[GeoNode-users] how to update all the thumbnails
Federico Gianoli alpacagis at gmail.com
Thu Nov 16 07:18:31 PST 2017
Thanks Paolo,
I ran "geonode updatelayers" without results.
The command give me the following message, should I give another command
before to run updatelayers?
# geonode updatelayers
Inspecting the available layers in GeoServer ...
  File "/usr/bin/django-admin", line 21, in <module>
    management.execute_from_command_line()
  File
"/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
354, in execute_from_command_line
    utility.execute()
  File
346, in execute
    self.fetch_command(subcommand).run_from_argv(self.argv)
  File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
line 394, in run_from_argv
    self.execute(*args, **cmd_options)
line 445, in execute
    output = self.handle(*args, **options)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/management/commands/updatelayers.py",
line 119, in handle
    execute_signals=True)
  File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
439, in gs_slurp
    resources = [k for k in resources if k.enabled in ["true", True]]
  File "/usr/lib/python2.7/dist-packages/geoserver/support.py", line 67, in
getter
    self.fetch()
  File "/usr/lib/python2.7/dist-packages/geoserver/support.py", line 176,
in fetch
    self.dom = self.catalog.get_xml(self.href)
  File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 214,
in get_xml
    return parse_or_raise(content)
  File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 205,
in parse_or_raise
    raise Exception(msg, e)
Exception: ('GeoServer gave non-XML response for [GET
http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore/featuretypes/salah_aldin_wells_iraq_unesco_ll_point.xml]:
<featureType>\n  <name>salah_aldin_wells_iraq_unesco_ll_point</name>\n
<nativeName>salah_aldin_wells_iraq_unesco_ll_point</nativeName>\n
<namespace>\n    <name>geonode</name>\n    <atom:link xmlns:atom="
http://www.w3.org/2005/Atom" rel="alternate" href="
http://localhost:8080/geoserver/rest/namespaces/geonode.xml"
type="application/xml"/>\n  </namespace>\n
<title>salah_aldin_wells_iraq_unesco_ll_point</title>\n  <keywords>\n
<string>features</string>\n
<string>salah_aldin_wells_iraq_unesco_ll_point</string>\n  </keywords>\n
<nativeCRS>GEOGCS["WGS 84", \n  DATUM["World Geodetic System
1984", \n    SPHEROID["WGS 84", 6378137.0, 298.257223563,
AUTHORITY["EPSG","7030"]], \n
AUTHORITY["EPSG","6326"]], \n
PRIMEM["Greenwich", 0.0,
AUTHORITY["EPSG","8901"]], \n  UNIT["degree",
0.017453292519943295], \n  AXIS["Geodetic longitude", EAST], \n
AXIS["Geodetic latitude", NORTH], \n
AUTHORITY["EPSG","4326"]]</nativeCRS>\n
<srs>EPSG:4326</srs>\n  <nativeBoundingBox>\n
<minx>43.0292000000001</minx>\n    <maxx>44.8967</maxx>\n
<miny>33.7583000000001</miny>\n    <maxy>35.2347000000001</maxy>\n
<crs>EPSG:4326</crs>\n  </nativeBoundingBox>\n  <latLonBoundingBox>\n
<crs>GEOGCS["WGS84(DD)", \n  DATUM["WGS84", \n
SPHEROID["WGS84", 6378137.0, 298.257223563]], \n
PRIMEM["Greenwich", 0.0], \n  UNIT["degree",
AXIS["Geodetic latitude", NORTH]]</crs>\n
</latLonBoundingBox>\n
<projectionPolicy>FORCE_DECLARED</projectionPolicy>\n
<enabled>true</enabled>\n  <store class="dataStore">\n
<name>geonode:datastore</name>\n    <atom:link xmlns:atom="
http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore.xml"
type="application/xml"/>\n  </store>\n  <maxFeatures>0</maxFeatures>\n
<numDecimals>0</numDecimals>\n
<overridingServiceSRS>false</overridingServiceSRS>\n
<skipNumberMatched>false</skipNumberMatched>\n
<circularArcPresent>false</circularArcPresent>\n  <attributes',
ParseError(ExpatError('unclosed token: line 54, column 2',),))
2017-11-16 15:48 GMT+01:00 Paolo Corti <pcorti at gmail.com>:
> Hi Federico
> updatelayers will regenerate thumbnails for layers.
> Unfortunately there isn't a solution for maps right now. You can only
> manually regenerate them by using the "Set thumbnail" button
> cheers
> p
> On Thu, Nov 16, 2017 at 7:15 AM, Federico Gianoli <alpacagis at gmail.com>
> wrote:
> > Hi,
> > I have, maybe a stupid question.
> > I am using GeoNode 2.6.3.
> > Is there any way to regenerate all the layers and maps thumbnails?
> > Thanks
> > Federico
> > geonode-users mailing list
> > geonode-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171116/d389784b/attachment-0001.html>
More information about the geonode-users mailing list
