[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali
paolo.pasquali at ithaca.polito.it
Tue Nov 7 08:56:58 PST 2017
Sorry, maybe you asked for this:
$ python manage.py sync_geofence
File "manage.py", line 11, in <module>
execute_from_command_line(sys.argv)
File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
utility.execute()
File
346, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
self.execute(*args, **cmd_options)
line 445, in execute
output = self.handle(*args, **options)
File
"/usr/local/lib/python2.7/dist-packages/geonode/base/management/commands/sync_geofence.py",
line 53, in handle
print 'Synchronizing permissions for layer %s/%s: %s' % (count,
layers_count, layer.alternate)
AttributeError: 'Layer' object has no attribute 'alternate'
Paolo Pasquali
ITHACA
Information Technology for Humanitarian Assistance, Cooperation and Action
via Pier Carlo Boggio, 61 - 10138 Torino - Italy
Tel. +39 011 1975 1111
Fax +39 011 1975 1122
www.ithacaweb.org
On Tue, Nov 7, 2017 at 5:30 PM, Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Hi,
> No stack trace. It seems it does nothing.
> Thanks.
> On Tue, Nov 7, 2017 at 5:21 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi Paolo
>> Strange, it should work. Can you remove the try/except block and send me
>> again the stack trace?
>> thanks
>> p
>> On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
>>> Ciao Paolo.
>>> Actually I'm getting an error:
>>> ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>> File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>> line 354, in execute_from_command_line
>>> utility.execute()
>>> line 346, in execute
>>> File "/usr/local/lib/python2.7/dist-packages/geonode/base/managem
>>> ent/commands/sync_geofence.py", line 58, in handle
>>> print 'perm_spec is %s' % perm_spec
>>> UnboundLocalError: local variable 'perm_spec' referenced before
>>> assignment
>>> Thanks!
>>> P.
>>> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>> Hi Paolo
>>>> while I am not sure why this is happening (it shouldn't), in GeoNode
>>>> master there is now a sync_geofence command which will fix things:
>>>> https://github.com/GeoNode/geonode/blob/master/geono
>>>> de/geoserver/management/commands/sync_geofence.py
>>>> It should work for 2.6.x as well, in case not let me know
>>>> cheers
>>>> p
>>>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>>>> Dear all,
>>>>> I'm experiencing this problem with GeoNode 2.6.3. From some point on,
>>>>> every layer I upload does not appear in the GeoFence list.
>>>>> I've tried to edit and save permissions, restart Apache, Tomcat, run
>>>>> fixlayerpermission but with no result.
>>>>> This is not happening in my local installation that reflects the
>>>>> affected website.
>>>>> Is there some action I can take except upgrading GeoServer?
>>>>> Thanks.
>>>>> Best,
>>>>> Paolo
>>>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <
>>>>> alpacagis at gmail.com> wrote:
>>>>>> Dear list,
>>>>>> It seems that the problem with the permission is solved with the
>>>>>> upgrading of geoserver to 2.10 version
>>>>>> Thanks Alessio for your help
>>>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>> In that case you are correct. You need to double check that GeoFence
>>>>>>> access rules have been correctly set on GeoServer for the layer you are
>>>>>>> modifying.
>>>>>>> If you cannot find them or the rules are not correctly updated, it
>>>>>>> is possible that there is some communication issue between GeoNode and
>>>>>>> GeoServer.
>>>>>>> [image: Inline image 1]
>>>>>>> Maybe try to do some tests and double check that the rules actually
>>>>>>> change.
>>>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always click
>>>>>>> here
>>>>>>> [image: Inline image 2]
>>>>>>> Best Regards,
>>>>>>> Alessio Fabiani.
>>>>>>> GeoServer Professional Services from the experts!
>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>> Ing. Alessio Fabiani
>>>>>>> @alfa7691
>>>>>>> github <https://github.com/afabiani?tab=overview>
>>>>>>> Founder/Technical Lead
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Via di Montramito 3/A
>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>>>> 55054 Massarosa
>>>>>>> (LU)
>>>>>>> Italy
>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>> mob: +39 331 6233686 <(331)%20623-3686>
>>>>>>> http://www.geo-solutions.it
>>>>>>> http://twitter.com/geosolutions_it
>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>> Le informazioni contenute in questo messaggio di posta elettronica
>>>>>>> e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>>>>>>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>>>>>>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>>>>>>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>>>>>>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>> The information in this message and/or attachments, is intended
>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>> information in this message that has been received in error. The sender
>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>> e-mail transmission, viruses, etc.
>>>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <
>>>>>>>> Thanks for your reply Alessio,
>>>>>>>> about the layer preview question, I am logged in with the "SGI"
>>>>>>>> user, that should be have the permission to see the layer.
>>>>>>>> Moreover, the user that I'm using, is part of the "Staff" group,
>>>>>>>> but I can't see the layer preview.
>>>>>>>> Where I am wrong?
>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>> Really thanks
>>>>>>>> Federico
>>>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>>>> Hello,
>>>>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>>>>> groups.
>>>>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>>>> Denominators
>>>>>>>>> Best Regards,
>>>>>>>>> Alessio Fabiani.
>>>>>>>>> @alfa7691
>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>> 55054 Massarosa
>>>>>>>>> (LU)
>>>>>>>>> Italy
>>>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>>>>> Dear list,
>>>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>>>> 1- Layer permission issue:
>>>>>>>>>> When I change the permission: "who can view it" from Anyone to a
>>>>>>>>>> specific user/group, It works but the layer preview disappear, and I am not
>>>>>>>>>> more able to see the layer shape. Should I have to set something in Django
>>>>>>>>>> or Geoserver?
>>>>>>>>>> 2- Is it possible to fix a specific scale for the map view in the
>>>>>>>>>> map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>>>>> level that is closest to 1:250'000...)
>>>>>>>>>> Thanks a lot
>>>>>>>>>> Federico
>>>>>>>>>> _______________________________________________
>>>>>>>>>> geonode-users mailing list
>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Paolo Corti
>>>> Geospatial software developer
>>>> web: http://www.paolocorti.net
>>>> twitter: @capooti
>>>> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/9c69eaa9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/9c69eaa9/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/9c69eaa9/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/9c69eaa9/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171107/9c69eaa9/attachment-0007.png>
More information about the geonode-users
