any hints.
Best!
Steffen
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170512/6fe5100a/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170512/6fe5100a/attachment-0001.png>
More information about the geonode-users mailing list
