[GeoNode-users] Problem uploading raster file
Simone Dalmasso simone.dalmasso at gmail.com
Thu Nov 9 02:17:45 PST 2017
That makes sense. During the load I see a JavaIO error and a translator
error.
2017-11-09 10:52 GMT+01:00 <Stefano.LUONI at ext.ec.europa.eu>:
> Thank you Simone,
> we'll try to resave the file; the strange thing is that it works on my
> Geonode 2.9 development installation, so it might be that a most recent
> version of Geoserver can handle it as is.
> Stefano
> *From:* Simone Dalmasso [simone.dalmasso at gmail.com]
> *Sent:* 09 November 2017 10:42
> *To:* LUONI Stefano (JRC-ISPRA-EXT)
> *Cc:* geonode-users at lists.osgeo.org
> *Subject:* Re: [GeoNode-users] Problem uploading raster file
> Stefano, I tested on a new GeoNode installation and I can confirm the
> issue, geoserver is unable to spot the srs. It looks a data issue, could
> you try to reproject/resave it in a gis software and try again?
> This is the gdalinfo output for info
> PROJCS["ETRS_1989_LAEA",
>     GEOGCS["GCS_ETRS_1989",
>         DATUM["European_Terrestrial_Reference_System_1989",
>             SPHEROID["GRS_1980",6378137,298.257222101,
>                 AUTHORITY["EPSG","7019"]],
>             AUTHORITY["EPSG","6258"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433]],
>     PROJECTION["Lambert_Azimuthal_Equal_Area"],
>     PARAMETER["latitude_of_center",52],
>     PARAMETER["longitude_of_center",10],
>     PARAMETER["false_easting",4321000],
>     PARAMETER["false_northing",3210000],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]]]
> 2017-11-08 16:48 GMT+01:00 <Stefano.LUONI at ext.ec.europa.eu>:
>> Hello,
>> I currently have issues with GeoTiff raster files: after uploading from
>> GeoNode, the layer page displays an empty map. Looking from GeoServer admin
>> website, I can see the layer it's disabled, because no SRS is detected; the
>> only way to enable the layer is to manually set SRS.
>> After enabling the layer, this is visibile from GeoNode, but it is not
>> centered in the map, like the bounds are not correctly computed; the layer
>> preview from GeoServer is fine though.
>> This is happening on a 2.6.3 installation (standard deployment), with
>> GeoServer 2.9; I tried using both open-jdk and Oracle Java8 with the same
>> result.
>> The same raster file is uploaded correctly on a development installation
>> (GeoNode 2.9, Geoserver 2.12).
>> You can find an extraction of GeoSever log attached to this email; it
>> contains several errors, like
>> ERROR [geoserver.rest] - No such datastore: geonode,floodmapeu_rp200y
>> ERROR [geoserver.rest] - No such coverage store: geonode,floodmapeu_rp200y
>> ERROR [geoserver.rest] - No such wms store: geonode,floodmapeu_rp200y
>> ERROR [geoserver.rest] - No such style: floodmapeu_rp200y
>> ERROR [geoserver.ows] -
>> org.geoserver.platform.ServiceException: Could not find layer
>> geonode:floodmapeu_rp200y
>> I guess something is wrong with my GeoServer installation, but I cannot
>> say how.
>> You may download the raster file from this link:
>> https://drive.google.com/file/d/1u2iUD4Gf_QZKpjW0nAWNatbR6Nx
>> kU6Ni/view?usp=sharing
>> Stefano Luoni
>> External consultant for the European Commission (GFT Italia)
>> European Commission
>> Joint Research Centre – JRC.E.1
>> Disaster Risk Management Unit
>> Building 26b | Via E.Fermi 2749, I-21027 Ispra (VA) Italy, TP 266
>> Tel: +39 033278 9451 <+39%200332%20789451>
>> Email: stefano.luoni at ext.jrc.ec.europa.eu
>> geonode-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171109/2d33f8fb/attachment-0001.html>
More information about the geonode-users mailing list
