[GeoNode-users] Permission file || How to fix a specific scale in map composer
Paolo Pasquali
paolo.pasquali at ithaca.polito.it
Wed Nov 8 02:13:55 PST 2017
I just want to summarize what it is happening on my 2.6.3 version.
For no apparent reason GeoFence is not writing permissions of newly created
layers anymore. In GeoServer the new layers are not listed in the GeoFence
section.
Running updatelayers screwed up all layers permissions. The sync_geofence
script fixed the old layers but not the new ones (since the issue occurred).
Looking into catalina.out I get this error when trying to view a layer
without being logged:
08 Nov 10:49:02 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer
geonode:ville_3a4edffa
So, I'm still using GeoServer 2.9 and it seems that this permission issue
has been fixed on 2.10.
Can you confirm?
What would you suggest? Upgrading to GeoServer 2.10 or reinstalling the
whole platform?
Thanks for your help.
Best,
Paolo
On Wed, Nov 8, 2017 at 9:15 AM, Paolo Pasquali <
paolo.pasquali at ithaca.polito.it> wrote:
> Thanks Paolo!
> It solved the issue. I owe you a beer. Daje!
> Ciao.
> P.
> On Tue, Nov 7, 2017 at 6:09 PM, Paolo Corti <pcorti at gmail.com> wrote:
>> Hi Paolo
>> File a ticket. Later today I will try to backport the command to 2.6.x
>> cheers
>> p
>> On Tue, Nov 7, 2017 at 12:02 PM, Paolo Pasquali <
>>> I've run the script without layer.alternate (don't know what it is) and
>>> I get:
>>> Synchronizing permissions for layer 1/95
>>> ('Unexpected error:', None)
>>> perm_spec is {u'users': {u'paolo': [u'view_resourcebase',
>>> u'download_resourcebase', u'change_resourcebase_metadata',
>>> u'change_resourcebase', u'delete_resourcebase',
>>> u'change_resourcebase_permissions', u'publish_resourcebase',
>>> u'change_layer_data', u'change_layer_style']}, u'groups': {u'anonymous':
>>> [u'download_resourcebase', u'view_resourcebase']}}
>>> On Tue, Nov 7, 2017 at 5:56 PM, Paolo Pasquali <
>>>> Sorry, maybe you asked for this:
>>>> $ python manage.py sync_geofence
>>>> Traceback (most recent call last):
>>>> File "manage.py", line 11, in <module>
>>>> execute_from_command_line(sys.argv)
>>>> File "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>>>> line 354, in execute_from_command_line
>>>> utility.execute()
>>>> line 346, in execute
>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>> File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
>>>> line 394, in run_from_argv
>>>> self.execute(*args, **cmd_options)
>>>> line 445, in execute
>>>> output = self.handle(*args, **options)
>>>> File "/usr/local/lib/python2.7/dist-packages/geonode/base/managem
>>>> ent/commands/sync_geofence.py", line 53, in handle
>>>> print 'Synchronizing permissions for layer %s/%s: %s' % (count,
>>>> layers_count, layer.alternate)
>>>> AttributeError: 'Layer' object has no attribute 'alternate'
>>>> Paolo Pasquali
>>>> ITHACA
>>>> Information Technology for Humanitarian Assistance, Cooperation and
>>>> Action
>>>> via Pier Carlo Boggio, 61 - 10138 Torino - Italy
>>>> <https://maps.google.com/?q=via+Pier+Carlo+Boggio,+61+-%C2%A010138+Torino+-+Italy&entry=gmail&source=g>
>>>> Tel. +39 011 1975 1111 <+39%20011%201975%201111>
>>>> Fax +39 011 1975 1122 <+39%20011%201975%201122>
>>>> www.ithacaweb.org
>>>> On Tue, Nov 7, 2017 at 5:30 PM, Paolo Pasquali <
>>>>> Hi,
>>>>> No stack trace. It seems it does nothing.
>>>>> Thanks.
>>>>> On Tue, Nov 7, 2017 at 5:21 PM, Paolo Corti <pcorti at gmail.com> wrote:
>>>>>> Hi Paolo
>>>>>> Strange, it should work. Can you remove the try/except block and send
>>>>>> me again the stack trace?
>>>>>> thanks
>>>>>> p
>>>>>> On Tue, Nov 7, 2017 at 10:06 AM, Paolo Pasquali <
>>>>>>> Ciao Paolo.
