[GeoNode-users] I can't upload layers
Ariel Neri ariel.neriw at gmail.com
Mon Nov 27 07:25:37 PST 2017
Hi Annalisa, could you fix this issue? I´m facing the same problem and i
would like to how you did it. Thanks!
Ariel
2017-07-18 5:02 GMT-03:00 Francesco Bartoli <xbartolone at gmail.com>:
> You should review a little bit the configuration of your installation in
> particular the section of oauth2 configuration. Maybe a look at the
> workshop http://geonode.org/geonode-workshop/foss4git2017/#/4/7
> <https://n1.nylas.com/link/c6ec8a14bed90b1d818e5d0b0315b3664218da2fcd6721ea6d412ed515bbd5d7/0?redirect=http%3A%2F%2Fgeonode.org%2Fgeonode-workshop%2Ffoss4git2017%2F%23%2F4%2F7&recipient=geonode-users%40lists.osgeo.org>
> you attended in Genova can help.
> Francesco
> Sent from Nylas Mail
> <https://n1.nylas.com/link/c6ec8a14bed90b1d818e5d0b0315b3664218da2fcd6721ea6d412ed515bbd5d7/1?redirect=https%3A%2F%2Fnylas.com%3Fref%3Dn1&recipient=geonode-users%40lists.osgeo.org>,
> the best free email app for work
> On lug 18 2017, at 9:53 am, Annalisa Schiavon <annalisa.schiavon at gmail.com>
> wrote:
>> Hi Francesco!
>> I run the command you suggest and I receive
>> curl http://localhost:8080/geoserver/rest/workspaces.json
>> <http://localhost:8080/geoserver/rest/workspaces.json?recipient=geonode-users%40lists.osgeo.org>
>> {"workspaces":""}
>> I do not understand what is misconfigured in my Geoserver-Geonode!
>> Than, I set Active role Service = default in Geoserver (Security
>> Settings) and I could upload my layer ...
>> Now I set again Active role Service = geonode REST role service and I
>> get this Warning in geoserver log:
>> WARN [geofence.cache] - org.geoserver.geofence.cache.CachedRuleReader$NoAuthException:
>> Can't auth user [admin]
>> 2017-07-17 16:46 GMT+02:00 Francesco Bartoli <xbartolone at gmail.com>:
>> Hi Annalisa,
>> can you try to make a curl call to that endpoint from within the server?
>> Basically connect through ssh and then run from the shell:
>> $ curl http://localhost
>> <http://localhost/?recipient=geonode-users%40lists.osgeo.org>:8
>> you should receive something like
>> {"workspaces":""}
>> If you get 404 the it's likely geoserver is not routed through localhost.
>> Hope this helps
>> <https://n1.nylas.com/link/82bc912f54831b3fad494772c7bf7019a669ef0039d12be59d86966dcf2688fb/0?redirect=https%3A%2F%2Fnylas.com%3Fref%3Dn1&amp%3Brecipient=annalisa.schiavon%40gmail.com&recipient=geonode-users%40lists.osgeo.org>,
>> On lug 17 2017, at 3:15 pm, Annalisa Schiavon <
>> annalisa.schiavon at gmail.com> wrote:
>> Hi all.
>> I've migrated all my old layers, but now I can't upload a layer from ui.
>> It says:
>> "Tried to make a GET request to http://localhost:8080/geoserve
>> r/rest/workspaces/default.xml
>> <http://localhost:8080/geoserver/rest/workspaces/default.xml?recipient=geonode-users%40lists.osgeo.org>
>> but got a 404 status code: No such workspace: default"
>> In apache log I find:
>> ... Tried to make a GET request to http://localhost:8080/geoserve
>> ... [wsgi:error] [pid 9903:tid 139960535320320] No such workspace: default
>> In effect I have only one workspace: geonode, wich is the default one.
>> My geoserver-data-dir points to /mnt/geodata/geoserver_data and there is
>> the file /mnt/geodata/geoserver_data/workspaces/default.xml of tomcat7
>> user with 664 permission.
>> Please help!
>> Now I can login with geonode user both in geonode that in geoserver and I
>> see layers and maps and all thumbs.
>> Annalisa
>> geonode-users mailing listgeonode-users at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/geonode-users <https://lists.osgeo.org/mailman/listinfo/geonode-users?recipient=geonode-users%40lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171127/f4c81165/attachment.html>
More information about the geonode-users mailing list
