[GeoNode-users] Missing columns after migrating data from Geonode 2.4 to 2.6
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Oct 19 00:33:36 PDT 2017
Ok thanks a lot, then we need to create the missing migration. Could you
please open a ticket on this?
best
2017-10-19 2:06 GMT+02:00 Israel López <asralf at gmail.com>:
> Hi everybody, just in this moment I found the same error trying to delete
> some layers.
> Looking around I found that the file migration is missing for the Upload
> app, it only has the
> 24_initial.py, but this file includes the creation of the new fields, the
> right way have to be two files,
> the initial24.py and the 24_to_26.py as the other apps.
> So as we run initial--fake, the tables are not created, the solution for
> me was to delete the old
> upload and upload_file tables (I don't know why are empty), delete the
> fake migration in the
> django_migrations table and run the migrate comand for upload, and thats
> it, the tables were
> created.
> Hope this helps somebody. Greetings from Mexico.
> 2017-10-18 13:39 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Thanks all for the answers and feedbacks, we should investigate why
>> "migrate" did not add those columns. It should be its job.
>> Best
>> 2017-10-18 20:10 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>>> Thanks Annalisa, I ended up going that route too. I added those
>>> columns and removed the not null constraint on last_login on
>>> people_profile.
>>> Eric
>>> On Wed, Oct 18, 2017 at 2:49 AM, Annalisa Schiavon
>>> <annalisa.schiavon at gmail.com> wrote:
>>> > Dear Eric,
>>> > on 3 July I found a similar issue: upload_upload table hasn't 4
>>> attribute:
>>> > mosaic_time_regex,
>>> > mosaic_time_value, mosaic_elev_regex and mosaic_elev_value.
>>> > I added those columns and solved my problem.
>>> > Regards,
>>> > Annalisa
>>> > 2017-10-16 16:24 GMT+02:00 Eric Goddard <egoddard1010 at gmail.com>:
>>> >> Hi all,
>>> >> We're trying to upgrade from GeoNode 2.4 to 2.6. I have a new VM with
>>> >> Geonode 2.6 installed on Ubuntu 16.04 from the PPA. I dumped the
>>> >> postgres data from our 2.4 server and created new DBs on the Geonode
>>> >> 2.6 instance and updated settings.py to point to the geonode 2.4
>>> >> geonode and geonode_data DBs.
>>> >> Following the suggestion in this thread
>>> >> (http://osgeo-org.1560.x6.nabble.com/Help-for-migrate-data-f
>>> rom-2-4-to-2-6-td5323208.html),
>>> >> I ran geonode migrate --fake-initial and everything appears to have
>>> >> worked, however if I try to create a new account from the geonode
>>> >> registration page, or delete an existing account from the admin panel
>>> >> I get some errors.
>>> >> Trying to create a new account results in the following error:
>>> >> IntegrityError: null value in column "last_login" violates not-null
>>> >> constraint
>>> >> Trying to delete an account results in the following error:
>>> >> ProgrammingError: column upload_upload.mosaic_time_regex does not
>>> exist
>>> >> It looks like the migration didn't run correctly. If anyone has advice
>>> >> on how fix/work a round this issue it would be greatly appreciated!
>>> >> We'll be reloading the data anyway so our main concern is just
>>> >> migrating the accounts and groups.
>>> >> If it helps, here is the comparison of the geonode 2.4 and 2.6 schemas
>>> >> for the upload_upload table. The mosaic* columns are missing from the
>>> >> 2.4 database that was migrated:
>>> >> geonode 2.4 database (after running migrate):
>>> >> geonode24=# \d upload_upload
>>> >> Table "public.upload_upload"
>>> >> Column | Type |
>>> Modifiers
>>> >> id | integer | not null default
>>> >> nextval('upload_upload_id_seq'::regclass)
>>> >> import_id | bigint |
>>> >> user_id | integer |
>>> >> state | character varying(16) | not null
>>> >> date | timestamp with time zone | not null
>>> >> layer_id | integer |
>>> >> upload_dir | character varying(100) |
>>> >> name | character varying(64) |
>>> >> complete | boolean | not null
>>> >> session | text |
>>> >> metadata | text |
>>> >> Indexes:
>>> >> "upload_upload_pkey" PRIMARY KEY, btree (id)
>>> >> "upload_upload_layer_id" btree (layer_id)
>>> >> "upload_upload_user_id" btree (user_id)
>>> >> Foreign-key constraints:
>>> >> "upload_upload_layer_id_fkey" FOREIGN KEY (layer_id) REFERENCES
>>> >> layers_layer(resourcebase_ptr_id) DEFERRABLE INITIALLY DEFERRED
>>> >> "upload_upload_user_id_fkey" FOREIGN KEY (user_id) REFERENCES
>>> >> people_profile(id) DEFERRABLE INITIALLY DEFERRED
>>> >> Referenced by:
>>> >> TABLE "upload_uploadfile" CONSTRAINT
>>> >> "upload_uploadfile_upload_id_fkey" FOREIGN KEY (upload_id) REFERENCES
>>> >> upload_upload(id) DEFERRABLE INITIALLY DEFERRED
>>> >> Geonode 2.6 database (from initial install):
>>> >> geonode=# \d upload_upload
>>> >> Column | Type |
>>> >> Modifiers
>>> >> session | text |
>>> >> metadata | text |
>>> >> mosaic_time_regex | character varying(128) |
>>> >> mosaic_time_value | character varying(128) |
>>> >> mosaic_elev_regex | character varying(128) |
>>> >> mosaic_elev_value | character varying(128) |
>>> >> user_id | integer |
>>> >> Indexes:
>>> >> "upload_upload_7a39a38c" btree (layer_id)
>>> >> "upload_upload_e8701ad4" btree (user_id)
>>> >> "u_layer_id_6346de911330a880_fk_layers_layer_resourcebase_ptr_id"
>>> >> FOREIGN KEY (layer_id) REFERENCES layers_layer(resourcebase_ptr_id)
>>> >> "upload_upload_user_id_7fad116c8478bf31_fk_people_profile_id"
>>> >> FOREIGN KEY (user_id) REFERENCES people_profile(id) DEFERRABLE
>>> >> INITIALLY DEFERRED
>>> >> Referenced by:
>>> >> "upload_uploadfil_upload_id_21ef448d17dd4b6b_fk_upload_upload_id"
>>> >> FOREIGN KEY (upload_id) REFERENCES upload_upload(id) DEFERRABLE
>>> >> INITIALLY DEFERRED
>>> >> Thanks!
>>> >> Eric
>>> >> _______________________________________________
>>> >> geonode-users mailing list
>>> >> geonode-users at lists.osgeo.org
>>> >> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20171019/96776de1/attachment.html>
More information about the geonode-users
