[GeoNode-users] query about geonode version
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue May 23 02:00:52 PDT 2017
from here https://github.com/GeoNode/geonode you will get GeoNode 2.7.x
which is the very latest version, but this is the source code, so you will
need to install it by yourself.
In order to get the 2.6 version (actually the latest stable one), you can
just use apt on linux by adding the correct PPA. There are instructions to
do that both on the geonode blog and documentation.
Best Regards,
Alessio Fabiani.
GeoServer Professional Services from the experts!
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
github <https://github.com/afabiani?tab=overview>
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
On Tue, May 23, 2017 at 10:26 AM, Rasika Chinchwade <
rasikachinchwade31 at gmail.com> wrote:
> Thank you for your quick response.
> Now I want to know that which version of geonode I will get from the
> following link.
> Is this link going to give me latest version? Please tell me the version
> number.
> Also what to do for getting 2.6.x version of geonode on linux. Reply as
> soon as possible.
> Thank you
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/94c7c8f2/attachment-0001.html>
More information about the geonode-users
