[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Corti pcorti at gmail.com
Tue Nov 7 06:44:09 PST 2017
Hi Paolo
while I am not sure why this is happening (it shouldn't), in GeoNode master
there is now a sync_geofence command which will fix things:
https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/management/commands/sync_geofence.py
It should work for 2.6.x as well, in case not let me know
cheers
p
On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Dear all,
> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
> every layer I upload does not appear in the GeoFence list.
> I've tried to edit and save permissions, restart Apache, Tomcat, run
> fixlayerpermission but with no result.
> This is not happening in my local installation that reflects the affected
> website.
> Is there some action I can take except upgrading GeoServer?
> Thanks.
> Best,
> Paolo
> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
>> Dear list,
>> It seems that the problem with the permission is solved with the
>> upgrading of geoserver to 2.10 version
>> Thanks Alessio for your help
>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <alessio.fabiani at geo-solutions
>> .it>:
>>> In that case you are correct. You need to double check that GeoFence
>>> access rules have been correctly set on GeoServer for the layer you are
>>> modifying.
>>> If you cannot find them or the rules are not correctly updated, it is
>>> possible that there is some communication issue between GeoNode and
>>> GeoServer.
>>> [image: Inline image 1]
>>> Maybe try to do some tests and double check that the rules actually
>>> change.
>>> P.S.: do not use browser refresh on GeoFence Rules, but always click here
>>> [image: Inline image 2]
>>> Best Regards,
>>> Alessio Fabiani.
>>> GeoServer Professional Services from the experts!
>>> Visit http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> github <https://github.com/afabiani?tab=overview>
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A
>>> 55054  Massarosa (LU)
>>> Italy
>>> phone: +39 0584 962313 <+39%200584%20962313>
>>> fax:     +39 0584 1660272 <+39%200584%20166%200272>
>>> mob:   +39 331 6233686 <(331)%20623-3686>
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>> principi dettati dal D.Lgs. 196/2003.
>>> The information in this message and/or attachments, is intended solely
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>>> copying, distribution, or either dissemination, either whole or partial, is
>>> strictly forbidden except previous formal approval of the named
>>> addressee(s). If you are not the intended recipient, please contact
>>> immediately the sender by telephone, fax or e-mail and delete the
>>> information in this message that has been received in error. The sender
>>> does not give any warranty or accept liability as the content, accuracy or
>>> completeness of sent messages and accepts no responsibility  for changes
>>> made after they were sent or for other risks which arise as a result of
>>> e-mail transmission, viruses, etc.
>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <alpacagis at gmail.com>
>>> wrote:
>>>> Thanks  for your reply Alessio,
>>>> about the layer preview question, I am logged in with the "SGI" user,
>>>> that should be have the permission to see the layer.
>>>> Moreover, the user that I'm using, is part of the "Staff" group, but I
>>>> can't see the layer preview.
>>>> Where I am wrong?
>>>> [image: Immagine incorporata 1]
>>>> Really thanks
>>>> Federico
>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>> alessio.fabiani at geo-solutions.it>:
>>>>> Hello,
>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>> groups.
>>>>> 2) you can either change the Javascript of the map composer or
>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>> Denominators
>>>>> Best Regards,
>>>>> Alessio Fabiani.
>>>>> @alfa7691
>>>>> GeoSolutions S.A.S.
>>>>> Italy
>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <alpacagis at gmail.com
>>>>> > wrote:
>>>>>> Dear list,
>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>> 1- Layer permission issue:
>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>> or Geoserver?
>>>>>> 2- Is it possible to fix a specific scale for the map view in the map
>>>>>> composer? e.g. I would see a map only at 1:250'000 (or at the zoom level
>>>>>> that is closest to 1:250'000...)
>>>>>> Thanks a lot
>>>>>> Federico
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/96c1da8f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/96c1da8f/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/96c1da8f/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/96c1da8f/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/96c1da8f/attachment-0007.png>
More information about the geonode-users mailing list
