[GeoNode-users] backup error, geonode 2.6 => backup.py=> import error: no moduled named simplejson
Federico Gianoli
alpacagis at gmail.com
Tue May 23 08:24:33 PDT 2017
Hi Alessio,
thanks for your quick answer,
I have checked, but I have not the files 2 and 3 on my geonode instance.
How is it possible? I have installed geonode via ppa.
I have overwritten all "commands" folder, in order to be sure to have the
latest files, bu it is still not working.
There is another way to do the backup?
In your opinion, if I upgrade my version of geonode (2.6rc) to the last
stable (sudo apt-get upgrade right?), this issue will be solved?
How dangerous could be for my data?
Thanks a lot
Fede
2017-05-23 12:38 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions.it
> Digging to the source code of both GeoNode management command [1] and
> GeoServer Backup Plugin [2] and [3], seems like that GeoServer can't access
> the "${target_folder}/geoserver_catalog.zip"
> The ${target_folder} should be composed by the join of ${backup_dir} and
> ${dir_time_suffix}, something like ${backup_dir}/<time_stamp> where ${backup_dir}
> is the parameter provided when running the backup command from GeoNode.
> Now, the latest GeoNode code [4] tries to set chmod(777) to this temporary
> folder, which will be deleted at the end, in order to allow to GeoServer to
> write the file.
> That means that most probably the user running GeoNode must have full
> rights on the ${backup_dir} folder.
> Can you maybe try to double check this?
> [1] https://github.com/GeoNode/geonode/blob/master/
> geonode/base/management/commands/backup.py#L92
> [2] https://github.com/geoserver/geoserver/blob/2.9.
> x/src/community/backup-restore/rest/src/main/java/
> org/geoserver/backuprestore/rest/BackupResource.java#L155
> [3] https://github.com/geoserver/geoserver/blob/2.9.
> x/src/community/backup-restore/core/src/main/java/
> org/geoserver/backuprestore/Backup.java#L328
> [4] https://github.com/GeoNode/geonode/blob/master/
> geonode/base/management/commands/backup.py#L86
> Best Regards,
> Alessio Fabiani.
> GeoServer Professional Services from the experts!
> Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> github <https://github.com/afabiani?tab=overview>
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <(331)%20623-3686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Tue, May 23, 2017 at 12:23 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Hi Alessio,
>> I have checked the Geoserver Log, and here you can find the complete
>> geoserver log: https://pastebin.com/c9JeR1NU
>> The error that I have noted on the log is this one:
>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - Unable to perform
>> backup: :Could not create file.*
>> *2017-05-23 04:49:10,598 DEBUG [geoserver.filters] - Compressing output
>> for mimetype: text/plain*
>> *2017-05-23 04:49:10,598 ERROR [geoserver.rest] - *
>> *org.geoserver.rest.RestletException: java.lang.IllegalStateException:
>> * at org.geoserver.backuprestore.re
>> <http://org.geoserver.backuprestore.re>st.BackupResource.runBackup(BackupResource.java:172)*
>> <http://org.geoserver.backuprestore.re>st.BackupResource.handlePost(BackupResource.java:108)*
>> The rights of /usr/share/geoserver/data are these:
>> drwxr-xr-x 21 tomcat7 tomcat7 4096 May 23 04:49 data
>> I have also changed the folder rights adding user: tomcat7 and user:user,
>> but without any result.
>> Thanks a lot for your help and your patience
>> Federico
>> 2017-05-22 16:49 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> It is possible that GeoServer cannot write to the target folder. Take a
>>> look at the GeoServer logs. Also try to rise up the log level if you don't
>>> find anything useful.
>>> This can be done from the GeoServer admin gui.
>>> Best Regards,
>>> Alessio Fabiani.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Mon, May 22, 2017 at 4:47 PM, Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it> wrote:
>>>> Hi,
>>>> which version of GeoServer are you using?
