[GeoNode-users] GeoNode-problem with poor performance
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Nov 22 00:33:50 PST 2017
Dear Tamara,
please have a look at the GeoNode commercial providers here
http://geonode.org/providers/
This is the Open Source community, you won't be able to find replies to
such kind of requests here, I'm afraid.
Feel free to contact directly any of the commercial supporters.
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
On Wed, Nov 22, 2017 at 8:59 AM, Tamara Pejakovic <tamara.pejakovic at cedis.me
> wrote:
> Dear community,
> We've wrote to you earlier about performance issues (
> http://osgeo-org.1560.x6.nabble.com/Poor-performance-
> GeoNode-td5332874.html).
> We use GeoNode to map the infrastructure of our company. Currently, 180
> layers are uploaded and the performance is *very bad.* *Layers are
> extremely slow loaded on the map-initial loading of layers last almost 1
> minute?!  (video clip attached) Info balloons are also slowly appearing*.
> The video shows the response of the map when only one user is connected. *If
> 3-4 users are connected at the same time, performance becomes so bad that
> the map can not be used! *
> Using cache memory for the map did not result with significant results.
> Do you have any suggestion to solve this problem?* If we solve the
> problem of performance, our company would be interested in subscribing to
> geonode support  so we would appreciate if you could help us with this
> problem.*
> We are at your disposal for all additional information.
> Best regards,
> Video: https://www.dropbox.com/s/js45q8gr45kawyh/geonode_poor_per.flv?dl=0
> *Tamara Pejaković*
> IT Department
> CEDIS DOO
> Ivana Milutinovića 12, 81000 Podgorica
> tel: +382 20 408 453 <+382%2020%20408%20453>
> mob: +382 69 338 726 <+382%2069%20338%20726>
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171122/727a2d05/attachment-0001.html>
More information about the geonode-users mailing list
