[GeoNode-users] how to regenerate map tile
Federico Gianoli
alpacagis at gmail.com
Wed Nov 22 12:14:26 PST 2017
Dear list,
I didn't understand why I have this issue, but I have solved by setting my
map layers to "Single tile".
[image: Immagine incorporata 1]
Thanks a lot
Federico
2017-11-22 14:31 GMT+01:00 Federico Gianoli <alpacagis at gmail.com>:
> There is no firewall in my network and I am able to access without problem
> to my geoserver istance.
> Indeed, when I request the missing tile, geoserver sends me the correct
> tile. But it seems to me that the page doesn't make the request for all the
> tiles
> 2017-11-22 14:05 GMT+01:00 Alessio Fabiani <alessio.fabiani at geo-
> solutions.it>:
>> Well the error says "Server unreachable" so, yes, it looks that somehow
>> your connection is broken. Is there a firewall or proxy or something
>> similar limiting the number of connections to GeoServer?
>> Is GeoServer reachable directly?
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A
>> <https://maps.google.com/?q=Via+di+Montramito+3/A+55054+%C2%A0Massarosa&entry=gmail&source=g>
>> 55054 Massarosa
>> (LU)
>> Italy
>> phone: +39 0584 962313 <+39%200584%20962313>
>> fax: +39 0584 1660272 <+39%200584%20166%200272>
>> mob: +39 331 6233686 <+39%20331%20623%203686>
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> AVVERTENZE AI SENSI DEL D.Lgs. 196/2003
>> Le informazioni contenute in questo messaggio di posta elettronica e/o
>> nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
>> loro utilizzo è consentito esclusivamente al destinatario del messaggio,
>> per le finalità indicate nel messaggio stesso. Qualora riceviate questo
>> messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
>> darcene notizia via e-mail e di procedere alla distruzione del messaggio
>> stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
>> divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
>> utilizzarlo per finalità diverse, costituisce comportamento contrario ai
>> principi dettati dal D.Lgs. 196/2003.
>> The information in this message and/or attachments, is intended solely
>> for the attention and use of the named addressee(s) and may be confidential
>> or proprietary in nature or covered by the provisions of privacy act
>> (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
>> Code).Any use not in accord with its purpose, any disclosure, reproduction,
>> copying, distribution, or either dissemination, either whole or partial, is
>> strictly forbidden except previous formal approval of the named
>> addressee(s). If you are not the intended recipient, please contact
>> immediately the sender by telephone, fax or e-mail and delete the
>> information in this message that has been received in error. The sender
>> does not give any warranty or accept liability as the content, accuracy or
>> completeness of sent messages and accepts no responsibility for changes
>> made after they were sent or for other risks which arise as a result of
>> e-mail transmission, viruses, etc.
>> On Wed, Nov 22, 2017 at 1:54 PM, Federico Gianoli <alpacagis at gmail.com>
>> wrote:
>>> Hi Alessio,
>>> I have tried from different computers and accounts but the problem
>>> persist.
>>> I don't think that this is a problem of the cache of my browser, I have
>>> cleaned the cache and I did a reboot of the server.
>>> Maybe is something to set in geoserver?
>>> Thanks for your help
>>> Fede
>>> 2017-11-22 10:08 GMT+01:00 Alessio Fabiani <
>>> alessio.fabiani at geo-solutions.it>:
>>>> Federico,
>>>> did you try to logout and login again? Is that possible that your
>>>> browser cached an old access_token with is no valid anymore?
>>>> Nevertheless from the screenshots the message seems to be clear, the
>>>> GeoServer is unreachable somehow. Maybe you are seeing old locally cached
>>>> tiles only while the server is offline.
>>>> Regards,
>>>> Alessio Fabiani
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> 55054 Massarosa
>>>> (LU)
>>>> Italy
>>>> On Mon, Nov 20, 2017 at 12:11 PM, Federico Gianoli <alpacagis at gmail.com
>>>> > wrote:
>>>>> When I clik on Inspect I have these errors
>>>>> If I check the html, I can note that the system request the tile not
>>>>> for the whole image
>>>>> [image: Immagine incorporata 2]
>>>>> If I use the layer that loads correctly to retrive the missing
>>>>> bounding box and I request the missing tile, this is generate correctly.
>>>>> I don't understand why the system doesn't complete the request.
>>>>> Thanks
>>>>> Fede
>>>>> 2017-11-19 21:20 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
>>>>>> Hi Federico,
>>>>>> do you see any error in the network console of your browser
>>>>>> development tools?
>>>>>> Il giorno 18/nov/2017, alle ore 17:50, Federico Gianoli <
>>>>>> alpacagis at gmail.com> ha scritto:
>>>>>> > Good evening,
>>>>>> > I have this situation with the maps.
>>>>>> > someone have had the same problem?
>>>>>> > <image.png>
>>>>>> > thanks a lot
>>>>>> > have a nice w.e.
>>>>>> > Federico
>>>>>> > _______________________________________________
>>>>>> > geonode-users mailing list
>>>>>> > geonode-users at lists.osgeo.org
>>>>>> > https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171122/0285dae6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171122/0285dae6/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171122/0285dae6/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171122/0285dae6/attachment-0005.png>
More information about the geonode-users