>>>>>>> Actually I'm getting an error:
>>>>>>> ('Unexpected error:', <type 'exceptions.AttributeError'>)
>>>>>>> utility.execute()
>>>>>>> ent/commands/sync_geofence.py", line 58, in handle
>>>>>>> print 'perm_spec is %s' % perm_spec
>>>>>>> UnboundLocalError: local variable 'perm_spec' referenced before
>>>>>>> assignment
>>>>>>> Thanks!
>>>>>>> P.
>>>>>>> On Tue, Nov 7, 2017 at 3:44 PM, Paolo Corti <pcorti at gmail.com>
>>>>>>> wrote:
>>>>>>>> Hi Paolo
>>>>>>>> while I am not sure why this is happening (it shouldn't), in
>>>>>>>> GeoNode master there is now a sync_geofence command which will fix things:
>>>>>>>> https://github.com/GeoNode/geonode/blob/master/geono
>>>>>>>> de/geoserver/management/commands/sync_geofence.py
>>>>>>>> It should work for 2.6.x as well, in case not let me know
>>>>>>>> cheers
>>>>>>>> p
>>>>>>>> On Tue, Nov 7, 2017 at 4:29 AM, Paolo Pasquali <
>>>>>>>>> Dear all,
>>>>>>>>> I'm experiencing this problem with GeoNode 2.6.3. From some point
>>>>>>>>> on, every layer I upload does not appear in the GeoFence list.
>>>>>>>>> I've tried to edit and save permissions, restart Apache, Tomcat,
>>>>>>>>> run fixlayerpermission but with no result.
>>>>>>>>> This is not happening in my local installation that reflects the
>>>>>>>>> affected website.
>>>>>>>>> Is there some action I can take except upgrading GeoServer?
>>>>>>>>> Thanks.
>>>>>>>>> Best,
>>>>>>>>> Paolo
>>>>>>>>> On Tue, Jun 13, 2017 at 12:59 PM, Federico Gianoli <
>>>>>>>>> alpacagis at gmail.com> wrote:
>>>>>>>>>> Dear list,
>>>>>>>>>> It seems that the problem with the permission is solved with the
>>>>>>>>>> upgrading of geoserver to 2.10 version
>>>>>>>>>> Thanks Alessio for your help
>>>>>>>>>> 2017-06-09 12:42 GMT+02:00 Alessio Fabiani <
>>>>>>>>>> alessio.fabiani at geo-solutions.it>:
>>>>>>>>>>> In that case you are correct. You need to double check that
>>>>>>>>>>> GeoFence access rules have been correctly set on GeoServer for the layer
>>>>>>>>>>> you are modifying.
>>>>>>>>>>> If you cannot find them or the rules are not correctly updated,
>>>>>>>>>>> it is possible that there is some communication issue between GeoNode and
>>>>>>>>>>> GeoServer.
>>>>>>>>>>> [image: Inline image 1]
>>>>>>>>>>> Maybe try to do some tests and double check that the rules
>>>>>>>>>>> actually change.
>>>>>>>>>>> P.S.: do not use browser refresh on GeoFence Rules, but always
>>>>>>>>>>> click here
>>>>>>>>>>> [image: Inline image 2]
>>>>>>>>>>> Best Regards,
>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>> GeoServer Professional Services from the experts!
>>>>>>>>>>> Visit http://goo.gl/it488V for more information.
>>>>>>>>>>> Ing. Alessio Fabiani
>>>>>>>>>>> @alfa7691
>>>>>>>>>>> github <https://github.com/afabiani?tab=overview>
>>>>>>>>>>> Founder/Technical Lead
>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>> Via di Montramito 3/A
>>>>>>>>>>> <https://maps.google.com/?q=Via+di+Montramito+3/A55054+%C2%A0Massarosa&entry=gmail&source=g>
>>>>>>>>>>> 55054 Massarosa
>>>>>>>>>>> (LU)
>>>>>>>>>>> Italy
>>>>>>>>>>> phone: +39 0584 962313 <+39%200584%20962313>
>>>>>>>>>>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>>>>>>>>>>> mob: +39 331 6233686 <(331)%20623-3686>
>>>>>>>>>>> http://www.geo-solutions.it
>>>>>>>>>>> http://twitter.com/geosolutions_it
>>>>>>>>>>> *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
>>>>>>>>>>> Le informazioni contenute in questo messaggio di posta
>>>>>>>>>>> elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente
>>>>>>>>>>> riservate. Il loro utilizzo è consentito esclusivamente al destinatario del
>>>>>>>>>>> messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate
>>>>>>>>>>> questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente
>>>>>>>>>>> di darcene notizia via e-mail e di procedere alla distruzione del messaggio
>>>>>>>>>>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>>>>>>>>>>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>>>>>>>>>>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>>>>>>>>>>> principi dettati dal D.Lgs. 196/2003.
