[GeoNode-users] geoserver authentication in multi-geosites
Alessio Fabiani alessio.fabiani at gmail.com
Wed May 24 06:50:27 PDT 2017
Is the geotiff present and configured on the second instance too? Is it
private or publicly accessible? Can you somehow intercept the requests and
send them here?
On May 20, 2017 15:20, "Eugenio Trumpy" <frippe12573 at hotmail.com> wrote:
> Hi all,
> unfortunately I was not able to solve the issue raised in this thread. I
> was just living in the situation described.
> However, today I have to face a consequent, I guess, issue.
> From a child site I'm not able to download a raster layer (uploaded as
> tif) in geotiff format (i.e. in the download menu there is not the item
> 'Geotiff').
> If I try to download the same raster layer from the master site it is
> possible (i.e. in the download menu there is the item 'Geotiff').
> I think is a matter of geoserver configuration/authentication in
> geonode-multitenancy environment.
> Have you got any suggestion?
> E.
> *Da:* Simone Dalmasso <simone.dalmasso at gmail.com>
> *Inviato:* mercoledì 5 aprile 2017 15.39
> *A:* Eugenio Trumpy
> *Cc:* geonode-users at lists.osgeo.org
> *Oggetto:* Re: geoserver authentication in multi-geosites
> Eugenio, I don't see wrong config. It is ok I guess to leave the master
> site host in the gs config as well as I think it is ok that you cannot log
> in directly into gs from a child site. That said, when geosites was
> developed, the geoserver ext was modified to make sure that geoserver pings
> the same host that made the http request for authentication instead of
> relying on the base url parameter. So ideally it should work as you would
> expect.
> 2017-04-05 14:39 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
>> Hi,
>> I'm working on geonode 2.4 in a Ubuntu server 14.04LTS (tomcat7, java8).
>> I had to upgrade geoserver from 2.7.x version up to 2.9.x.
>> In the system I configured geonode to work as multi-geosites.
>> The master site is the normal geonode site, I mean it use the
>> local_setting.py I have in /geonode/geonode
>> The geosites are in /geonode/geonode/contrib/geosites, and they use the
>> relative config files.
>> The documentation: https://github.com/terranodo/geosites-project
>> /blob/master/GEOSITES-README.md
>> indicates to leave empty <baseurl> in config.xml in
>> security/auth/geonodeauthprovider/
>> In that way I have this error:
>> java.lang.IllegalArgumentException: host parameter is null
>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:206)
>> 	org.apache.commons.httpclient.HttpConnection.<init>(HttpConnection.java:155)
>> 	org.apache.commons.httpclient.SimpleHttpConnectionManager.getConnectionWithTimeout(SimpleHttpConnectionManager.java:175)
>> 	org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:153)
>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
>> 	org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
>> 	org.geonode.security.HTTPClient.sendGET(HTTPClient.java:89)
>> 	org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>> 	org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>> 	org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>> 	org.geoserver.security.GeoServerAuthenticationProvider.authenticate(GeoServerAuthenticationProvider.java:58)
>> 	org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:167)
>> 	org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
>> 	org.geonode.security.GeoNodeCookieProcessingFilter.doFilter(GeoNodeCookieProcessingFilter.java:94)
>> 	org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
>> 	org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
>> 	org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
>> 	org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
>> 	org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
>> 	org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
>> 	org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
>> 	org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
>> 	org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
>> 	org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
>> 	org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
>> 	org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
>> 	org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
>> 	org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
>> 	org.springframework.web.filter.CharacterEncodingFilter.doFilterIntaernal(CharacterEncodingFilter.java:121)
>> 	org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
>> both if I use the geoserver link in the menu (once logged in) and if I
>> call geoserver by using the geoserver url in the browser address bar.
>> If set the doman name of the master site in <baseurl> in config.xml in
>> I'm able to enter in geoserver as admin from the menu, by the way doing
>> the same operation from a geosite
>> I got the geoserverage but not logged.
>> The master site virtualhost as well as those of the geosites have the
>> proxypass and reverse pointing to http://localhost:8080/geoserver
>> The same in /geonode/geonode/contrib/geosites/local_setting.py and
>> pre-setting.py I have http://localhost:8080/geoserver
>> Is there a wrong configuration?
>> Any hints?
> Simone
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20170524/274206fe/attachment.html>
More information about the geonode-users mailing list
