[GeoNode-users] Disable Unique filename
Arisandi, Donny (ICRAF) D.Arisandi at cgiar.org
Mon Oct 9 23:47:06 PDT 2017
Thanks Simone, but I need the filename of the document to be the same with the updated one. As we know if we edit document and replace the file with the same file name, it would generate a new filename. I would like to disable it if possible.
If anyone have experienced on this please advise.
Cheers
From: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Sent: 10 Oktober 2017 12:22
To: Arisandi, Donny (ICRAF)
Cc: geonode-users at lists.osgeo.org
Subject: Re: [GeoNode-users] Disable Unique filename
Hi, There's not a unique filename constraint but a unique layer name, which cannot be disabled, the layer name is used as unique ID in GeoNode. You can always set a layer title, it is not unique.
best
2017-10-10 6:05 GMT+02:00 Arisandi, Donny (ICRAF) <D.Arisandi at cgiar.org<mailto:D.Arisandi at cgiar.org>>:
Dear all,
How to disable unique filename function? Please advise.
Thank you
Donny
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171010/7f500668/attachment-0001.html>
More information about the geonode-users mailing list