>>>>>>>>>>> The information in this message and/or attachments, is intended
>>>>>>>>>>> solely for the attention and use of the named addressee(s) and may be
>>>>>>>>>>> confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>> privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data
>>>>>>>>>>> Protection Code).Any use not in accord with its purpose, any disclosure,
>>>>>>>>>>> reproduction, copying, distribution, or either dissemination, either whole
>>>>>>>>>>> or partial, is strictly forbidden except previous formal approval of the
>>>>>>>>>>> named addressee(s). If you are not the intended recipient, please contact
>>>>>>>>>>> immediately the sender by telephone, fax or e-mail and delete the
>>>>>>>>>>> information in this message that has been received in error. The sender
>>>>>>>>>>> does not give any warranty or accept liability as the content, accuracy or
>>>>>>>>>>> completeness of sent messages and accepts no responsibility for changes
>>>>>>>>>>> made after they were sent or for other risks which arise as a result of
>>>>>>>>>>> e-mail transmission, viruses, etc.
>>>>>>>>>>> On Fri, Jun 9, 2017 at 12:31 PM, Federico Gianoli <
>>>>>>>>>>>> Thanks for your reply Alessio,
>>>>>>>>>>>> about the layer preview question, I am logged in with the "SGI"
>>>>>>>>>>>> user, that should be have the permission to see the layer.
>>>>>>>>>>>> Moreover, the user that I'm using, is part of the "Staff"
>>>>>>>>>>>> group, but I can't see the layer preview.
>>>>>>>>>>>> Where I am wrong?
>>>>>>>>>>>> [image: Immagine incorporata 1]
>>>>>>>>>>>> Really thanks
>>>>>>>>>>>> Federico
>>>>>>>>>>>> 2017-06-09 11:00 GMT+02:00 Alessio Fabiani <
>>>>>>>>>>>>> Hello,
>>>>>>>>>>>>> 1) if you remove "Anyone" check the layer is no more publicly
>>>>>>>>>>>>> accessible. It will be visible only by logged-in users belonging to allowed
>>>>>>>>>>>>> groups.
>>>>>>>>>>>>> 2) you can either change the Javascript of the map composer or
>>>>>>>>>>>>> manually modify the SLDs on GeoServer by setting ths Max and Min Scale
>>>>>>>>>>>>> Denominators
>>>>>>>>>>>>> Best Regards,
>>>>>>>>>>>>> Alessio Fabiani.
>>>>>>>>>>>>> @alfa7691
>>>>>>>>>>>>> GeoSolutions S.A.S.
>>>>>>>>>>>>> 55054 Massarosa
>>>>>>>>>>>>> (LU)
>>>>>>>>>>>>> Italy
>>>>>>>>>>>>> intended solely for the attention and use of the named addressee(s) and may
>>>>>>>>>>>>> be confidential or proprietary in nature or covered by the provisions of
>>>>>>>>>>>>> On Thu, Jun 8, 2017 at 11:35 AM, Federico Gianoli <
>>>>>>>>>>>>>> Dear list,
>>>>>>>>>>>>>> I have two questions about geonode.(I am using 2.6 version)
>>>>>>>>>>>>>> 1- Layer permission issue:
>>>>>>>>>>>>>> When I change the permission: "who can view it" from Anyone
>>>>>>>>>>>>>> to a specific user/group, It works but the layer preview disappear, and I
>>>>>>>>>>>>>> am not more able to see the layer shape. Should I have to set something in
>>>>>>>>>>>>>> Django or Geoserver?
>>>>>>>>>>>>>> 2- Is it possible to fix a specific scale for the map view in
>>>>>>>>>>>>>> the map composer? e.g. I would see a map only at 1:250'000 (or at the zoom
>>>>>>>>>>>>>> level that is closest to 1:250'000...)
>>>>>>>>>>>>>> Thanks a lot
>>>>>>>>>>>>>> Federico
>>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>>>>> Paolo Corti
>>>>>>>> Geospatial software developer
>>>>>>>> web: http://www.paolocorti.net
>>>>>>>> twitter: @capooti
>>>>>>>> skype: capooti
>>>>>> Paolo Corti
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/eca9fcb4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/eca9fcb4/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/eca9fcb4/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/eca9fcb4/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171108/eca9fcb4/attachment-0007.png>
More information about the geonode-users
