[GeoNode-users] Dificulty logging into GeoServer
Daniel Victoria
daniel.victoria at gmail.com
Fri Nov 17 07:21:07 PST 2017
The funny thing is that it works the first time I login after a
apache/tomcat restart
Where can I look to try and debug this problem?
I'm also seeing this in apache error.log. Not sure if it's related:
extern "Python": function Cryptography_rand_bytes() called, but
@ffi.def_extern() was not called in the current subinterpreter. Returning
0.
On Fri, Nov 17, 2017 at 1:12 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Ok, so the problem arise when you try to use the geonode button, right?
> In that case I'm afraid there's an issue on the OAuth2 configuration which
> can be either on GeoNode side, GeoServer side or both :(
> Also you have to be sure that GeoServer can reach GeoNode in order to
> validate the credentials and successfully complete the handshake.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
> 55054 Massarosa
> (LU)
> Italy
> phone: +39 0584 962313 <+39%200584%20962313>
> fax: +39 0584 1660272 <+39%200584%20166%200272>
> mob: +39 331 6233686 <+39%20331%20623%203686>
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
> Le informazioni contenute in questo messaggio di posta elettronica e/o
> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> darcene notizia via e-mail e di procedere alla distruzione del messaggio
> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
> principi dettati dal D.Lgs. 196/2003.
> The information in this message and/or attachments, is intended solely for
> the attention and use of the named addressee(s) and may be confidential or
> proprietary in nature or covered by the provisions of privacy act
> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> Code).Any use not in accord with its purpose, any disclosure, reproduction,
> copying, distribution, or either dissemination, either whole or partial, is
> strictly forbidden except previous formal approval of the named
> addressee(s). If you are not the intended recipient, please contact
> immediately the sender by telephone, fax or e-mail and delete the
> information in this message that has been received in error. The sender
> does not give any warranty or accept liability as the content, accuracy or
> completeness of sent messages and accepts no responsibility for changes
> made after they were sent or for other risks which arise as a result of
> e-mail transmission, viruses, etc.
> On Fri, Nov 17, 2017 at 4:06 PM, Daniel Victoria <
> daniel.victoria at gmail.com> wrote:
>> Hi Alessio,
>> I can log into Geoserver using the admin password.
>> And the geoserver web gui works also
>> On Fri, Nov 17, 2017 at 11:49 AM Alessio Fabiani <
>>> Hi Daniel,
>>> a question, are you able to login to GeoServer at least the first time
>>> or you cannot login to GeoServer anyway?
>>> Also the GeoServer web gui appears, even if you are not logged in, if
>>> you go directly to the geoserver url?
>>> Regards,
>>> Alessio Fabiani
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> 55054 Massarosa
>>> (LU)
>>> Italy
>>> for the attention and use of the named addressee(s) and may be confidential
>>> or proprietary in nature or covered by the provisions of privacy act
>>> On Fri, Nov 17, 2017 at 2:20 PM, Daniel Victoria <
>>>> Hi list,
>>>> I just installed GeoNode 2.6 in a fresh Ubuntu Server, using the
>>>> ppa:geonode/stable repository. I then created a superuser and updated the
>>>> IP.
>>>> After that i tried to log into GeoServer clicking on the GeoNode icon
>>>> that appears in the Geoserver web page but it did not work. It gave me a
>>>> "mismatching redirect uri" Searching the web I found some discussion about
>>>> setting up GeoServer to allow for Oauth2 to work
>>>> https://lists.osgeo.org/pipermail/geonode-users/2017-June/003261.html
>>>> This I followed the steps detailed in a Google Docs written by Alessio
>>>> Fabiani. After that, things seamed to work. I would log into GeoNode as
>>>> admin, go to GeoServer and things would work. But if I close geoserver and
>>>> open again, I'm logged out. And when I click on the GeoNode icon, to log
>>>> into geoserver, I'm recieve a 404 error
>>>> HTTP Status 404 -
>>>> *type* Status report
>>>> *message*
>>>> *description* *The requested resource is not available.*
>>>> Apache Tomcat/7.0.68 (Ubuntu)
>>>> Any idea what is going on?
>>>> Thanks
>>>> Daniel
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171117/e7223b20/attachment-0001.html>
More information about the geonode-users