>>>> Best Regards,
>>>> Alessio Fabiani.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Italy
>>>> phone: +39 0584 962313 <0584%20962313>
>>>> fax: +39 0584 1660272 <0584%20166%200272>
>>>> mob: +39 331 6233686 <331%20623%203686>
>>>> On Fri, May 19, 2017 at 1:08 PM, Federico Gianoli <alpacagis at gmail.com>
>>>> wrote:
>>>>> Thanks a lot Alessio,
>>>>> I have changed the files according to your suggestions,
>>>>> but now I have this error:
>>>>> *$ sudo python manage.py backup --backup-dir=backup/*
>>>>> *Before proceeding with the Backup, please ensure that:*
>>>>> * 1. The backend (DB or whatever) is accessible and you have rights*
>>>>> * 2. The GeoServer is up and running and reachable from this machine*
>>>>> *You want to proceed? [n]|y: y*
>>>>> *Dumping 'GeoServer Catalog [http://212.237.232.12/geoserver/
>>>>> <http://212.237.232.12/geoserver/>]' into 'backup/2017-05-19_050730
>>>>> <050%20730>/geoserver_catalog.zip'.*
>>>>> *Traceback (most recent call last):*
>>>>> * File "manage.py", line 11, in <module>*
>>>>> * execute_from_command_line(sys.argv)*
>>>>> * File
>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>> 354, in execute_from_command_line*
>>>>> * utility.execute()*
>>>>> * File
>>>>> 346, in execute*
>>>>> * self.fetch_command(subcommand).run_from_argv(self.argv)*
>>>>> * File
>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/base.py", line
>>>>> 394, in run_from_argv*
>>>>> * self.execute(*args, **cmd_options)*
>>>>> * File
>>>>> 445, in execute*
>>>>> * output = self.handle(*args, **options)*
>>>>> * File
>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/backup.py",
>>>>> line 101, in handle*
>>>>> * gs_backup = r.json()*
>>>>> * File "/usr/lib/python2.7/dist-packages/requests/models.py", line
>>>>> 808, in json*
>>>>> * return complexjson.loads(self.text, **kwargs)*
>>>>> * File "/usr/lib/python2.7/json/__init__.py", line 339, in loads*
>>>>> * return _default_decoder.decode(s)*
>>>>> * File "/usr/lib/python2.7/json/decoder.py", line 364, in decode*
>>>>> * obj, end = self.raw_decode(s, idx=_w(s, 0).end())*
>>>>> * File "/usr/lib/python2.7/json/decoder.py", line 382, in raw_decode*
>>>>> * raise ValueError("No JSON object could be decoded")*
>>>>> *ValueError: No JSON object could be decoded*
>>>>> *Thanks a lot for your help*
>>>>> *Fede*
>>>>> 2017-05-05 16:41 GMT+02:00 Alessio Fabiani <
>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>> PR here
>>>>>> https://github.com/GeoNode/geonode/pull/3031
>>>>>> Best Regards,
>>>>>> Alessio Fabiani.
>>>>>> @alfa7691
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>> On Thu, Apr 27, 2017 at 2:09 PM, Alessio Fabiani <
>>>>>>> Dear all,
>>>>>>> currently the backup and restore utility should be aligned with
>>>>>>> latest updates I guess. There are also several issues / improvements we are
>>>>>>> working on to improve this tool.
>>>>>>> We will find some spare time soon to devote to those tasks. We will
>>>>>>> send updates as soon as possible.
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> @alfa7691
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> On Thu, Apr 27, 2017 at 1:50 PM, Simone Dalmasso <
>>>>>>> simone.dalmasso at gmail.com> wrote:
>>>>>>>> Hi Federico,
>>>>>>>> there seems to be an issue in the commands, simplejson is not
>>>>>>>> available anymore, json has to be used. we should fix it.
>>>>>>>> @afabiani, is that correct?
>>>>>>>> https://github.com/GeoNode/geonode/blob/2.6.x/geonode/base/m
>>>>>>>> anagement/commands/restore.py#L28
>>>>>>>> anagement/commands/backup.py#L26
>>>>>>>> 2017-04-27 12:11 GMT+02:00 Federico Gianoli <alpacagis at gmail.com>:
>>>>>>>>> Dear all,
>>>>>>>>> I would like to create a backup of my geonode project and I am
>>>>>>>>> using this guide: http://docs.geonode.org
>>>>>>>>> /en/master/tutorials/admin/backup_restore/
>>>>>>>>> From my django admin page (Base => backups) I tried to do a
>>>>>>>>> backup, but, when I run the backup, on a fully writable folder (777), there
>>>>>>>>> is this server error:
>>>>>>>>> Internal Server Error
>>>>>>>>> The server encountered an internal error or misconfiguration and
>>>>>>>>> was unable to complete your request.
>>>>>>>>> I have double checked the settings.ini file, and I have noted that
>>>>>>>>> the configuration file is not yet update for the 2.6 version, it has these
>>>>>>>>> lines:
>>>>>>>>> #Migrate from GN 2.4 to GN 2.4
>>>>>>>>> migrations = base.resourcebase,layers.layer
>>>>>>>>> ,layers.attribute,maps.map,maps.maplayer
>>>>>>>>> manglers = gn24_to_24.ResourceBaseMangler
>>>>>>>>> ,gn24_to_24.LayerMangler,gn24_to_24.LayerAttributesMangler,g
>>>>>>>>> n24_to_24.DefaultMangler,gn24_to_24.MapLayersMangler
>>>>>>>>> Is it correct? Have I to change these lines accordingly to the 2.6
>>>>>>>>> version? (e.g. gn26_to_26.ResourceBaseMangler ...)?
>>>>>>>>> When I try to run the backup from command line there is the
>>>>>>>>> following error about the file backup.py
>>>>>>>>> How can I solved this issue?
>>>>>>>>> Tanks a lot
>>>>>>>>> Federico
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170523/c5b2c7ec/attachment-0001.html>
More information about the geonode-users
