[GeoNode-users] How to use QGIS as backbone server
Jayesh Gohel
jayesh.gohel at gmail.com
Mon May 22 20:38:38 PDT 2017
Ideally shouldn't the QGIS backend be available as a module (a contrib
project, in geonode terms) since it is optional? I am unaware if this is
even possible.
On 23-May-2017 3:43 AM, "Jeffrey Johnson" <ortelius at gmail.com> wrote:
> Definitely lets try to merge these things in piece by piece and add to
> the tests stepwise. Im sure Tim can help with that.
> On Sun, May 21, 2017 at 10:16 PM, Rizky Maulana Nugraha
> <rizky at kartoza.com> wrote:
> > Hi Ragnvald,
> > We are trying to keep up with latest GeoNode update.
> > Because of the latest changes, the old geonode_qgis_server package is not
> > working correctly.
> > If you are interested with our development state, you can visit
> > https://github.com/kartoza/geonode
> > Our latest changes is in master-qgis_server branch
> > I also made a small wiki here:
> > https://github.com/kartoza/geonode/wiki/QGIS-Server-
> Backend-Configuration
> > We are planning to move the qgis_server backend package itself into
> GeoNode.
> > As I think this is also a perfect opportunity for me to raise a question
> > about merging these changes to GeoNode,
> > can someone give me an advice on how to make a PR to GeoNode?
> > I’m concerned because I think the changes will be quite big, so I prefer
> if
> > we can merge it in stages?
> > That way, even if QGIS Server backend is not fully functional in the
> first
> > PR, we can create another smaller PR
> > for bugfix and improving unit tests to make sure it works tightly with
> > GeoNode.
> > Jeffrey, do you have any comment on this?
> > Regards,
> > Software Developer
> > Kartoza
> > On May 22, 2017, at 10:52, Ismail Sunni <imajimatika at gmail.com> wrote:
> > Hi Ragnvald
> > I cc’ed my friend in Kartoza, Rizky Maulana, who is currently the
> maintainer
> > of GeoNode with QGIS Server project.
> > Best Regards
> > Ismail Sunni
> > Software Engineer at Kartoza
> > On 21May, 2017, at 04:54, Ragnvald Larsen <ragnvald at mindland.com> wrote:
> > Looks like the plugin which should be in place for QGIS is not available
> in
> > the general repositories. There is mention of it at the Kartoza website,
> and
> > its functionality is shown in the video you refer to. So this looks very
> > good - only the documentation needs a little friendly help :-)
> > I am very excited about geonode 2.6!
> > 2017-05-20 16:49 GMT+02:00 Jeffrey Johnson <ortelius at gmail.com>:
> >> There is a video here showing what the Kartoza folks have been working
> >> on recently. I suppose one of them will pipe up with some more
> >> complete answers shortly.
> >> https://youtu.be/z0WYsEUNmg4
> >> On Sat, May 20, 2017 at 7:31 AM, Ragnvald Larsen <ragnvald at mindland.com
> >> wrote:
> >> > Thanks Jeffrey - I would still need to know how to interact with the
> >> > QGIS server. Will I need to restart the geonode server before trying
> my
> >> > luck? And how do I interface with the QGIS server? Web user interface
> or
> >> > connect via QGIS desktop.
> >> > I am no novice at using QGIS, but using and managing data/layouts
> using
> >> > the QGIS server in a ageonode context has left me with more questions
> than
> >> > answers.
> >> > That said I will be more than happy to contribute to the docs once I
> get
> >> > my head sbove water :-)
> >> > Vennlig hilsen
> >> > Ragnvald
> >> >> On 20 May 2017, at 15:27, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
> >> >> The repo is here. Looks like the docs are not being published
> >> >> correctly but there are in this repo.
> >> >> https://github.com/kartoza/geonode_qgis_server
> >> >> Tim or Gavin where is the best place for docs now?
> >> >>> On Sat, May 20, 2017 at 3:18 AM, Ragnvald Larsen
> >> >>> Browsing through the documentation I have found some references to a
> >> >>> local
> >> >>> settings file with references to using QGIS server instead of
> >> >>> geoserver.
> >> >>> Is there any documentation on how to set this up?
> >> >>> Ragnvald
> >> >>> _______________________________________________
> >> >>> geonode-users mailing list
> >> >>> geonode-users at lists.osgeo.org
> >> >>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/32123a1a/attachment.html>
More information about the geonode-users
